Hello everyone, a good week for everyone! Is there any way to load a sequence of 4 images.png "one at a time" every 3 seconds in the same coordinate in a palette. Each image would have 3 seconds of display: image1.png: 3seconds later = upload image2.png .... 3 seconds after uploading image3.png / 3 seconds after uploading image4.png My idea here is to improvise a kind of window like: Wait! Processing ...
OK. It is advisable to upgrade to version 19.0.1.
Look what happened. It seems to work.
There are 6 modifications in your script. They are labeled as // MODIFICATION !!!!!
One at the beginning, the rest at the very end.
The script a.jsx - Google Drive
P.S. Although all this garbage. It is necessary to use normal progressbar.
I did not understand anything, but I can offer.
Open the first image. Turn the layer into a smart object.
Do delay in 3 seconds. Then in the loop do Replace content.on the next image and do a delay
Hi r-bin Is it through images that I communicate better? It would work like a gif.
function drawButton() {
this.graphics.drawImage(this.image, 0, 0);
myPrs = new Window('palette', 'Processing image');
myPrs.orientation = 'column';
myPrs.alignment = 'right';
myPrs.ProcessHead = myPrs.add('statictext',[40,0,260,25], "Batch Processing...");
var logo = File("~/Desktop/imge 1.png");
var logo = myPrs .add("iconbutton", [0, 0, 0, 0], ScriptUI.newImage(logo), )
logo.onDraw = drawButton;
logo.location = [10, 2]
var LENGTH = 4;
myPrs.show();
for(i=0;i<1;i++){
var PrCounter = 0;
Function1();
function Function1(){
// The palette will be displayed the moment some script is executing some function
Well, you almost did everything.
Why not use
var img = [ new File("~/Desktop/imge 1.png"),
new File("~/Desktop/imge 2.png"),
new File("~/Desktop/imge 3.png"),
new File("~/Desktop/imge 4.png") ];
//var logo = myPrs.add("image", undefined, img[0] )
var logo = myPrs .add("iconbutton", undefined, img[0] )
logo.onDraw = drawButton; // if logo == "image" this func not need
var LENGTH = 4;
myPrs.show();
for(i=0;i<LENGTH;i++)
logo.image = img;
refresh(); //
var PrCounter = 0;
Function1();
function Function1(){ $.sleep(500)
Using refresh () is a bad option, but there is no time to experiment.
r-bin i am impressed by your ability to programmer, I am honored to receive your answers! It really worked well until I realized that for every loaded image, my script runs again. Where am I going wrong, how to make this work correctly in my script? I feel frustrated.
This script performs too long a task! All images would have loaded until the script finished executing its function. Will the script have to be broken into 4 parts? if the answer is yes, how can I make it work in practice with this palette?
Here is the script that I want to add a "Wait ... processing" palette
cTID = function(s) { return app.charIDToTypeID(s); };
sTID = function(s) { return app.stringIDToTypeID(s); };
////////////// Id-Prints beta 2 ////////////////////////////////
function Id_Printsbeta2() {
// Make
function step1(enabled, withDialog) {
if (enabled != undefined && !enabled)
return;
var dialogMode = (withDialog ? DialogModes.ALL : DialogModes.NO);
//Risezer Reol 200 DPI
var doc = activeDocument
if(doc.resolution<200){
doc.resizeImage (undefined, undefined, 200, )}
runMenuItem(app.charIDToTypeID("FtOn"));
var desc1 = new ActionDescriptor();
var ref1 = new ActionReference();
ref1.putClass(cTID('Lyr '));
desc1.putReference(cTID('null'), ref1);
desc1.putInteger(cTID('LyrI'), 3);
executeAction(cTID('Mk '), desc1, dialogMode);
// Reset
function step2(enabled, withDialog) {
return;
ref1.putProperty(cTID('Clr '), cTID('Clrs'));
executeAction(cTID('Rset'), desc1, dialogMode);
// Set
function step3(enabled, withDialog) {
return;
ref1.putProperty(cTID('Clr '), cTID('BckC'));
var desc2 = new ActionDescriptor();
desc2.putUnitDouble(cTID('H '), cTID('#Ang'), 0);
desc2.putDouble(cTID('Strt'), 99.6078431372549);
desc2.putDouble(cTID('Brgh'), 1.17647058823529);
desc1.putObject(cTID('T '), cTID('HSBC'), desc2);
desc1.putString(cTID('Srce'), "photoshopPicker");
executeAction(cTID('setd'), desc1, dialogMode);
// Merge Visible
function step4(enabled, withDialog) {
return;
executeAction(sTID('mergeVisible'), undefined, dialogMode);
// Canvas Size
function step5(enabled, withDialog) {
return;
desc1.putBoolean(cTID('Rltv'), true);
desc1.putUnitDouble(cTID('Wdth'), cTID('#Rlt'), 11.3385826771654);
desc1.putUnitDouble(cTID('Hght'), cTID('#Rlt'), 11.3385826771654);
desc1.putEnumerated(cTID('Hrzn'), cTID('HrzL'), cTID('Cntr'));
desc1.putEnumerated(cTID('Vrtc'), cTID('VrtL'), cTID('Cntr'));
desc1.putEnumerated(sTID("canvasExtensionColorType"), sTID("canvasExtensionColorType"), cTID('Clr '));
desc2.putDouble(cTID('Strt'), 0);
desc2.putDouble(cTID('Brgh'), 100);
desc1.putObject(sTID("canvasExtensionColor"), cTID('HSBC'), desc2);
executeAction(sTID('canvasSize'), desc1, dialogMode);
// Set
function step6(enabled, withDialog) {
return;
ref1.putProperty(cTID('Path'), cTID('WrPt'));
var list1 = new ActionList();
desc2.putEnumerated(sTID("shapeOperation"), sTID("shapeOperation"), cTID('Add '));
var list2 = new ActionList();
var desc3 = new ActionDescriptor();
desc3.putBoolean(cTID('Clsp'), true);
var list3 = new ActionList();
var desc4 = new ActionDescriptor();
var desc5 = new ActionDescriptor();
desc5.putUnitDouble(cTID('Hrzn'), cTID('#Rlt'), 0);
desc5.putUnitDouble(cTID('Vrtc'), cTID('#Rlt'), 0);
desc4.putObject(cTID('Anch'), cTID('Pnt '), desc5);
list3.putObject(cTID('Pthp'), desc4);
var desc6 = new ActionDescriptor();
var desc7 = new ActionDescriptor();
desc7.putUnitDouble(cTID('Hrzn'), cTID('#Rlt'), 43.2);
desc7.putUnitDouble(cTID('Vrtc'), cTID('#Rlt'), 0);
desc6.putObject(cTID('Anch'), cTID('Pnt '), desc7);
list3.putObject(cTID('Pthp'), desc6);
var desc8 = new ActionDescriptor();
var desc9 = new ActionDescriptor();
desc9.putUnitDouble(cTID('Hrzn'), cTID('#Rlt'), 43.2);
desc9.putUnitDouble(cTID('Vrtc'), cTID('#Rlt'), 2.88);
desc8.putObject(cTID('Anch'), cTID('Pnt '), desc9);
list3.putObject(cTID('Pthp'), desc8);
var desc10 = new ActionDescriptor();
var desc11 = new ActionDescriptor();
desc11.putUnitDouble(cTID('Hrzn'), cTID('#Rlt'), 0);
desc11.putUnitDouble(cTID('Vrtc'), cTID('#Rlt'), 2.88);
desc10.putObject(cTID('Anch'), cTID('Pnt '), desc11);
list3.putObject(cTID('Pthp'), desc10);
desc3.putList(cTID('Pts '), list3);
list2.putObject(cTID('Sbpl'), desc3);
desc2.putList(cTID('SbpL'), list2);
list1.putObject(cTID('PaCm'), desc2);
desc1.putList(cTID('T '), list1);
// Make
function step7(enabled, withDialog) {
return;
ref1.putClass(cTID('Path'));
var ref2 = new ActionReference();
ref2.putEnumerated(cTID('Path'), cTID('Path'), sTID("vectorMask"));
ref2.putEnumerated(cTID('Lyr '), cTID('Ordn'), cTID('Trgt'));
desc1.putReference(cTID('From'), ref2);
desc1.putString(cTID('Nm '), "mark");
// Transform
function step8(enabled, withDialog) {
return;
ref1.putEnumerated(cTID('Path'), cTID('Ordn'), cTID('Trgt'));
desc1.putEnumerated(cTID('FTcs'), cTID('QCSt'), sTID("QCSSide0"));
desc2.putUnitDouble(cTID('Hrzn'), cTID('#Rlt'), 0);
desc2.putUnitDouble(cTID('Vrtc'), cTID('#Rlt'), 0);
desc1.putObject(cTID('Ofst'), cTID('Ofst'), desc2);
desc1.putUnitDouble(cTID('Wdth'), cTID('#Prc'), 99.6336996336996);
desc1.putUnitDouble(cTID('Hght'), cTID('#Prc'), 90.0562851782364);
executeAction(cTID('Trnf'), desc1, dialogMode);
// Make
function step9(enabled, withDialog) {
return;
desc1.putInteger(cTID('LyrI'), 15);
// Set
function step10(enabled, withDialog) {
return;
ref1.putEnumerated(cTID('Lyr '), cTID('Ordn'), cTID('Trgt'));
desc2.putString(cTID('Nm '), "base");
desc1.putObject(cTID('T '), cTID('Lyr '), desc2);
// Set
function step11(enabled, withDialog) {
return;
ref1.putProperty(cTID('Chnl'), sTID("selection"));
ref2.putEnumerated(cTID('Path'), cTID('Ordn'), cTID('Trgt'));
desc1.putReference(cTID('T '), ref2);
desc1.putInteger(cTID('Vrsn'), 1);
desc1.putBoolean(sTID("vectorMaskParams"), true);
// Fill
function step12(enabled, withDialog) {
return;
desc1.putEnumerated(cTID('Usng'), cTID('FlCn'), cTID('BckC'));
desc1.putUnitDouble(cTID('Opct'), cTID('#Prc'), 100);
desc1.putEnumerated(cTID('Md '), cTID('BlnM'), cTID('Nrml'));
executeAction(cTID('Fl '), desc1, dialogMode);
// Set
function step13(enabled, withDialog) {
return;
desc1.putEnumerated(cTID('T '), cTID('Ordn'), cTID('None'));
// Set
function step14(enabled, withDialog) {
return;
desc1.putEnumerated(cTID('T '), cTID('Ordn'), cTID('Al '));
// Align
function step15(enabled, withDialog) {
return;
desc1.putEnumerated(cTID('Usng'), cTID('ADSt'), sTID("ADSLefts"));
executeAction(cTID('Algn'), desc1, dialogMode);
// Align
function step16(enabled, withDialog) {
return;
desc1.putEnumerated(cTID('Usng'), cTID('ADSt'), sTID("ADSTops"));
// Set
function step17(enabled, withDialog) {
return;
// Layer Via Copy
function step18(enabled, withDialog) {
return;
executeAction(sTID('copyToLayer'), undefined, dialogMode);
// Transform
function step19(enabled, withDialog) {
return;
desc1.putEnumerated(cTID('FTcs'), cTID('QCSt'), sTID("QCSAverage"));
desc1.putUnitDouble(cTID('Angl'), cTID('#Ang'), 90);
desc1.putEnumerated(cTID('Intr'), cTID('Intp'), cTID('Bcbc'));
// Set
function step20(enabled, withDialog) {
return;
// Align
function step21(enabled, withDialog) {
return;
// Transform
function step22(enabled, withDialog) {
return;
desc1.putUnitDouble(cTID('Wdth'), cTID('#Prc'), -100);
// Align
function step23(enabled, withDialog) {
return;
// Set
function step24(enabled, withDialog) {
return;
// Merge Layers
function step25(enabled, withDialog) {
return;
executeAction(sTID('mergeLayersNew'), desc1, dialogMode);
// Layer Via Copy
function step26(enabled, withDialog) {
return;
// Transform
function step27(enabled, withDialog) {
return;
// Set
function step28(enabled, withDialog) {
return;
// Align
function step29(enabled, withDialog) {
return;
desc1.putEnumerated(cTID('Usng'), cTID('ADSt'), sTID("ADSRights"));
// Set
function step30(enabled, withDialog) {
return;
// Merge Layers
function step31(enabled, withDialog) {
return;
// Layer Via Copy
function step32(enabled, withDialog) {
return;
// Transform
function step33(enabled, withDialog) {
return;
desc1.putUnitDouble(cTID('Hght'), cTID('#Prc'), -100);
// Set
function step34(enabled, withDialog) {
return;
// Align
function step35(enabled, withDialog) {
return;
desc1.putEnumerated(cTID('Usng'), cTID('ADSt'), sTID("ADSBottoms"));
// Set
function step36(enabled, withDialog) {
return;
// Merge Layers
function step37(enabled, withDialog) {
return;
// Merge Layers
function step38(enabled, withDialog) {
return;
// Canvas Size
function step39(enabled, withDialog) {
return;
desc1.putUnitDouble(cTID('Hght'), cTID('#Rlt'), 17.007874015748);
desc1.putEnumerated(cTID('Vrtc'), cTID('VrtL'), cTID('Top '));
// Set
function step40(enabled, withDialog) {
return;
ref1.putProperty(cTID('Clr '), cTID('FrgC'));
desc2.putDouble(cTID('Strt'), 100);
desc2.putDouble(cTID('Brgh'), 0);
// Make
function step41(enabled, withDialog) {
return;
ref1.putClass(cTID('TxLr'));
desc2.putString(cTID('Txt '), "Hollywood ID:");
desc3.putEnumerated(sTID("warpStyle"), sTID("warpStyle"), sTID("warpNone"));
desc3.putDouble(sTID("warpValue"), 0);
desc3.putDouble(sTID("warpPerspective"), 0);
desc3.putDouble(sTID("warpPerspectiveOther"), 0);
desc3.putEnumerated(sTID("warpRotate"), cTID('Ornt'), cTID('Hrzn'));
desc2.putObject(cTID('warp'), cTID('warp'), desc3);
desc4.putUnitDouble(cTID('Hrzn'), cTID('#Prc'), 8.18713450292398);
desc4.putUnitDouble(cTID('Vrtc'), cTID('#Prc'), 98.0952380952381);
desc2.putObject(cTID('TxtC'), cTID('Pnt '), desc4);
desc2.putEnumerated(sTID("textGridding"), sTID("textGridding"), cTID('None'));
desc2.putEnumerated(cTID('Ornt'), cTID('Ornt'), cTID('Hrzn'));
desc2.putEnumerated(cTID('AntA'), cTID('Annt'), cTID('AnSm'));
desc5.putUnitDouble(cTID('Left'), cTID('#Pxl'), -70.414306640625);
desc5.putUnitDouble(cTID('Top '), cTID('#Pxl'), -20.595703125);
desc5.putUnitDouble(cTID('Rght'), cTID('#Pxl'), 70.4144439697266);
desc5.putUnitDouble(cTID('Btom'), cTID('#Pxl'), 7.79296875);
desc2.putObject(sTID("bounds"), sTID("bounds"), desc5);
desc6.putUnitDouble(cTID('Left'), cTID('#Pxl'), -68.414306640625);
desc6.putUnitDouble(cTID('Top '), cTID('#Pxl'), -17);
desc6.putUnitDouble(cTID('Rght'), cTID('#Pxl'), 67.8302307128906);
desc6.putUnitDouble(cTID('Btom'), cTID('#Pxl'), 5);
desc2.putObject(sTID("boundingBox"), sTID("boundingBox"), desc6);
desc7.putEnumerated(sTID("textType"), sTID("textType"), cTID('Pnt '));
desc7.putEnumerated(cTID('Ornt'), cTID('Ornt'), cTID('Hrzn'));
desc8.putDouble(sTID("xx"), 1);
desc8.putDouble(sTID("xy"), 0);
desc8.putDouble(sTID("yx"), 0);
desc8.putDouble(sTID("yy"), 1);
desc8.putDouble(sTID("tx"), 0);
desc8.putDouble(sTID("ty"), 0);
desc7.putObject(cTID('Trnf'), cTID('Trnf'), desc8);
desc7.putInteger(sTID("rowCount"), 1);
desc7.putInteger(sTID("columnCount"), 1);
desc7.putBoolean(sTID("rowMajorOrder"), true);
desc7.putUnitDouble(sTID("rowGutter"), cTID('#Pxl'), 0);
desc7.putUnitDouble(sTID("columnGutter"), cTID('#Pxl'), 0);
desc7.putUnitDouble(cTID('Spcn'), cTID('#Pxl'), 0);
desc7.putEnumerated(sTID("frameBaselineAlignment"), sTID("frameBaselineAlignment"), sTID("alignByAscent"));
desc7.putUnitDouble(sTID("firstBaselineMinimum"), cTID('#Pxl'), 0);
desc9.putDouble(cTID('Hrzn'), 0);
desc9.putDouble(cTID('Vrtc'), 0);
desc7.putObject(cTID('base'), cTID('Pnt '), desc9);
list1.putObject(sTID("textShape"), desc7);
desc2.putList(sTID("textShape"), list1);
desc10.putInteger(cTID('From'), 0);
desc10.putInteger(cTID('T '), 14);
desc11.putBoolean(sTID("styleSheetHasParent"), true);
desc11.putString(sTID("fontPostScriptName"), "ArialMT");
desc11.putString(cTID('FntN'), "Arial");
desc11.putString(cTID('FntS'), "Regular");
desc11.putInteger(cTID('Scrp'), 0);
desc11.putInteger(cTID('FntT'), 1);
desc11.putBoolean(sTID("fontAvailable"), true);
desc11.putUnitDouble(cTID('Sz '), cTID('#Pxl'), 24);
desc11.putUnitDouble(sTID("impliedFontSize"), cTID('#Pxl'), 24);
desc11.putDouble(cTID('HrzS'), 89.9999976158142);
desc11.putBoolean(sTID("syntheticBold"), true);
desc11.putUnitDouble(sTID("markYDistFromBaseline"), cTID('#Pxl'), 100);
desc11.putBoolean(sTID("altligature"), true);
desc11.putEnumerated(sTID("textLanguage"), sTID("textLanguage"), sTID("brazilianPortugueseLanguage"));
var desc12 = new ActionDescriptor();
desc12.putString(sTID("fontPostScriptName"), "MyriadPro-Regular");
desc12.putString(cTID('FntN'), "Myriad Pro");
desc12.putString(cTID('FntS'), "Regular");
desc12.putInteger(cTID('Scrp'), 0);
desc12.putInteger(cTID('FntT'), 0);
desc12.putBoolean(sTID("fontAvailable"), true);
desc12.putUnitDouble(cTID('Sz '), cTID('#Pxl'), 12);
desc12.putUnitDouble(sTID("impliedFontSize"), cTID('#Pxl'), 12);
desc12.putDouble(cTID('HrzS'), 100);
desc12.putDouble(cTID('VrtS'), 100);
desc12.putBoolean(sTID("syntheticBold"), false);
desc12.putBoolean(sTID("syntheticItalic"), false);
desc12.putBoolean(sTID("autoLeading"), true);
desc12.putInteger(cTID('Trck'), 0);
desc12.putUnitDouble(cTID('Bsln'), cTID('#Pxl'), 0);
desc12.putUnitDouble(sTID("impliedBaselineShift"), cTID('#Pxl'), 0);
desc12.putDouble(sTID("characterRotation"), 0);
desc12.putEnumerated(cTID('AtKr'), cTID('AtKr'), sTID("metricsKern"));
desc12.putEnumerated(sTID("fontCaps"), sTID("fontCaps"), cTID('Nrml'));
desc12.putEnumerated(sTID("digitSet"), sTID("digitSet"), sTID("defaultDigits"));
desc12.putEnumerated(sTID("dirOverride"), sTID("dirOverride"), sTID("dirOverrideDefault"));
desc12.putEnumerated(sTID("kashidas"), sTID("kashidas"), sTID("kashidaDefault"));
desc12.putEnumerated(sTID("diacVPos"), sTID("diacVPos"), sTID("diacVPosOpenType"));
desc12.putUnitDouble(sTID("diacXOffset"), cTID('#Pxl'), 0);
desc12.putUnitDouble(sTID("diacYOffset"), cTID('#Pxl'), 0);
desc12.putUnitDouble(sTID("markYDistFromBaseline"), cTID('#Pxl'), 100);
desc12.putEnumerated(sTID("baseline"), sTID("baseline"), cTID('Nrml'));
desc12.putEnumerated(sTID("otbaseline"), sTID("otbaseline"), cTID('Nrml'));
desc12.putEnumerated(sTID("strikethrough"), sTID("strikethrough"), sTID("strikethroughOff"));
desc12.putEnumerated(cTID('Undl'), cTID('Undl'), sTID("underlineOff"));
desc12.putUnitDouble(sTID("underlineOffset"), cTID('#Pxl'), 0);
desc12.putBoolean(sTID("ligature"), true);
desc12.putBoolean(sTID("altligature"), false);
desc12.putBoolean(sTID("contextualLigatures"), false);
desc12.putBoolean(sTID("alternateLigatures"), false);
desc12.putBoolean(sTID("oldStyle"), false);
desc12.putBoolean(sTID("fractions"), false);
desc12.putBoolean(sTID("ordinals"), false);
desc12.putBoolean(sTID("swash"), false);
desc12.putBoolean(sTID("titling"), false);
desc12.putBoolean(sTID("connectionForms"), false);
desc12.putBoolean(sTID("stylisticAlternates"), false);
desc12.putBoolean(sTID("ornaments"), false);
desc12.putBoolean(sTID("justificationAlternates"), false);
desc12.putEnumerated(sTID("figureStyle"), sTID("figureStyle"), cTID('Nrml'));
desc12.putBoolean(sTID("proportionalMetrics"), false);
desc12.putBoolean(cTID('kana'), false);
desc12.putBoolean(sTID("italics"), false);
desc12.putBoolean(cTID('ruby'), false);
desc12.putEnumerated(sTID("baselineDirection"), sTID("baselineDirection"), sTID("rotated"));
desc12.putEnumerated(sTID("textLanguage"), sTID("textLanguage"), sTID("englishLanguage"));
desc12.putEnumerated(sTID("japaneseAlternate"), sTID("japaneseAlternate"), sTID("defaultForm"));
desc12.putDouble(sTID("mojiZume"), 0);
desc12.putEnumerated(sTID("gridAlignment"), sTID("gridAlignment"), sTID("roman"));
desc12.putBoolean(sTID("enableWariChu"), false);
desc12.putInteger(sTID("wariChuCount"), 2);
desc12.putInteger(sTID("wariChuLineGap"), 0);
desc12.putDouble(sTID("wariChuScale"), 0.5);
desc12.putInteger(sTID("wariChuWidow"), 2);
desc12.putInteger(sTID("wariChuOrphan"), 2);
desc12.putEnumerated(sTID("wariChuJustification"), sTID("wariChuJustification"), sTID("wariChuAutoJustify"));
desc12.putInteger(sTID("tcyUpDown"), 0);
desc12.putInteger(sTID("tcyLeftRight"), 0);
desc12.putDouble(sTID("leftAki"), -1);
desc12.putDouble(sTID("rightAki"), -1);
desc12.putInteger(sTID("jiDori"), 0);
desc12.putBoolean(sTID("noBreak"), false);
var desc13 = new ActionDescriptor();
desc13.putDouble(cTID('Rd '), 0);
desc13.putDouble(cTID('Grn '), 0);
desc13.putDouble(cTID('Bl '), 0);
desc12.putObject(cTID('Clr '), sTID("RGBColor"), desc13);
var desc14 = new ActionDescriptor();
desc14.putDouble(cTID('Rd '), 0);
desc14.putDouble(cTID('Grn '), 0);
desc14.putDouble(cTID('Bl '), 0);
desc12.putObject(sTID("strokeColor"), sTID("RGBColor"), desc14);
desc12.putBoolean(cTID('Fl '), true);
desc12.putBoolean(cTID('Strk'), false);
desc12.putBoolean(sTID("fillFirst"), true);
desc12.putBoolean(sTID("fillOverPrint"), false);
desc12.putBoolean(sTID("strokeOverPrint"), false);
desc12.putEnumerated(sTID("lineCap"), sTID("lineCap"), sTID("buttCap"));
desc12.putEnumerated(sTID("lineJoin"), sTID("lineJoin"), sTID("miterJoin"));
desc12.putUnitDouble(sTID("lineWidth"), cTID('#Pxl'), 1);
desc12.putUnitDouble(sTID("miterLimit"), cTID('#Pxl'), 4);
desc12.putDouble(sTID("lineDashoffset"), 0);
desc11.putObject(sTID("baseParentStyle"), cTID('TxtS'), desc12);
desc10.putObject(cTID('TxtS'), cTID('TxtS'), desc11);
list2.putObject(cTID('Txtt'), desc10);
desc2.putList(cTID('Txtt'), list2);
var desc15 = new ActionDescriptor();
desc15.putInteger(cTID('From'), 0);
desc15.putInteger(cTID('T '), 14);
var desc16 = new ActionDescriptor();
desc16.putBoolean(sTID("styleSheetHasParent"), true);
desc16.putEnumerated(cTID('Algn'), cTID('Alg '), cTID('Cntr'));
desc16.putBoolean(sTID("hyphenate"), true);
desc16.putInteger(sTID("hyphenateWordSize"), 8);
desc16.putInteger(sTID("hyphenatePreLength"), 3);
desc16.putInteger(sTID("hyphenatePostLength"), 3);
desc16.putInteger(sTID("hyphenateLimit"), 2);
desc16.putDouble(sTID("hyphenationZone"), 36);
desc16.putBoolean(sTID("hyphenateCapitalized"), true);
desc15.putObject(sTID("paragraphStyle"), sTID("paragraphStyle"), desc16);
list3.putObject(sTID("paragraphStyleRange"), desc15);
desc2.putList(sTID("paragraphStyleRange"), list3);
var list4 = new ActionList();
desc2.putList(sTID("kerningRange"), list4);
desc1.putObject(cTID('Usng'), cTID('TxLr'), desc2);
desc1.putInteger(cTID('LyrI'), 89);
// Set
function step42(enabled, withDialog) {
return;
// Align
function step43(enabled, withDialog) {
return;
// Align
function step44(enabled, withDialog) {
return;
// Set
function step45(enabled, withDialog) {
return;
// Move
function step46(enabled, withDialog) {
return;
desc2.putUnitDouble(cTID('Hrzn'), cTID('#Rlt'), 0.36);
desc1.putObject(cTID('T '), cTID('Ofst'), desc2);
executeAction(cTID('move'), desc1, dialogMode);
// Move
function step47(enabled, withDialog) {
return;
desc2.putUnitDouble(cTID('Hrzn'), cTID('#Rlt'), 2.16);
desc2.putUnitDouble(cTID('Vrtc'), cTID('#Rlt'), -0.36);
// Scripts
function step48(enabled, withDialog) {
return;
if (app.documents.length > 0) {
var myDocument = app.activeDocument;
var originalUnits = app.preferences.rulerUnits;
app.preferences.rulerUnits = Units.PIXELS;
// getting the name;
var docName = myDocument.name;
//var basename = docName.match(/(.*)\.[^\.]+$/)[1];
//getting the location;
var docPath = decodeURI(myDocument.path);
// make the layer;
var myLayerRef = myDocument.artLayers.add();
myLayerRef.kind = LayerKind.TEXT;
myLayerRef.name = "text";
var myTextRef = myLayerRef.textItem;
myTextRef.size = 11;
myTextRef.font = "Arial";
myTextRef.justification = Justification.RIGHT;
//Set text colour in RGB values
var newColor = new SolidColor();
newColor.rgb.red = 192;
newColor.rgb.green = 44;
newColor.rgb.blue = 44;
myTextRef.color = newColor;
// Set the position of the text - percentages from left first, then from top.
myTextRef.position = new Array(myDocument.width - 670, myDocument.height - 1640);
myLayerRef.blendMode = BlendMode.NORMAL;
myLayerRef.opacity = 100;
myTextRef.contents = docPath.toString();
app.preferences.rulerUnits = originalUnits;
// Set
function step49(enabled, withDialog) {
return;
ref2.putEnumerated(cTID('Chnl'), cTID('Chnl'), cTID('Trsp'));
ref2.putName(cTID('Lyr '), "Hollywood ID:");
// Align
function step50(enabled, withDialog) {
return;
desc1.putEnumerated(cTID('Usng'), cTID('ADSt'), sTID("ADSCentersV"));
// Align
function step51(enabled, withDialog) {
return;
// Delete
function step52(enabled, withDialog) {
return;
executeAction(cTID('Dlt '), desc1, dialogMode);
// Set
function step53(enabled, withDialog) {
return;
// Transform
function step54(enabled, withDialog) {
return;
desc1.putEnumerated(cTID('FTcs'), cTID('QCSt'), sTID("QCSSide1"));
desc2.putUnitDouble(cTID('Hrzn'), cTID('#Rlt'), 0.53993957519531);
desc2.putUnitDouble(cTID('Vrtc'), cTID('#Rlt'), -0.19146929740906);
desc1.putUnitDouble(cTID('Wdth'), cTID('#Prc'), -100.360900342253);
desc1.putUnitDouble(cTID('Hght'), cTID('#Prc'), 99.3555158356269);
// Transform
function step55(enabled, withDialog) {
return;
desc2.putUnitDouble(cTID('Hrzn'), cTID('#Rlt'), 0.18);
desc2.putUnitDouble(cTID('Vrtc'), cTID('#Rlt'), -1.63709046319127e-13);
// Flatten Image
function step56(enabled, withDialog) {
return;
executeAction(sTID('flattenImage'), undefined, dialogMode);
/////Destranca BG
function promoteBackgroundLayer() {
var doc = activeDocument;
var layers = doc.layers;
var layer = layers[layers.length - 1];
if (layer.isBackgroundLayer) {layer.name = 'Background';}}
if (documents.length) {promoteBackgroundLayer();}
step1(); // Make
step2(); // Reset
step3(); // Set
step4(); // Merge Visible
step5(); // Canvas Size
step6(); // Set
step7(); // Make
step8(); // Transform
step9(); // Make
step10(); // Set
step11(); // Set
step12(); // Fill
step13(); // Set
step14(); // Set
step15(); // Align
step16(); // Align
step17(); // Set
step18(); // Layer Via Copy
step19(); // Transform
step20(); // Set
step21(); // Align
step22(); // Transform
step23(); // Align
step24(); // Set
step25(); // Merge Layers
step26(); // Layer Via Copy
step27(); // Transform
step28(); // Set
step29(); // Align
step30(); // Set
step31(); // Merge Layers
step32(); // Layer Via Copy
step33(); // Transform
step34(); // Set
step35(); // Align
step36(); // Set
step37(); // Merge Layers
step38(); // Merge Layers
step39(); // Canvas Size
step40(); // Set
step41(); // Make
step42(); // Set
step43(); // Align
step44(); // Align
step45(); // Set
step46(); // Move
step47(); // Move
step48(); // Scripts
step49(); // Set
step50(); // Align
step51(); // Align
step52(); // Delete
step53(); // Set
step54(); // Transform
step55(); // Transform
step56(); // Flatten Image
Id_Printsbeta2.main = function () {
Id_Printsbeta2();
Id_Printsbeta2.main();
Wow!
Do you want to use your png-progress here?
I'll look a little later.
First, tell me which version of Photoshop and OS. Since UI and its bugs (features) vary from version to version.
r-bin escreveu
Wow!
First, tell me which version of Photoshop and OS. Since UI and its bugs (features) vary from version to version.There are many steps until you complete the entire task in one script! The code is really too big! But it works very well.
I wait the time it takes! The important thing for me is to understand how to properly add my scripts so they can work on this progress bar example using custom images:
This is the version I am using:
Wow! Friend r-bin you're a genius! It is perfect! Even in version 19.0 it worked perfectly well. Dude, you do not know how much it's going to be useful to me. Now I understand how it works. Thank you for the precious minutes of dedication and sharing your knowledge. Forever grateful to you.
