16 Replies Latest reply on Mar 27, 2018 6:40 PM by MrAbarbanel
    Media Encoder "Failed" on almost every video
    Shawnbarryoftoronto Level 1
      I wish I could be more specific about the issues I'm having with Media Encoder - most people's problems I've seen thus far have been with a single project, and a diagnosed and repeatable problem. Not so lucky in my case, but here's the situation:
      Media Encoder fails on renders. It fails on all my projects at this point. This started about 2 weeks ago. I create my sequences based on my footage settings. After that, it's a combination of Adjustment layers with Lumetri colour for grading, occasionally graphic layers, but not always. Sometimes using type, not always. Sometimes with After Effects sequences through media link, but not always. If I have only one sequence rendering it fails. If I have multiple sequences, the first one fails, then ME rapidly runs through the balance of sequences and fails them all in about 6 seconds. Again that's with or without any of the variations to my timelines above. That's also across at least 5 different projects, using 3 different camera sources and 3 different audio sources. These combinations and variations from these same cameras and audio sources have all rendered no problems at all previously to a couple weeks ago. If I render the projects directly from Premiere, they render fine, using the same settings. If I restart, then ME will mostly render them fine, but not every time.
      I've updated the app recently. I've re-set the app preferences. I've cleared the media cache, by using the preferences method, and manually clearing the "common > media cache" folders. I'm on Windows 10.
      Frustrated, as I'm not doing anything repeatedly the same, and assuming I haven't spontaneously forgotten how to do post properly, I have no idea where to even look for the issues. Anyone have any ideas?
        • 1. Re: Media Encoder "Failed" on almost every video
          Peru Bob Adobe Community Professional & MVP
          Try updating or rolling back your video driver directly from the card manufacturer's site.
          • 2. Re: Media Encoder "Failed" on almost every video
            I updated the driver, but that didn't make any difference. It fails so often, that AME has become completely un-usable. I now have to render everything from Premiere which means I can batch render anymore. I have to do one at a time, and that also means I can't edit anything else when I render or render over night.
            Expected more from an Adobe product. This is a bit of a show-stopper. I'm actually going to have to look for another editing solution, and that's not where I wanted to be. Disappointed that no one from Adobe has chimed in either.
            • 3. Re: Media Encoder "Failed" on almost every video
              Michael L at UNCP Level 1
              Let's take a look at the log file.
              Open Media Encoder  click File > Show logs.
              Scroll down to the bottom and post a screen cap of the last screen or page of the log.
              • 4. Re: Media Encoder "Failed" on almost every video
                • 5. Re: Media Encoder "Failed" on almost every video
                  You're right. It looks like your last two exported without error. Can you cut and paste the entire file? I'm looking for information on the encodings that failed.  I was hoping the last few might shed some light. Let's look at it all.
                  • 6. Re: Media Encoder "Failed" on almost every video
                    Here's what's there. Note that only the one above the last one rendered. That came from After Effects. The one above that which was Premiere also failed.
                    Here's the full log - as much as I have. You'll see long stretches of files that were indeed rendered (I was doing a ton of edits for a specific set of projects). The ones that rendered only did so after a restart, but then the next batch would start failing again. Where you see "stopped by user" was typically after the cascade of fails - the log doesn't really tell that story, but FYI as you look through. Also Queue Pauses are interesting. That was NOT me sitting there pausing every few seconds. Anyway, here it is...
                    Log File Created: 10/29/2017 12:18:13 AM
                    10/29/2017 12:18:13 AM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_23.prproj
                    - Output File: C:\Users\The Beast\Desktop\Skylar-Harris-BWC-01-720.mp4
                    - Preset Used: BW-720-60fps
                    - Video: 1280x720 (1.0), 59.94 fps, Progressive, 00;24;22;54
                    - Audio: AAC, 128 kbps, 48 kHz, Stereo
                    - Bitrate: VBR, 2 pass, Target 3.50 Mbps, Max 5.00 Mbps
                    - Encoding Time: 00:50:51
                    10/29/2017 01:09:06 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_24.prproj
                    - Output File: C:\Users\The Beast\Desktop\Skylar-Harris-BWC-01-trailer-1080_1.mp4
                    - Preset Used: BW-1080-60fps
                    - Video: 1920x1080 (1.0), 59.94 fps, Progressive, 00;01;10;00
                    - Bitrate: VBR, 2 pass, Target 4.50 Mbps, Max 7.00 Mbps
                    - Encoding Time: 00:04:03
                    10/29/2017 01:13:10 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_25.prproj
                    - Output File: C:\Users\The Beast\Desktop\Skylar-Harris-BWC-01-1080.mp4
                    - Video: 1920x1080 (1.0), 59.94 fps, Progressive, 00;24;22;54
                    - Encoding Time: 01:00:58
                    10/29/2017 02:14:10 AM : File Successfully Encoded
                    10/29/2017 02:14:10 AM : Queue Stopped
                    10/29/2017 02:36:40 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_26.prproj
                    - Output File: C:\Users\The Beast\Desktop\Skylar-Harris-BWC-bts.mp4
                    - Preset Used: YouTube 2160p 4K
                    - Video: 3840x2160 (1.0), 59.94 fps, Progressive, 00;02;01;28
                    - Audio: AAC, 320 kbps, 48 kHz, Stereo
                    - Bitrate: VBR, 1 pass, Target 40.00 Mbps, Max 40.00 Mbps
                    - Encoding Time: 00:06:39
                    10/29/2017 02:43:19 PM : File Successfully Encoded
                    10/29/2017 02:43:20 PM : Queue Stopped
                    11/01/2017 10:05:12 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\Sampraday-Hockey-Night-2017.prproj
                    - Output File: C:\Users\The Beast\Desktop\Sampradaya-Hockey-Night-Indo-Canada-4K.mp4
                    - Preset Used: Custom
                    - Video: 3840x2160 (1.0), 23.976 fps, Progressive, 00:49:53:22
                    - Bitrate: VBR, 2 pass, Target 5.00 Mbps, Max 7.00 Mbps
                    11/01/2017 10:08:14 PM : Queue Stopped
                    11/01/2017 10:17:18 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\Sampraday-Hockey-Night-2017_2.prproj
                    - Output File: C:\Users\The Beast\Desktop\Sampradaya-Hockey-Night-Indo-Canada-1080HD.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:49:53:22
                    - Bitrate: VBR, 2 pass, Target 3.00 Mbps, Max 6.00 Mbps
                    - Encoding Time: 01:10:03
                    11/01/2017 11:27:22 PM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\Sampraday-Hockey-Night-2017_3.prproj
                    - Output File: C:\Users\The Beast\Desktop\Sampradaya-Hockey-Night-Indo-Canada-4KUHD.mp4
                    - Bitrate: VBR, 2 pass, Target 4.50 Mbps, Max 6.00 Mbps
                    - Encoding Time: 01:59:00
                    11/02/2017 01:26:22 AM : File Successfully Encoded
                    11/02/2017 01:26:23 AM : Queue Stopped
                    11/02/2017 12:40:59 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_27.prproj
                    - Output File: C:\Users\The Beast\Desktop\Skylar-Harris-BWC-01-PG-trailer-4K.mp4
                    - Preset Used: BW-4K-60fps
                    - Video: 3840x2160 (1.0), 59.94 fps, Progressive, 00;01;53;57
                    - Bitrate: VBR, 2 pass, Target 5.00 Mbps, Max 8.00 Mbps
                    11/02/2017 12:43:48 PM : Queue Stopped
                    11/02/2017 11:34:45 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000524.mp4
                    - Preset Used: FT-1080-23.976
                    - Video: 3840x2160 (1.0), 23.976 fps, Progressive, 00:05:55:12
                    - Encoding Time: 00:13:25
                    11/02/2017 11:48:10 PM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_1.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000525.mp4
                    - Video: 3840x2160 (1.0), 23.976 fps, Progressive, 00:02:01:12
                    - Encoding Time: 00:04:40
                    11/02/2017 11:52:51 PM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_2.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000526.mp4
                    - Encoding Time: 00:13:26
                    11/03/2017 12:06:19 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_3.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000527.mp4
                    - Video: 3840x2160 (1.0), 23.976 fps, Progressive, 00:01:56:12
                    - Encoding Time: 00:04:16
                    11/03/2017 12:10:35 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_4.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000528.mp4
                    - Encoding Time: 00:13:04
                    11/03/2017 12:23:40 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_5.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000529.mp4
                    - Video: 3840x2160 (1.0), 23.976 fps, Progressive, 00:05:20:12
                    - Encoding Time: 00:11:18
                    11/03/2017 12:34:59 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_6.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000530.mp4
                    - Encoding Time: 00:12:29
                    11/03/2017 12:47:33 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_7.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000531.mp4
                    - Video: 3840x2160 (1.0), 23.976 fps, Progressive, 00:01:34:12
                    - Encoding Time: 00:03:23
                    11/03/2017 12:50:57 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_8.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000532.mp4
                    - Encoding Time: 00:12:37
                    11/03/2017 01:03:37 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_9.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000533.mp4
                    - Video: 3840x2160 (1.0), 23.976 fps, Progressive, 00:00:50:00
                    - Encoding Time: 00:01:47
                    11/03/2017 01:05:25 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_10.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000534.mp4
                    - Video: 3840x2160 (1.0), 23.976 fps, Progressive, 00:05:56:00
                    - Encoding Time: 00:12:53
                    11/03/2017 01:18:19 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_11.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000535.mp4
                    - Encoding Time: 00:12:51
                    11/03/2017 01:31:13 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_12.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000536.mp4
                    - Encoding Time: 00:12:44
                    11/03/2017 01:44:00 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_13.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000537.mp4
                    - Encoding Time: 00:12:48
                    11/03/2017 01:56:49 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_14.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000538.mp4
                    - Video: 3840x2160 (1.0), 23.976 fps, Progressive, 00:00:25:00
                    - Encoding Time: 00:00:56
                    11/03/2017 01:57:46 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_15.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000539.mp4
                    - Encoding Time: 00:12:52
                    11/03/2017 02:10:39 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_16.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000540.mp4
                    11/03/2017 02:23:28 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_17.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000541.mp4
                    - Encoding Time: 00:12:55
                    11/03/2017 02:36:24 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_18.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000542.mp4
                    - Video: 3840x2160 (1.0), 23.976 fps, Progressive, 00:01:49:12
                    - Encoding Time: 00:03:58
                    11/03/2017 02:40:23 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_19.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000543.mp4
                    - Video: 3840x2160 (1.0), 23.976 fps, Progressive, 00:03:26:00
                    - Encoding Time: 00:07:18
                    11/03/2017 02:47:42 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_20.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000544.mp4
                    - Video: 3840x2160 (1.0), 23.976 fps, Progressive, 00:05:55:00
                    - Encoding Time: 00:12:33
                    11/03/2017 03:00:16 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_21.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000545.mp4
                    - Encoding Time: 00:12:43
                    11/03/2017 03:12:59 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_22.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000546.mp4
                    - Video: 3840x2160 (1.0), 23.976 fps, Progressive, 00:05:01:00
                    - Encoding Time: 00:10:44
                    11/03/2017 03:23:44 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_23.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000547.mp4
                    - Encoding Time: 00:12:35
                    11/03/2017 03:36:20 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_24.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000548.mp4
                    - Encoding Time: 00:12:32
                    11/03/2017 03:48:53 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_25.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000549.mp4
                    - Video: 3840x2160 (1.0), 23.976 fps, Progressive, 00:01:26:00
                    - Encoding Time: 00:03:03
                    11/03/2017 03:51:56 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_26.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000550.mp4
                    11/03/2017 04:04:29 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_27.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\P1000551.mp4
                    - Video: 3840x2160 (1.0), 23.976 fps, Progressive, 00:00:52:12
                    - Encoding Time: 00:01:52
                    11/03/2017 04:06:22 AM : File Successfully Encoded
                    11/03/2017 04:06:22 AM : Queue Stopped
                    11/03/2017 09:06:17 AM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_28.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1251.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:03:36:04
                    - Encoding Time: 00:02:32
                    11/03/2017 09:08:50 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_29.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1250.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:02:59:12
                    - Encoding Time: 00:02:06
                    11/03/2017 09:10:58 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_30.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1248.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:03:56:03
                    - Encoding Time: 00:02:45
                    11/03/2017 09:13:44 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_31.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1247.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:01:55:15
                    - Encoding Time: 00:01:18
                    11/03/2017 09:15:03 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_32.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1245.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:00:35:20
                    - Encoding Time: 00:00:24
                    11/03/2017 09:15:29 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_33.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1244.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:04:21:13
                    11/03/2017 09:18:33 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_34.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1242.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:05:06:00
                    - Encoding Time: 00:03:34
                    11/03/2017 09:22:08 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_35.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1241.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:06:04:03
                    - Audio: AAC, 16 kbps, 48 kHz, Stereo
                    - Encoding Time: 00:04:15
                    11/03/2017 09:26:24 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_36.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1239.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:03:01:20
                    - Encoding Time: 00:02:07
                    11/03/2017 09:28:32 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_37.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1238.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:01:00:03
                    - Encoding Time: 00:00:48
                    11/03/2017 09:29:21 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_38.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1237.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:03:23:14
                    - Encoding Time: 00:02:35
                    11/03/2017 09:31:58 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_39.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1236.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:00:04:17
                    - Encoding Time: 00:00:04
                    11/03/2017 09:32:03 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_40.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1235.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:12:02:00
                    - Encoding Time: 00:08:55
                    11/03/2017 09:40:59 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_41.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1234.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:07:08:10
                    - Encoding Time: 00:05:25
                    11/03/2017 09:46:25 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_42.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1233.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:09:50:19
                    - Encoding Time: 00:07:33
                    11/03/2017 09:53:58 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_43.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1232.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:01:16:16
                    - Encoding Time: 00:00:58
                    11/03/2017 09:54:58 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_44.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1231.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:00:05:20
                    11/03/2017 09:55:03 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_45.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1230.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:06:41:06
                    - Encoding Time: 00:04:51
                    11/03/2017 09:59:54 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_46.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1228.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:06:38:04
                    11/03/2017 10:04:46 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_47.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1227.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:00:08:22
                    - Encoding Time: 00:00:06
                    11/03/2017 10:04:53 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_48.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1226.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:00:14:02
                    - Encoding Time: 00:00:09
                    11/03/2017 10:05:03 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_49.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1225.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:11:25:22
                    - Encoding Time: 00:08:33
                    11/03/2017 10:13:36 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_50.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1224.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:08:01:10
                    - Encoding Time: 00:06:01
                    11/03/2017 10:19:38 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\876-studio-day-1_51.prproj
                    - Output File: N:\Chris-Lesso-876-Studio\Day1-Aug28\down-renders\5D\MVI_1223.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:07:54:00
                    - Encoding Time: 00:05:49
                    11/03/2017 10:25:28 AM : File Successfully Encoded
                    11/03/2017 10:25:28 AM : Queue Stopped
                    11/03/2017 04:19:49 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\Rakkatak-Small-Pieces.prproj
                    - Output File: C:\Users\The Beast\Desktop\Maplewood.mp4
                    - Video: 1920x1080 (1.0), 23.976 fps, Progressive, 00:04:02:05
                    - Encoding Time: 00:03:00
                    11/03/2017 04:22:50 PM : File Successfully Encoded
                    11/03/2017 04:22:51 PM : Queue Stopped
                    11/12/2017 12:22:06 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\HUHS-tubes_2.prproj
                    - Output File: C:\Users\The Beast\Desktop\Ariana-Aimes-01.mp4
                    - Preset Used: HUHS-tube
                    - Video: 1280x720 (1.0), 29.97 fps, Progressive, 00;14;35;15
                    - Bitrate: VBR, 1 pass, Target 3.50 Mbps, Max 8.00 Mbps
                    - Encoding Time: 00:03:13
                    11/12/2017 12:25:19 PM : File Successfully Encoded
                    11/12/2017 12:25:19 PM : Queue Stopped
                    11/12/2017 07:48:01 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_28.prproj
                    - Output File: C:\Users\The Beast\Desktop\Audrey-LaVey-BWC-01-trailer.mp4
                    - Video: 1280x720 (1.0), 59.94 fps, Progressive, 00;01;06;56
                    - Encoding Time: 00:02:52
                    11/12/2017 07:50:56 PM : File Successfully Encoded
                    11/12/2017 07:50:57 PM : Queue Stopped
                    11/12/2017 09:17:02 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_29.prproj
                    - Output File: C:\Users\The Beast\Desktop\Audrey-LaVey-BWC-01-4k.mp4
                    - Video: 3840x2160 (1.0), 59.94 fps, Progressive, 00;19;06;30
                    - Encoding Time: 01:48:13
                    11/12/2017 11:05:17 PM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_30.prproj
                    - Output File: C:\Users\The Beast\Desktop\Audrey-LaVey-BWC-01-1080.mp4
                    - Video: 1920x1080 (1.0), 59.94 fps, Progressive, 00;19;06;30
                    - Encoding Time: 00:49:59
                    11/12/2017 11:55:20 PM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_31.prproj
                    - Output File: C:\Users\The Beast\Desktop\Audrey-LaVey-BWC-01-720.mp4
                    - Video: 1280x720 (1.0), 59.94 fps, Progressive, 00;19;06;30
                    - Encoding Time: 00:38:36
                    11/13/2017 12:33:58 AM : File Successfully Encoded
                    11/13/2017 12:33:58 AM : Queue Stopped
                    11/13/2017 12:31:56 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_32.prproj
                    - Output File: C:\Users\The Beast\Desktop\Audrey-LaVey-BWC-01-trailer-4k.mp4
                    - Video: 3840x2160 (1.0), 59.94 fps, Progressive, 00;01;06;56
                    11/13/2017 12:35:15 PM : Queue Paused
                    11/13/2017 12:35:17 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_33.prproj
                    - Output File: C:\Users\The Beast\Desktop\Audrey-LaVey-BWC-01-trailer-1080.mp4
                    - Video: 1920x1080 (1.0), 59.94 fps, Progressive, 00;01;06;56
                    11/13/2017 12:36:17 PM : Queue Paused
                    11/13/2017 12:36:18 PM : Queue Started
                    11/13/2017 12:37:46 PM : Queue Paused
                    11/13/2017 12:37:48 PM : Queue Started
                    11/13/2017 12:38:16 PM : Queue Paused
                    11/13/2017 12:38:25 PM : Queue Started
                    11/13/2017 12:38:46 PM : Queue Paused
                    11/13/2017 12:38:48 PM : Queue Started
                    11/13/2017 12:38:51 PM : Queue Paused
                    11/13/2017 12:38:53 PM : Queue Started
                    11/13/2017 12:38:56 PM : Queue Paused
                    11/13/2017 12:38:57 PM : Queue Started
                    11/13/2017 12:39:26 PM : Queue Paused
                    11/13/2017 12:39:27 PM : Queue Started
                    11/13/2017 12:39:58 PM : Queue Paused
                    11/13/2017 12:40:00 PM : Queue Stopped
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_34.prproj
                    - Output File: C:\Users\The Beast\Desktop\Audrey-LaVey-BWC-01-trailer-720.mp4
                    - Encoding Time: 00:04:30
                    11/13/2017 12:40:00 PM : Encoding Failed
                    The Operation was interrupted by user
                    11/13/2017 01:21:02 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_35.prproj
                    11/13/2017 01:27:01 PM : Queue Stopped
                    11/13/2017 01:35:13 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_36.prproj
                    - Encoding Time: 00:08:03
                    11/13/2017 01:43:18 PM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_37.prproj
                    - Encoding Time: 00:03:46
                    11/13/2017 01:47:05 PM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_38.prproj
                    - Encoding Time: 00:03:05
                    11/13/2017 01:50:12 PM : File Successfully Encoded
                    11/13/2017 01:50:12 PM : Queue Stopped
                    11/13/2017 03:59:19 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_39.prproj
                    - Output File: C:\Users\The Beast\Desktop\Audrey-LaVey-BWC-01-4-Audrey-1080.mp4
                    - Encoding Time: 00:48:31
                    11/13/2017 04:47:51 PM : File Successfully Encoded
                    11/13/2017 04:47:51 PM : Queue Stopped
                    11/13/2017 05:29:10 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_40.prproj
                    - Output File: C:\Users\The Beast\Desktop\Audrey-LaVey-BWC-01-interview.mp4
                    - Video: 3840x2160 (1.0), 59.94 fps, Progressive, 00;03;10;12
                    - Encoding Time: 00:10:32
                    11/13/2017 05:39:43 PM : File Successfully Encoded
                    11/13/2017 05:39:43 PM : Queue Stopped
                    11/13/2017 07:27:41 PM : Queue Started
                    11/13/2017 07:29:12 PM : Queue Paused
                    11/13/2017 07:29:21 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_41.prproj
                    - Video: 3840x2160 (1.0), 59.94 fps, Progressive, 00;03;17;55
                    11/13/2017 07:29:22 PM : Queue Stopped
                    11/13/2017 07:51:26 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_43.prproj
                    - Output File: C:\Users\The Beast\Desktop\Audrey-LaVey-BWC-01-PG-trailer.mp4
                    - Video: 3840x2160 (1.0), 59.94 fps, Progressive, 00;01;56;23
                    - Encoding Time: 00:07:01
                    11/13/2017 07:58:29 PM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_44.prproj
                    - Encoding Time: 00:11:27
                    11/13/2017 08:09:57 PM : File Successfully Encoded
                    11/13/2017 08:09:58 PM : Queue Stopped
                    11/14/2017 07:30:19 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\HUHS-tubes_3.prproj
                    - Output File: C:\Users\The Beast\Desktop\Trina-Rush-01.mp4
                    - Video: 1280x720 (1.0), 29.97 fps, Progressive, 00;13;02;27
                    - Encoding Time: 00:02:46
                    11/14/2017 07:33:05 PM : File Successfully Encoded
                    11/14/2017 07:33:05 PM : Queue Stopped
                    11/15/2017 12:56:40 PM : Queue Started
                    11/15/2017 12:57:09 PM : Queue Stopped
                    - Encoding Time: 00:00:11
                    11/15/2017 12:57:09 PM : Encoding Failed
                    11/15/2017 12:57:12 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\Sampraday-Hockey-Night-2017_4.prproj
                    - Output File: C:\Users\The Beast\Desktop\Sampradaya-Hockey-Night-Indo-Canada-4k.mp4
                    - Encoding Time: 02:05:29
                    11/15/2017 03:02:41 PM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\Sampraday-Hockey-Night-2017_5.prproj
                    - Output File: C:\Users\The Beast\Desktop\Sampradaya-Hockey-Night-Indo-Canada-1080.mp4
                    - Encoding Time: 01:16:08
                    11/15/2017 04:18:50 PM : File Successfully Encoded
                    11/15/2017 04:18:51 PM : Queue Stopped
                    11/20/2017 08:04:04 PM : Queue Started
                    - Source File: M:\BallWonder\Tubes\BW-video-ads_AME\tmpAEtoAMEProject-PH-channelad-B-315x3001.aep
                    - Output File: M:\BallWonder\Tubes\BW-video-ads_AME\PH-channelad-B-315x300.mp4
                    - Video: 314x300 (1.0), 12 fps, Progressive, 00;00;08;29
                    - Audio:
                    - Bitrate: VBR, 1 pass, Target 1.29 Mbps, Max 8.00 Mbps
                    - Encoding Time: 00:00:03
                    11/20/2017 08:04:07 PM : File Successfully Encoded
                    - Source File: M:\BallWonder\Tubes\BW-video-ads_AME\tmpAEtoAMEProject-RT-video-footer-950x2501.aep
                    - Output File: M:\BallWonder\Tubes\BW-video-ads_AME\RT-video-footer-950x250.mp4
                    - Video: 950x250 (1.0), 12 fps, Progressive, 00;00;08;29
                    - Audio:
                    - Bitrate: VBR, 1 pass, Target 1.22 Mbps, Max 8.00 Mbps
                    11/20/2017 08:04:11 PM : File Successfully Encoded
                    - Source File: M:\BallWonder\Tubes\BW-video-ads_AME\tmpAEtoAMEProject-PH-channelad-A-315x3001.aep
                    - Output File: M:\BallWonder\Tubes\BW-video-ads_AME\PH-channelad-A-315x300.mp4
                    - Encoding Time: 00:00:01
                    11/20/2017 08:04:12 PM : File Successfully Encoded
                    11/20/2017 08:04:13 PM : Queue Stopped
                    11/22/2017 11:59:44 AM : Queue Started
                    - Source File: W:\BRM0013-Azimuth-Olympics-2017\video\23855_SEQ41295172_11-41-09-19_11-41-45-05.MOV
                    - Output File: C:\Users\The Beast\Desktop\23855_SEQ41295172_11-41-09-19_11-41-45-05.mp4
                    - Preset Used: FT-720-29.97-old-scenes
                    - Video: 1280x720 (1.0), 29.97 fps, Upper, 00;00;43;04
                    - Audio: AAC, 128 kbps, 48 kHz, Mono
                    - Encoding Time: 00:00:27
                    11/22/2017 12:00:12 PM : File Successfully Encoded
                    - Source File: W:\BRM0013-Azimuth-Olympics-2017\video\23855_SEQ41295173_10-49-39-19_10-49-51-15.MOV
                    - Output File: C:\Users\The Beast\Desktop\23855_SEQ41295173_10-49-39-19_10-49-51-15.mp4
                    - Video: 1280x720 (1.0), 29.97 fps, Upper, 00;00;14;25
                    11/22/2017 12:00:22 PM : File Successfully Encoded
                    - Source File: W:\BRM0013-Azimuth-Olympics-2017\video\23855_SEQ41295174_11-41-45-05_11-42-12-12.MOV
                    - Output File: C:\Users\The Beast\Desktop\23855_SEQ41295174_11-41-45-05_11-42-12-12.mp4
                    - Video: 1280x720 (1.0), 29.97 fps, Upper, 00;00;33;02
                    - Encoding Time: 00:00:18
                    11/22/2017 12:00:40 PM : File Successfully Encoded
                    11/22/2017 12:00:40 PM : Queue Stopped
                    11/22/2017 02:24:47 PM : Queue Started
                    - Source File: W:\BRM0013-Azimuth-Olympics-2017\video\23855_SEQ41295168_11-40-18-00_11-40-51-08.MOV
                    - Output File: C:\Users\The Beast\Desktop\23855_SEQ41295168_11-40-18-00_11-40-51-08.mp4
                    - Video: 1280x720 (1.0), 29.97 fps, Upper, 00;00;40;08
                    - Encoding Time: 00:00:25
                    11/22/2017 02:25:13 PM : File Successfully Encoded
                    11/22/2017 02:25:14 PM : Queue Stopped
                    11/23/2017 09:06:10 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\HUHS-tubes_4.prproj
                    - Output File: C:\Users\The Beast\Desktop\Kristen-Scott-02.mp4
                    - Video: 1280x720 (1.0), 29.97 fps, Progressive, 00;12;13;12
                    - Encoding Time: 00:02:44
                    11/23/2017 09:08:54 PM : File Successfully Encoded
                    11/23/2017 09:08:55 PM : Queue Stopped
                    11/26/2017 08:07:31 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_45.prproj
                    - Output File: C:\Users\The Beast\Desktop\Emily-Crush-BWC-01-SFW-trailer-720.mp4
                    - Video: 1280x720 (1.0), 59.94 fps, Progressive, 00;02;10;55
                    - Encoding Time: 00:04:25
                    11/26/2017 08:12:00 PM : File Successfully Encoded
                    11/26/2017 08:12:00 PM : Queue Stopped
                    11/27/2017 03:18:17 PM : Queue Started
                    - Source File: W:\BRM0013-Azimuth-Olympics-2017\PG-Olympics-DaraHowell-2017_AME\tmpAEtoAMEProject-PG-Oly mpics-DaraHowell-720x12801.aep
                    - Output File: C:\Users\The Beast\Desktop\PG-Olympics-DaraHowell-rough1.mp4
                    - Video: 774x966 (1.0), 23.976 fps, Progressive, 00:00:08:00
                    - Bitrate: VBR, 2 pass, Target 5.04 Mbps, Max 7.23 Mbps
                    11/27/2017 03:18:27 PM : File Successfully Encoded
                    11/27/2017 03:18:27 PM : Queue Stopped
                    11/27/2017 06:43:41 PM : Queue Started
                    - Source File: W:\BRM0013-Azimuth-Olympics-2017\PG-Olympics-DaraHowell-2017_AME\tmpAEtoAMEProject-PG-Oly mpics-DaraHowell-alt1.aep
                    - Output File: C:\Users\The Beast\Desktop\PG-Olympics-DaraHowell-alt.mp4
                    - Bitrate: VBR, 2 pass, Target 5.00 Mbps, Max 5.00 Mbps
                    11/27/2017 06:43:53 PM : File Successfully Encoded
                    11/27/2017 06:43:53 PM : Queue Stopped
                    11/27/2017 08:57:03 PM : Queue Started
                    11/27/2017 09:14:27 PM : Queue Paused
                    11/27/2017 09:14:29 PM : Queue Started
                    11/27/2017 09:14:30 PM : Queue Paused
                    11/27/2017 09:14:32 PM : Queue Started
                    11/27/2017 09:15:39 PM : Queue Paused
                    11/27/2017 09:15:41 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_46.prproj
                    - Output File: C:\Users\The Beast\Desktop\Emily-Crush-BWC-01-4k.mp4
                    - Video: 3840x2160 (1.0), 59.94 fps, Progressive, 00;26;32;58
                    11/27/2017 09:15:58 PM : Queue Stopped
                    11/27/2017 09:32:27 PM : Queue Started
                    11/27/2017 09:33:09 PM : Queue Paused
                    11/27/2017 09:33:11 PM : Queue Started
                    11/27/2017 09:33:42 PM : Queue Paused
                    11/27/2017 09:33:43 PM : Queue Started
                    11/27/2017 09:34:09 PM : Queue Paused
                    11/27/2017 09:34:10 PM : Queue Started
                    11/27/2017 09:35:17 PM : Queue Paused
                    11/27/2017 09:35:19 PM : Queue Started
                    11/27/2017 09:35:40 PM : Queue Paused
                    11/27/2017 09:35:41 PM : Queue Started
                    11/27/2017 09:36:06 PM : Queue Paused
                    11/27/2017 09:36:12 PM : Queue Started
                    11/27/2017 09:37:03 PM : Queue Paused
                    11/27/2017 09:37:05 PM : Queue Started
                    11/27/2017 09:38:53 PM : Queue Paused
                    11/27/2017 09:39:01 PM : Queue Started
                    11/27/2017 09:39:08 PM : Queue Paused
                    11/27/2017 09:39:10 PM : Queue Started
                    11/27/2017 09:39:12 PM : Queue Paused
                    11/27/2017 09:39:29 PM : Queue Started
                    11/27/2017 09:39:49 PM : Queue Paused
                    11/27/2017 09:39:51 PM : Queue Started
                    11/27/2017 09:40:52 PM : Queue Paused
                    11/27/2017 09:40:55 PM : Queue Started
                    11/27/2017 09:41:10 PM : Queue Paused
                    11/27/2017 09:41:12 PM : Queue Started
                    11/27/2017 09:41:13 PM : Queue Paused
                    11/27/2017 09:41:15 PM : Queue Started
                    11/27/2017 09:42:28 PM : Queue Paused
                    11/27/2017 09:42:37 PM : Queue Started
                    11/27/2017 09:42:59 PM : Queue Paused
                    11/27/2017 09:43:02 PM : Queue Started
                    11/27/2017 09:43:04 PM : Queue Paused
                    11/27/2017 09:43:07 PM : Queue Started
                    11/27/2017 09:43:16 PM : Queue Paused
                    11/27/2017 09:43:19 PM : Queue Started
                    11/27/2017 09:43:20 PM : Queue Paused
                    11/27/2017 09:43:27 PM : Queue Started
                    11/27/2017 09:43:28 PM : Queue Paused
                    11/27/2017 09:43:32 PM : Queue Started
                    11/27/2017 09:43:33 PM : Queue Paused
                    11/27/2017 09:43:37 PM : Queue Started
                    11/27/2017 09:43:57 PM : Queue Paused
                    11/27/2017 09:43:59 PM : Queue Started
                    11/27/2017 09:44:40 PM : Queue Paused
                    11/27/2017 09:44:42 PM : Queue Started
                    11/27/2017 09:44:57 PM : Queue Paused
                    11/27/2017 09:44:59 PM : Queue Started
                    11/27/2017 09:45:00 PM : Queue Paused
                    11/27/2017 09:45:03 PM : Queue Started
                    11/27/2017 09:45:04 PM : Queue Paused
                    11/27/2017 09:45:06 PM : Queue Started
                    11/27/2017 09:45:58 PM : Queue Paused
                    11/27/2017 09:46:01 PM : Queue Started
                    11/27/2017 09:46:55 PM : Queue Paused
                    11/27/2017 09:46:58 PM : Queue Started
                    11/27/2017 09:47:00 PM : Queue Paused
                    11/27/2017 09:47:03 PM : Queue Started
                    11/27/2017 09:47:30 PM : Queue Paused
                    11/27/2017 09:47:32 PM : Queue Started
                    11/27/2017 09:48:57 PM : Queue Paused
                    11/27/2017 09:48:58 PM : Queue Started
                    11/27/2017 09:49:37 PM : Queue Paused
                    11/27/2017 09:49:39 PM : Queue Started
                    11/27/2017 09:49:56 PM : Queue Paused
                    11/27/2017 09:49:57 PM : Queue Started
                    11/27/2017 09:50:03 PM : Queue Paused
                    11/27/2017 09:50:06 PM : Queue Started
                    11/27/2017 09:50:07 PM : Queue Paused
                    11/27/2017 09:50:08 PM : Queue Started
                    11/27/2017 09:50:31 PM : Queue Paused
                    11/27/2017 09:50:32 PM : Queue Started
                    11/27/2017 09:51:11 PM : Queue Paused
                    11/27/2017 09:51:12 PM : Queue Started
                    11/27/2017 09:51:58 PM : Queue Paused
                    11/27/2017 09:52:01 PM : Queue Started
                    11/27/2017 09:52:05 PM : Queue Paused
                    11/27/2017 09:52:09 PM : Queue Started
                    11/27/2017 09:52:32 PM : Queue Paused
                    11/27/2017 09:52:33 PM : Queue Started
                    11/27/2017 09:52:40 PM : Queue Paused
                    11/27/2017 09:52:41 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_47.prproj
                    11/27/2017 10:05:33 PM : Queue Stopped
                    11/27/2017 10:12:54 PM : Queue Started
                    11/27/2017 10:16:09 PM : Queue Paused
                    11/27/2017 10:16:11 PM : Queue Started
                    11/27/2017 10:16:36 PM : Queue Paused
                    11/27/2017 10:16:50 PM : Queue Started
                    11/27/2017 10:17:43 PM : Queue Paused
                    11/27/2017 10:17:48 PM : Queue Started
                    11/27/2017 10:18:21 PM : Queue Paused
                    11/27/2017 10:18:23 PM : Queue Started
                    11/27/2017 10:18:28 PM : Queue Paused
                    11/27/2017 10:18:30 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_48.prproj
                    11/27/2017 10:18:58 PM : Queue Paused
                    11/27/2017 10:19:05 PM : Queue Started
                    11/27/2017 10:19:10 PM : Queue Paused
                    11/27/2017 10:19:11 PM : Queue Started
                    11/27/2017 10:19:12 PM : Queue Paused
                    11/27/2017 10:19:13 PM : Queue Started
                    11/27/2017 10:19:14 PM : Queue Paused
                    11/27/2017 10:19:16 PM : Queue Started
                    11/27/2017 10:19:22 PM : Queue Paused
                    11/27/2017 10:19:26 PM : Queue Started
                    11/27/2017 10:19:50 PM : Queue Paused
                    11/27/2017 10:19:54 PM : Queue Started
                    11/27/2017 10:19:55 PM : Queue Paused
                    11/27/2017 10:19:56 PM : Queue Started
                    11/27/2017 10:20:31 PM : Queue Paused
                    11/27/2017 10:20:32 PM : Queue Started
                    11/27/2017 10:21:11 PM : Queue Paused
                    11/27/2017 10:21:13 PM : Queue Started
                    11/27/2017 10:21:21 PM : Queue Paused
                    11/27/2017 10:21:27 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_49.prproj
                    - Output File: C:\Users\The Beast\Desktop\Emily-Crush-BWC-01-1080.mp4
                    - Video: 1920x1080 (1.0), 59.94 fps, Progressive, 00;26;32;58
                    11/27/2017 10:22:31 PM : Queue Paused
                    11/27/2017 10:22:33 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_50.prproj
                    - Output File: C:\Users\The Beast\Desktop\Emily-Crush-BWC-01-720.mp4
                    - Video: 1280x720 (1.0), 59.94 fps, Progressive, 00;26;32;58
                    11/27/2017 10:22:35 PM : Queue Stopped
                    11/27/2017 11:03:51 PM : Queue Started
                    11/27/2017 11:04:10 PM : Queue Stopped
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_51.prproj
                    - Output File: C:\Users\The Beast\Desktop\Emily-Crush-BWC-01-trailer-4k.mp4
                    - Video: 3840x2160 (1.0), 59.94 fps, Progressive, 00;01;20;48
                    11/27/2017 11:04:10 PM : Encoding Failed
                    11/27/2017 11:04:23 PM : Queue Started
                    11/27/2017 11:04:33 PM : Queue Stopped
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_52.prproj
                    - Output File: C:\Users\The Beast\Desktop\Emily-Crush-BWC-01-trailer-1080.mp4
                    - Video: 1920x1080 (1.0), 59.94 fps, Progressive, 00;01;20;48
                    11/27/2017 11:04:33 PM : Encoding Failed
                    11/27/2017 11:09:48 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_57.prproj
                    - Encoding Time: 00:08:15
                    11/27/2017 11:18:04 PM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_58.prproj
                    - Encoding Time: 00:04:08
                    11/27/2017 11:22:13 PM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_59.prproj
                    - Output File: C:\Users\The Beast\Desktop\Emily-Crush-BWC-01-trailer-720.mp4
                    - Video: 1280x720 (1.0), 59.94 fps, Progressive, 00;01;20;48
                    - Encoding Time: 00:03:19
                    11/27/2017 11:25:34 PM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_60.prproj
                    - Encoding Time: 02:17:04
                    11/28/2017 01:42:41 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_61.prproj
                    - Encoding Time: 01:05:17
                    11/28/2017 02:48:03 AM : File Successfully Encoded
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_62.prproj
                    - Encoding Time: 00:52:14
                    11/28/2017 03:40:22 AM : File Successfully Encoded
                    11/28/2017 03:40:23 AM : Queue Stopped
                    11/28/2017 08:57:39 AM : Queue Started
                    - Source File: W:\BRM0013-Azimuth-Olympics-2017\PG-Olympics-DaraHowell-2017_AME\tmpAEtoAMEProject-PG-Oly mpics-DaraHowell-alt-21.aep
                    - Output File: C:\Users\The Beast\Desktop\PG-Olympics-DaraHowell-alt-2.mp4
                    - Encoding Time: 00:00:12
                    11/28/2017 08:57:51 AM : File Successfully Encoded
                    11/28/2017 08:57:51 AM : Queue Stopped
                    11/28/2017 02:13:38 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_63.prproj
                    - Output File: C:\Users\The Beast\Desktop\Skylar-Harris-BWC-01-tube.mp4
                    - Preset Used: BWC-tube
                    - Video: 1280x720 (1.0), 23.976 fps, Progressive, 00:11:45:20
                    - Encoding Time: 00:09:08
                    11/28/2017 02:22:48 PM : File Successfully Encoded
                    11/28/2017 02:22:48 PM : Queue Stopped
                    11/28/2017 03:48:01 PM : Queue Started
                    - Source File: W:\BRM0013-Azimuth-Olympics-2017\PG-Olympics-DaraHowell-2017_AME\tmpAEtoAMEProject-PG-Oly mpics-DaraHowell-alt-32.aep
                    - Output File: W:\BRM0013-Azimuth-Olympics-2017\PG-Olympics-DaraHowell-2017_AME\PG-Olympics-DaraHowell-a lt-3.mp4
                    - Video: 800x1000 (1.0), 23.976 fps, Progressive, 00:00:13:00
                    11/28/2017 03:48:14 PM : File Successfully Encoded
                    11/28/2017 03:48:14 PM : Queue Stopped
                    11/29/2017 10:11:49 AM : Queue Started
                    - Source File: W:\BRM0013-Azimuth-Olympics-2017\PG-Olympics-DaraHowell-2017_AME\tmpAEtoAMEProject-PG-Oly mpics-DaraHowell-alt-35.aep
                    - Output File: C:\Users\The Beast\Desktop\PG-Olympics-DaraHowell-alt-3.mp4
                    - Encoding Time: 00:00:07
                    11/29/2017 10:11:57 AM : File Successfully Encoded
                    11/29/2017 10:11:57 AM : Queue Stopped
                    11/29/2017 02:39:34 PM : Queue Started
                    - Source File: W:\BRM0013-Azimuth-Olympics-2017\PG-Olympics-DaraHowell-2017_AME\tmpAEtoAMEProject-PG-Oly mpics-DaraHowell-alt41.aep
                    - Output File: C:\Users\The Beast\Desktop\PG-Olympics-DaraHowell-alt4.mp4
                    - Video: 800x1000 (1.0), 23.976 fps, Progressive, 00:00:08:00
                    - Encoding Time: 00:00:05
                    11/29/2017 02:39:39 PM : File Successfully Encoded
                    11/29/2017 02:39:39 PM : Queue Stopped
                    11/29/2017 04:38:51 PM : Queue Started
                    - Source File: W:\BRM0013-Azimuth-Olympics-2017\PG-Olympics-DaraHowell-2017_AME\tmpAEtoAMEProject-PG-Oly mpics-DaraHowell-alt42.aep
                    - Output File: C:\Users\The Beast\Desktop\PG-Olympics-DaraHowell-alt4_1.mp4
                    11/29/2017 04:38:56 PM : File Successfully Encoded
                    11/29/2017 04:38:56 PM : Queue Stopped
                    11/30/2017 09:52:15 PM : Queue Started
                    - Source File: C:\Users\THEBEA~1\AppData\Local\Temp\BWC-Vol1_64.prproj
                    - Output File: C:\Users\The Beast\Desktop\Emily-Crush-BWC-01-for-Emily-1080.mp4
                    11/30/2017 09:53:59 PM : Queue Stopped
                    • 7. Re: Media Encoder "Failed" on almost every video
                      I believe ME will pause rendering if something of a higher priority needs the render engine.  For example, if ME is rendering a queue of files while I'm editing in Premiere, ME will pause when Pr needs to render something and then resume the queue when Pr's render is finished.
                      What I find puzzling is that there is nothing in the log about files failing to render except when you've chosen to stop them.  I've had some render issues and I can usually see a problem reflected in the log files.
                      Let's look in another place and, I apologize, I probably should have started here ...
                      Open Media Encoder  click File > Show Errors.
                      What can we find in there?
                      • 8. Re: Media Encoder "Failed" on almost every video
                        Ha - don't apologize for taking time to help someone. I appreciate it. The behaviour is certainly weird. Here's what's in the error logs.
                        - Encoding Time: 00:03:01
                        11/01/2017 10:08:14 PM : Encoding Failed
                        Export Error
                        Error compiling movie.
                        GPU Render Error
                        Unable to process frame.
                        Writing with exporter: H.264
                        Writing to file: \\?\C:\Users\The Beast\Desktop\Sampradaya-Hockey-Night-Indo-Canada-4K.mp4
                        Writing file type: H264
                        Around timecode: 00:00:28:15 - 00:00:28:20
                        Rendering effect: AE.ADBE Lumetri
                        Rendering at offset: 28.362 seconds
                        Component: EffectFilter of type GPUVideoFilter
                        Selector: 9
                        Error code: -1609629695
                        11/02/2017 12:43:48 PM : Encoding Failed
                        Export Error
                        Render Error
                        Render returned error.
                        Writing to file: \\?\C:\Users\The Beast\Desktop\Skylar-Harris-BWC-01-PG-trailer-4K.mp4
                        Around timecode: 00;00;46;37 - 00;00;46;43
                        Rendering at offset: 46.580 seconds
                        Component: H.264 of type Exporter
                        Selector: 9
                        - Encoding Time: 00:01:08
                        11/13/2017 12:33:05 PM : Encoding Failed
                        Export Error
                        Render Error
                        Writing to file: \\?\C:\Users\The Beast\Desktop\Audrey-LaVey-BWC-01-trailer-4k.mp4
                        Around timecode: 00;00;13;14 - 00;00;13;23
                        Rendering at offset: 13.247 seconds
                        Selector: 9
                        - Encoding Time: 00:02:23
                        11/13/2017 12:35:29 PM : Encoding Failed
                        Export Error
                        Accelerated Renderer Error
                        Unable to produce frame.
                        Writing to file: \\?\C:\Users\The Beast\Desktop\Audrey-LaVey-BWC-01-trailer-1080.mp4
                        Around timecode: 00;00;26;38 - 00;00;27;01
                        Rendering at offset: 26.476 seconds
                        Selector: 9
                        - Encoding Time: 00:05:57
                        11/13/2017 01:27:01 PM : Encoding Failed
                        Export Error
                        Render Error
                        Around timecode: 00;00;24;17 - 00;00;24;24
                        Rendering at offset: 24.241 seconds
                        Selector: 9
                        - Encoding Time: 00:01:40
                        11/13/2017 07:29:22 PM : Encoding Failed
                        Export Error
                        Render Error
                        Writing to file: \\?\C:\Users\The Beast\Desktop\Audrey-LaVey-BWC-01-interview.mp4
                        Around timecode: 00;00;22;31 - 00;00;22;40
                        Rendering at offset: 22.539 seconds
                        Selector: 9
                        - Encoding Time: 00:18:52
                        11/27/2017 09:15:57 PM : Encoding Failed
                        Export Error
                        Render Error
                        Writing to file: \\?\C:\Users\The Beast\Desktop\Emily-Crush-BWC-01-4k.mp4
                        Around timecode: 00;07;27;32 - 00;07;27;41
                        Rendering at offset: 447.514 seconds
                        Selector: 9
                        - Encoding Time: 00:33:05
                        11/27/2017 10:05:33 PM : Encoding Failed
                        Export Error
                        Render Error
                        Around timecode: 00;11;02;44 - 00;11;02;53
                        Rendering at offset: 662.729 seconds
                        Selector: 9
                        - Encoding Time: 00:05:54
                        11/27/2017 10:18:50 PM : Encoding Failed
                        Export Error
                        Render Error
                        Around timecode: 00;01;53;51 - 00;01;53;59
                        Rendering at offset: 113.814 seconds
                        Selector: 9
                        - Encoding Time: 00:03:17
                        11/27/2017 10:22:09 PM : Encoding Failed
                        Export Error
                        Render Error
                        Writing to file: \\?\C:\Users\The Beast\Desktop\Emily-Crush-BWC-01-1080.mp4
                        Around timecode: 00;01;36;24 - 00;01;36;48
                        Rendering at offset: 96.430 seconds
                        Selector: 9
                        11/27/2017 10:22:35 PM : Encoding Failed
                        Export Error
                        Render Error
                        Writing to file: \\?\C:\Users\The Beast\Desktop\Emily-Crush-BWC-01-720.mp4
                        Around timecode: 00;00;17;52 - 00;00;18;16
                        Rendering at offset: 17.885 seconds
                        Selector: 9
                        - Encoding Time: 00:01:43
                        11/30/2017 09:53:59 PM : Encoding Failed
                        Export Error
                        Writing to file: \\?\C:\Users\The Beast\Desktop\Emily-Crush-BWC-01-for-Emily-1080.mp4
                        Around timecode: 00;00;57;29 - 00;00;57;50
                        Rendering at offset: 57.474 seconds
                        Selector: 9
                        • 9. Re: Media Encoder "Failed" on almost every video
                          Additional note: I just saw another thread that suggests the connection might be using Lumetri Color (I use that for basic colour correction and grading) in Premiere. That is indeed common to everything I've rendered that failed.
                          • 10. Re: Media Encoder "Failed" on almost every video
                            I suppose it's possible. I use Lumetri Color on literally everything as well. I love the interface and convenience. I had a problem like this once with a Fade to White effect. For some reason it just wouldn't render. I used the Error log to track it down.  Once I removed that effect from the clip, the sequence rendered.
                            To narrow down yours, you can look at the time code in the errors and see what is going on there.  After a fail, go right to the error code and look at the time and then take a look at what is going on in your sequence at that time that is unique up to that point. For example, if the error is at 5:35 and that is the first time in your sequence that you use a Curves correction, try resetting that or turning it off just for that section and re-render.   If you get the same error at the same time, look to see what else might be unique about that clip.
                              For example, you have an error code that looks like this...
                              Selector: 9
                            I haven't been able to narrow down that error code but there's something going on around 17 seconds and 52 frames in that the encoder doesn't like.  It might be anywhere in the clip that extends from 17;52 to 18;16.
                            I did see one that was listed as an Accelerated Renderer Error. - Unable to produce frame. This might suggest an issue with the graphics card acceleration. You might experiment with turning off GPU acceleration and see if that helps.  It will be much slower but a possible next step in diagnosis.
                            You consistently get this Error code: -1609629695.  Maybe check with tech support and see what that is?
                            • 11. Re: Media Encoder "Failed" on almost every video
                              Found a thread with many people experiencing that particular error code.
                              Error compiling movie error code 1609629695
                              I haven't read it all but have read much of it. There seems to be a pattern of Lumetri + some other effect either on older GPU or a system with GPU driver issues.  For some users, turning off GPU acceleration worked, for others it didn't.  For some, using different color effects (not Lumetri) worked.
                              A few mentioned having problems using large images and fixing it by scaling down the images before importing them. For example, a few had massive .png images (8334x8334) and found that the sequence would render if they used something like photoshop to scale the image to the desired size before importing to Premiere rather than scaling in Premiere.
                              I think I'm at the end of my ability to help.  Best of luck. Hopefully an Adobe rep will chime in with better info.
                              • 12. Re: Media Encoder "Failed" on almost every video
                                Yeah, I tried turning off the acceleration, but it still failed. I keep my drivers up to date, but as it has been pointed out in other threads, that's not necessarily a good strategy with Adobe products. I did google that error, and just got some deep looking Windows references, not a specific Adobe mention. I'll take a closer look.
                                I'll go to that clip you highlighted and see if I can find something in the sequence that's conspicuous.
                                • 13. Re: Media Encoder "Failed" on almost every video
                                  HA - I just checked the timeline and at exactly 17 seconds, 52 frames... hello Lumetri color. Balls.
                                  • 14. Re: Media Encoder "Failed" on almost every video
                                    That's not good.
                                    Well... at least the Obsolete color tools are still there under Video Effects > Obsolete.  They'll work, I think, even if they're not preferred.  Come back to Lumetri when your video drivers or Premiere has the next update?
                                    • 15. Re: Media Encoder "Failed" on almost every video
                                      Kevin-Monahan Adobe Employee
                                      Hi ShawnBarry of Toronto,
                                      Sorry for these errors. You have not mentioned much about your computer, OS, system, GPU, or your media. Looks like you've got a PC. What about your GPU? Have you tried smart rendering any GPU centric footage? IOW, try to use previews in the rendering process?
                                      Kevin
                                      • 16. Re: Media Encoder "Failed" on almost every video
                                        MrAbarbanel
                                        I've been dealing with this problem very recently.  If you are using any effects that may be where the problem lies.  I was able to resolve this issue by removing my effects and then rendering.  Because I'm on a timeline I wasn't able to identify the corrupt effect.  Try rendering your project with the layers and everything but leave out the effects.  If it renders, then start adding the effects you want and begin rendering.  It is a time consuming process but i just may work to identify exactly what is causing the failure.
