I am trying to change the lineweight using loops so that vectors in each layer is subsequently thinner by a certain amount. Here is a sample of the code that I am working with. Here, I am prompting the user to input a starting lineweight, and then using that for the first layer, and the subsequent layers are multiplied by a factor of 0.125.
So far, it only iterates it twice (there are more than two layers), but all the lineweights are all same value.
var vectors = doc.pathItems;
while (isNaN(stroke) == true) {
var stroke = Number(prompt(doc.layers.name, "Enter lineweight: "));
for (var j = 0; j < vectors.length; j++) {
vectors
vectors
vectors
Here is what I ended up doing:
#target illustrator
function main() {
if (app.documents.length > 0) {
var doc = app.activeDocument;
var stroke = undefined;
var vectors = undefined;
var totalLayers = doc.layers.length;
stroke = Number(prompt('Enter a numeric lineweight:', "1"));
for (var i = 0; i < totalLayers; i++) {
vectors = doc.layers.pathItems;vectors = doc.layers.pathItems;
...Copy link to clipboard
Maybe try asking in the scripting forum
you're assigning the same value to all pathItems,
stroke * 0.125
you have to decrease the value of stroke on each pass.
stroke -= 0.125 (same as stroke = stroke - 0.125)
var stroke = Number(prompt('Prompt', "Enter lineweight: "));
vectors[0].strokeWidth = stroke; // starting line weight
for (var j = 1; j < vectors.length; j++) {
//vectors
.selected = false; //vectors
.fillColor = replaceColor; vectors
.strokeWidth = stroke -= 0.125; // 2nd path to last, reduce weight by 0.125 }
I nested this under another loop (for layers), and was hoping one lineweight would apply to all the vectors (pathitems) in each of the layers. What I set up here only loops through few vectors in the first layer:
#target illustrator
function main() {
var totallayers = doc.layers.length;
for (var i = 0; i < totallayers; i++) {
var currentLayer = doc.layers;
// Sets initial layer's lineweight to the entered stroke
doc.layers[0].vectors.strokeWidth = stroke; // starting line weight
currentLayer.vectors
You always are going to doc.layers[0].vectors
I removed it but didn't change anything. Here is what I have now:
#target illustrator
function main() {
vectors
stroke -= 0.125;
main();
Well what is your vectors
Right now your vectors is doc.Path items, so it's doing a loop for every layer on all the document's pathItems, and changes all of them to the new stroke variable.
To fix it, you'll have to change the vectors to something like totalLayers.pathItems.
Thanks! It worked
#target illustrator
function main() {
vectors
stroke *= 0.500;
main();
