Join us for an upcoming in-person Adobe Target Skill Builders event ~~> We're hosting these live learning opportunities to equip you with the knowledge and skills to leverage Target successfully. Learn more to see if we'll be coming to a city near you!
SOLVED
Have Target based on values tracked in Sitecatalyst
Avatar
Level 10
Hello,
Is it possible to target based on data that has been tracked by Sitecatalyst? Would Test and target be able to read values from tracked Sitecatalyst data OOTB?By doing so i could target to a content on the page based on a value tracked.
Appreciate Kind help.
NZ
1 Accepted Solution
Avatar
Correct answer by
Employee
It is possible to target based on data from SiteCatalyst; however, it is limited to success events (passed by s.event). This will show up as "SiteCatalyst:event" and "SiteCatalyst:purchase" in Test&Target. You would need to install the mboxLoadSCPlugin() after you have set all the SC variables on the page code.
Here are two articles that should help to explain this:
http://microsite.omniture.com/t2/help/en_US/tnt/help/#Analytics_to_Target_Integration
http://microsite.omniture.com/t2/help/en_US/tnt/help/#Analytics_to_Target_Integration_to_Track_Analy...
Avatar
Correct answer by
Employee
Avatar
Level 3
AllDayDev​ the help links do not exist.. Could you share new links or any  other help material
Avatar
Employee
ameliaw95025277 Can you suggest what might be the current links to these documentation resources?
Avatar
Employee Advisor
Hi YogitaBist,
You are looking at an old question so those links are dead now unfortunately. Actually, the correct answer is also old. That is for the legacy version of the Analytics & Target integrations. For recently implemenations you should be using the profile and audiences integration method. This is more robust. To target an activity off of Analytics data you can share a segment from Analytics to the Marketing Cloud, then it will automatically show up as an audience with Target. OR you can create an audience in the Audiences Library (Marketing Cloud > Profiles & Audiences > Audience Library). You can define an audience based off of Analytics evars or events.
Create and audience in help will give you the details.
Avatar
Administrator
YogitaBist Here are some additional resources to get you going!
- Documentation: Publish an Analytics audience segment
- Blog post: Share Segments with the Marketing Cloud
- Documentation: Discover and Build Audiences
- Documentation: Personalize Content
Hope this is helpful!
Avatar
Level 3
@ameliaw95025277
Thanks a lot for sharing the documentation i was looking up form them since a while.
