Liquify tool in CC
Feb 05, 2017 Feb 05, 2017
Hoping there is a fix. I've been editing all morning and using liquify on most. No problems, I open up the next photo and all of the sudden liquify is weird. I have all these tools on the left but I can't for the life of me figure out how to get to just normal brush liquify. Any help or advise appreciated!
TIA!
6.8K
Community Expert , Feb 06, 2017 Feb 06, 2017
If a type layer or a shape layer is selected, you must rasterize the layer before proceeding, making the type or shape editable by the Liquify filter. To distort type without rasterizing the type layer, use the Warp options for the Type tool.
  • Select the layer you want to distort. To change only part of the current layer, select that area.
  • Choose Filter > Liquify.
Prerequisite: Enable the graphics processor
As a prerequisite to using Face-aware Liquify functionality, ensure that the graphics processo
Adobe
Guide ,
Menu Filter?
Fenja
You want the Forward Warp Tool.
As a prerequisite to using Face-aware Liquify functionality, ensure that the graphics processor is enabled in your Photoshop preferences.
  1. Choose Edit > Preferences > Performance.
  2. In the Graphics Processor Settings area, select Use Graphics Processor.
  3. Click Advanced Settings. Ensure that Use Graphics Processor To Accelerate Computation is selected.
  4. Click OK.
These settings are enabled by default when you launch Photoshop for the first time. If you have questions regarding GPU usage in Photoshop, consult this document.
Distortion tools
Several tools in the Liquify dialog box distort the brush area when you hold down the mouse button or drag. The distortion is concentrated at the center of the brush area, and the effect intensifies as you hold down the mouse button or repeatedly drag over an area.
Forward Warp tool
Pushes pixels forward as you drag.
Note:Shift-click with the Warp tool, the Push Left tool, or the Mirror tool to create the effect of dragging in a straight line from the previous point you clicked.
Reconstruct tool
Reverses the distortion you’ve already added, as you hold down the mouse button and drag.
Twirl Clockwise tool
Rotates pixels clockwise as you hold down the mouse button or drag. To twirl pixels counterclockwise, hold down Alt (Windows) or Option (Mac OS) as you hold down the mouse button or drag.
Pucker tool
Moves pixels toward the center of the brush area as you hold down the mouse button or drag.
Bloat tool
Moves pixels away from the center of the brush area as you hold down the mouse button or drag.
Push Left tool
Moves pixels to the left when you drag the tool straight up (pixels move to the right if you drag down). You can also drag clockwise around an object to increase its size, or drag counterclockwise to decrease its size. To push pixels right when you drag straight up (or to move pixels left when you drag down), hold down Alt (Windows) or Option (Mac OS) as you drag.
Distortion tool options
In the tool options area of the dialog box, set the following options:
Brush Size
Sets the width of the brush you’ll use to distort the image.
Brush Density
Controls how a brush feathers at the edge. An effect is strongest in the center of the brush and lighter at the edge.
Brush Pressure
Sets the speed at which distortions are made when you drag a tool in the preview image. Using a low brush pressure makes changes occur more slowly, so it’s easier to stop them at exactly the right moment.
Brush Rate
Sets the speed at which distortions are applied when you keep a tool (such as the Twirl tool) stationary in the preview image. The higher the setting, the greater the speed at which distortions are applied.
Stylus Pressure
Uses pressure readings from a stylus tablet. (This option is available only when you are working with a stylus tablet.) When selected, the brush pressure for the tools is the stylus pressure multiplied by the Brush Pressure value.
Dec 04, 2017 Dec 04, 2017
I have Adobe Photoshop CC as the monthly $9.99 option. I do not have the entire liquify selection drop down menu - no froward warp, no liquify, no pucker, etc. Do I have to purchase these tools somewhere or enable them somehow within photoshop?
Need answer ASAP if anyone out there is watching this.
THANKS!
e
Guide ,
Dec 05, 2017 Dec 05, 2017
There isn't a liquify selection dropdown menu. The Liquify filter has a window of its own with a toolbar on the left edge.
Fenja
Nov 30, 2022 Nov 30, 2022
This didn't work
Feb 09, 2024 Feb 09, 2024
Carmenm, I've got the same problem.  Highly disappointed in Adobe.  I've spent half a day reading all the different so-called solutions to the problem from the "Community Experts", who all seem to have a different solution to the problem, and NONE OF THEM PRODUCES RESULTS!  As much as Adobe charges to use this software, you would think they'd have this issue resolved.  When you try to "talk" to tech support, you can't, you have to text with someone half way around the world and then you have the language barrier.  Adobe's tech support has NOTHING on Apple's support.  Apple  support won't let you leave/end the "conversation" until your issue is resolved.
