This has started happening suddenly and with no change to any settings or root files.
When I go to > Save for Web and I scroll over anything that offers an information support box (the little yellow boxes) then this message comes up immediately and then doesn't disappear - making saving for the web impossible. I've tried redownloading and installing Adobe Photoshop CS6 (as this is - from the CS6 Master Collection) and still now joy. Any ideas of what I can do or even what the problem is?
Yes you can turn off the Tool Tips in Photoshop>Preferences>Interface, uncheck Show Tool Tips and then restart photoshop.
Must be a bug or glitch in macOS High Sierra.
Try resetting your Photoshop preferences and photoshop tools on your mac..
Thank you so much for your suggestion JJMack. Have just reset all tools, deleted all warning dialogs in the preferences and then deleted the setting files on loading PS and sadly that hasn't changed the annoying boxes!! Any other ideas?
When this problem started what changed around that time you started having this problem? Something must have changed. to consistently work a different way. Its not a random occurrence thing.
Yes I've been racking my brains trying to think. I run a website and only use PS to reduce file sizes. So I went through my normal routine. The only think I can think of is that before it started I did do about 5-6 images rather than the normal 2-3 but I didn't change any settings, change any tools around, adjust new settings or preferences that I normally don't mettle with or anything else. I do see, and agree, with what you're saying but sadly cannot think of anything that I have done - something that is continually frustrating me!
Have just tried a full uninstall of Photoshop, redownloaded the CS6 file and fully reloaded it and it's still happening!!! How frustrating!
Solved. Thank you so much. Sadly doesn't solve the overall problem but I agree - may be a problem with OS HS. Never mind. I don't really need the tool tips often anyway so this does solve it for me.
Thanks for the help guys!
See if applying the macOS 10.13.2 High Sierra update solves the Tool Tip issue.
It seems to have on this macbook pro.
Great idea.
Sadly not but I think I'll look to see if future updates sort it out.
S.
