Hello
Is there a way (script ?) to keep Illustrator CS6 slice names and use them as the Artboards names (needed to save as SVG ) ?
1) The slice name (I use it to Export for the Web into PNG)
2) I need the Slice name on Artboard name too, to use for saving into SVG
The only info I found is to rename each Artboards one by one... but I have so many icons, already named correctly with the Slices...
You can compare the center point of the slice to the artboards, then when you find a match, you can apply the name of the given slice to the matching artboard.
Hi, sounds easy... but I can't write code, I design only
I can pay a little for a script, or send something from a website wishlist... someone interested ?
I checked the PDF from Adobe http://wwwimages.adobe.com/content/dam/acom/en/devnet/illustrator/pdf/Illustrator-Scripting-Referenc... , it seems there's nothing to get a Slice name... there's no Slice Object. I hope I'm wrong....
