When I 'Add a Text Comment' from the Annotations toolbar then click somewhere else in the document the comment is not visible.
The text colour is set to black. I can re-click on the text box and highlight the text however when I again click somewhere else in the document it becomes invisible again.
Hello nialld13195649
Sorry for the delay in response to your query and apologize for the inconvenience caused. Please check for any pending updates of Acrobat from Help menu>Check for updates.
You may also refer and try the steps from the following KB docs which discusses the similar issue and scenarios: How can I unlock the Add text comment tool properties in Acrobat XI if the lock check is on but grey...
https://answers.acrobatusers.com/my-comments-are-not-showing-q182211.aspx
You may also refer to Use annotation and drawing markup tools to add comments in PDFs, Adobe Acrobat and Acrobat Reader
Hope this helps, and let us know how it goes.
Anand Sri.
I have the same problem. It started today, but previously everything was fine. There are no fixes on the community forum. I don't understand why we can't get help and support.
Hello pamelab57888250
We apologize for the inconvenience caused, Check for any pending updates of Acrobat or Reader from Help menu>Check for updates, ​and please try the steps mentioned in the following KB docs and let us know how it goes.
my comments are not showing (Edit PDF)
How can I unlock the Add text comment tool properties in Acrobat XI if the lock check is on but gr... Link: https://forums.adobe.com/thread/1637086
Anand Sri.
My Acrobat is on the latest version, no Updates available, yet this still happens.
It worked 5 minutes ago and then stopped working out of nowhere. Very frustrating.
I have exactly the same issue too. When you are editing the text comment, the text is normally-visible. Once you finish editing, move your mouse and click somewhere else, the comment text becomes almost invisible (you barely see the text) immediately. I am using the most updated version of Adobe Acrobat Pro DC.
Same problem for me...
Did you find any solution for this problem ?
