Is is possible to make a photo legend like the one below in Adobe Elements?
Message was edited by: Moderator (Discussion successfully moved from Adobe Digital Classroom: Discussion Forum to Photoshop Elements)
Let us divide the problem in several parts:
- creating the list of people with the 6 colums: I would use a text editor like Word. The result can be pasted later on the upper part of a canvas, the bottom will receive the drawing.
- Creating the 'silhouettes' (contours) for the persons in the group. I can't see a way to do that automatically. If you don't redraw manually, you can perhaps create a 'contour' effect from the various filters available in Elements.
- Adding the numbers... each number on its own text layer; possible to merge layers by smaller batches to avoid 200 layers.
I have done such group images (under 50 persons).
If you really have nearly 200 persons, that's really a big job!
Thank you for the advice. I don't have that many, it was just an example I found online. I will try using the filters.
