Is There anything like Automatic Displacement Maps? Is there a way (or there is some other similar filter) to set the displace filter to main file. So when i change the location of my files it will still works.
Thank you!
Not that I know, though somewhere out there a better dispalcment plug-in may exist.
Mylenium
If by "Set to main file" you mean you are storing your displacement maps in the file you are working on, you could somehow get the path and filename of the doc into the clipboard (maybe via a script), you could then paste this into the file location in the Displace dialog.
