Tooltip as3 explaination
Dec 05, 2017 Dec 05, 2017
Hye guys,
I currently want to learn how to make tooltip via as3.
Hoping you guys can help me to explain what the code function in the code;
import fl.transitions.easing.*;
import fl.transitions.*;
mc.addEventListener("mouseOver", mouseRollOver);
mc.addEventListener("mouseOut", mouseRollOut);
mc.addEventListener("mouseMove", mouseMove1);
var tooltip:Tooltip = new Tooltip();
tooltip.txt.text = "This is a tooltip";
tooltip.x = stage.mouseX;
tooltip.y = stage.mouseY - mc.height;
function mouseRollOver(e:MouseEvent):void {
    addChild(tooltip);
    var myTween:Tween = new Tween(tooltip, "alpha", Regular.easeIn, 0, 1, 0.5, true);
function mouseRollOut(e:MouseEvent):void {
    removeChild(tooltip);
function mouseMove1(e:MouseEvent):void {
Thank you
cc: RandomlyFish​, just.emma​,
485
do you have a Tooltip class?  (just  movieclip with a textfield (named txt) is sufficient.)
is that your code?
Yes I have create a Movie Clip with instance & class named "Tooltip" with empty Dynamic Text in it.
This is not my own code, i just copied & pasted from a tutorial (i forgot where).
But I have no idea the function of the code & need someone to help me to explain it so later I can made my own.
and I want make a multi tooltip.
Thanks.
Dec 06, 2017 Dec 06, 2017
iezqandarzulqarnaen
mc.addEventListener("mouseOver", mouseRollOver);  // adding mouseevent listeners
mc.addEventListener("mouseOut", mouseRollOut);  //   ""   ""
mc.addEventListener("mouseMove", mouseMove1);  //  ""  ""
var tooltip:Tooltip = new Tooltip();  // create a new Tooltip instance
tooltip.txt.text = "This is a tooltip";  // assign the help text
tooltip.x = stage.mouseX;  // assign position
tooltip.y = stage.mouseY - mc.height;  //  ""   ""
    addChild(tooltip);  // add to the display when mc is rolledover
    var myTween:Tween = new Tween(tooltip, "alpha", Regular.easeIn, 0, 1, 0.5, true);  // tween its alpha so it fades in
    removeChild(tooltip);  // remove the tooltip on mouse out
    tooltip.x = stage.mouseX;   // move the tooltip when the mouse moves
Dec 07, 2017 Dec 07, 2017
Thanks for the reply @kglad
So if I put it to more changeable view:
<movieClip>.addEventListener("mouseOver", <mouseOver function>);  // adding mouseevent listeners
<movieClip>.addEventListener("mouseOut", <mouseOut function>);  //   ""   ""
<movieClip>.addEventListener("mouseMove", <mouseMove function>);  //  ""  ""
var <instance>:<class>= new <class>();  // create a new instance
<instance>.<dynamicText instance>.text = "This is a tooltip";  // assign the help text
<instance>.x = stage.mouseX;  // assign position
<instance>.y = stage.mouseY - <movieClip>.height;  //  ""   ""
function <mouseOver function>(e:MouseEvent):void {
    addChild(<instance>);  // add to the display when mc is rolledover
    var myTween:Tween = new Tween(<instance>, "alpha", Regular.easeIn, 0, 1, 0.5, true);  // tween its alpha so it fades in
function <mouseOut function>)(e:MouseEvent):void {
    removeChild(<instance>);  // remove the tooltip on mouse out
function <mouseMove function>(e:MouseEvent):void {
    <instance>.x = stage.mouseX;   // move the tooltip when the mouse moves
is this correct?
that's not valid actionscript.  if it's meant to something else, i don't understand it.
Dec 10, 2017 Dec 10, 2017
So sorry,
forget my previous post.
What i need to change if i want to make another tooltip in the same stage.
var tooltip:Tooltip;
var ttObj:Object={};
//call toolTipF and pass whatever displayobject and tooltip string you want
function toolTipF(dobj:DisplayObject,s:String):void{
tooltip = new Tooltip();  // create a new Tooltip instance
tooltip.txt.text = s;  // assign the help text
ttObj.dobj=tooltip;
obj.addEventListener(MouseEvent.MOUSE_OVER,mouseRollOver);
obj.addEventListener(MouseEvent.MOUSE_OUT,mouseRollOut);
tooltip=ttObj.e.currentTarget
    removeChild(ttObj.e.currentTarget);  // remove the tooltip on mouse out
