Hi Everyone
Please let us know how to perform visual compare in Acrobat DC. Because I checked some of the criteria it working fine. But if there is line movement in between the 2 PDF its not showing in the report.
Ganesh.R
Hi Ganesh,
Since their is no textual difference in between two files, so compare shows no difference.
If you wish to see visual difference, then please follow below mentioned steps:
I hope this helps, do let me know if you need more support here.
Adobe Acrobat DC Team
First image is File 1 and Second image is File 2 while comparing these 2 pdf, there is some line difference in second line of the paragraphs but while doing compare in Acrobat DC it not showing.
Hi Ganesh,
Hi Charu
We did not get our expected result, I compare the 2 pdf (check for pdf compare_Visual1, and check for pdf compare_Visual) and compare report for the same. There is a line movement in 3rd paragraphs but it not shown in the compare report.
But if we do in Acrobat 7 for visual compare it will shows the changes. Its is possible to fix it in Acriobat DC
url link for sample file
Rapidshare - Mobile file sharing with self-destruction & auto encryption
Ganesh.R
Hi Ganesh,
Now I have two issues from you.
1. There is some spacing movement in paragraph (something like justification), which is not detected by Compare files. Currently this feature is not supported in Compare Files, we have raised this feature request and forwarded to product management.
2. Showing highlight at wrong position. Looking at the compare result files I can see the issue for sure, will raise another bug with development team regarding this. Please share file1 and file 2 ( if not confidential), it will help us understand and solve the problem.
Hi Charu
Thanks for you response
I already shared the PDF for you in the below link
Now I am sharing the indesign application link
Regards
Ganesh.R
Hi Ganesh,
Thanks for sharing the files, I created PDFs from InDesign files you shared and compared them (without any crop) using Compare Files. When selecting scanned mode in settings, I get results at expected place, could not reproduce the issue which you mentioned for crop files.
Please share PDFs, cropped as well, so that I can reproduce the issue.
Adobe Acrobat DC
Hi Charu
I used the same application file for creating the 2 pdf. You just create the PDF with crop mark and slug line. Then trim that pdf by removing the crop mark and slug line using crop tool in Acrobat DC and then do the visual compare process.
Ganesh.R
Hi Charu
We are facing some issue in visual compare as listed below
I placed the 2 pdf [Compare Report] Visual1_withcrop, [Compare Report] Visual1withoutcrop.
To remove the slug line in pdf we just crop the pdf to trim size. If we do this process and perform visual compare in Acrobat DC the highlight of pdf compare appear after the 2 lines. Highlight position falls after 2 lines down.
If we do the PDF compare in Acrobat DC without cropping the Slug the highlights shows in the correct position.
There is any possible way to fix this issue.
Ganesh.R
Hi Team
Any update on the above issue, based on you reply only we need to take decision for moving to latest version (Acrobat DC) for PDF compare Process.
Ganesh.R
Hi Ganesh,
I have been trying to reproduce the issue mentioned by you, but could not. It will be very difficult to fix any issue which is not reproducible at our end.
I request you again to please provide me with PDFs - original and cropped (not InDesign files), it will help me immensely to reproduce the issue.
Hi Charu
Thanks for your immediate response
I posted 4 pdf in the below link
http://www.rapidshare.com.cn/eil24Hm
1.Source file Visual.pdf-- PDF file after removing the crop
2.Source file Visual1.pdf -- PDF file after removing the crop
3.[Compare Report] Visual_With crop mark -- If we do the PDF compare it showing the shading of changes in correct position.
4.[Compare Report] Visual1_After removing crop mark -- IF we do the pdf compare after removing the crop mark the shading position are down by 2 lines.
Ganesh.R
Hi Charu
Any Luck on this?
Ganesh.R
Hi Ganesh,
Thanks for sharing files.
Now I can reproduce the issue and have raised it with the relevant team to look into it. Will update you once I have more clarity from development team.
Hi Charu
Good morning, Any update for the above said issue.
Ganesh.R
Hi Charu
Any luck on the above issue
Ganesh.R
Hi Charu
Ganesh.R
Hi Ganesh,
We were able to isolate the issue and are working on the fix, will keep you posted as and when we are ready.
With the latest release of Acrobat on 13th Feb, 2018, this issue has been addressed.
If your product is not already updated, you can manually do so from within the product. Click on the menu Help-> Check for updates.
