Hi All,
Is it possible to apply knockout group for Textframe contents(ie., XXXXX) through scripting?
Succeed by applying knockout for Stroke or PageItems.
//Point 4: Disable overprint for all white text.
var items = app.activeDocument.pageItems;
var myCheck1 = 0;
for (i = 0; i < items.length; i++) {
if (items.typename == 'PathItem') {
//fill color
if (items.fillColor.cyan == 0 && items.fillColor.magenta == 0 && items.fillColor.yellow == 0 && items.fillColor.black == 0)
items.artworkKnockout = KnockoutState.ENABLED;
else if (items.fillColor == "[GrayColor]")
if (items.fillColor.gray == 0)
//stroke color
if (items.strokeColor.cyan == 0 && items.strokeColor.magenta == 0 && items.strokeColor.yellow == 0 && items.strokeColor.black == 0)
else if (items.strokeColor == "[GrayColor]")
if(items.typename == 'TextFrame'){
for ( var j = 0; j < items.textRanges.length; j++ ) {
if (items.textRanges
.fillColor.cyan == 0 && items.textRanges .fillColor.magenta == 0 && items.textRanges .fillColor.yellow == 0 && items.textRanges .fillColor.black == 100){
items.textRanges
.artworkKnockout = KnockoutState.ENABLED; //ERROR or NEED THIS LINE
Regards
Siraj
Hi, BEGINNER_X.
I also couldn't find the property "artworkKnockout" in a TextRange. So I tried using the action.
Silly-V 's great post:
Creating a dynamic action to use with app.doScript() method.
How is this?
...var textFrames = app.activeDocument.textFrames,
actStr = [
"/version 3",
"/name [ 15",
"53616d706c65416374696f6e536574",
"/isOpen 1",
"/actionCount 1",
"/action-1 {",
"/name [ 12",
"53616d706c65416374696f6e",
Hi, BEGINNER_X.
How is this?
actStr = [
"/version 3",
"/name [ 15",
"/isOpen 1",
"/actionCount 1",
"/action-1 {",
"/name [ 12",
"/keyIndex 0",
"/colorIndex 0",
"/isOpen 1",
"/eventCount 1",
"/event-1 {",
"/useRulersIn1stQuadrant 0",
"/internalName (ai_plugin_transparency)",
"/localizedName [ 12",
"5472616e73706172656e6379",
"/isOpen 1",
"/isOn 1",
"/hasDialog 0",
"/parameterCount 1",
"/parameter-1 {",
"/key 1802399587",
"/showInPalette 4294967295",
"/type (enumerated)",
"/name [ 3",
"596573",
"/value 1",
].join("\n"),
actFile = File(Folder.desktop + "/SampleActionSet.aia"),
i,
max;
try {
actFile.open("w");
actFile.write(actStr);
} catch (e) {
alert("Sorry. The file could not be written.");
} finally {
actFile.close();
app.loadAction(actFile);
actFile.remove();
for (i = 0, max = textFrames.length; i < max; i += 1) {
textFrames.textRange.select();
app.doScript("SampleAction", "SampleActionSet");
app.unloadAction("SampleActionSet", "");
Another thing I was not aware of! Per-character knockout group options. Can I ask, what visual effect this will produce for you? I can't envision right now how it would work as my experience with knockout group options is only using it on group items to have one of the group's shapes create a transparent area cut out of the shape behind it.
