[PHOTOSHOP] - Décalage lors de l'exportation
Dec 04, 2017 Dec 04, 2017
Bonjour à toutes et à tous,
Je débute actuellement sur Photoshop et je viens de finir de réaliser mon premier projet. Seulement, lors de l'exportation dudit projet, l'image se retrouve complètement décalée et cela ne ressemble plus du tout à ce que je voyais dans ma zone de travail... Voici ci-dessous des captures d'écran pour que vous puissiez y voir plus clair :
Voilà, je n'y comprend rien, j'espère que vous pourrez m'aider à comprendre l'origine de ce "décalage".
Merci beaucoup.
1.0K
Community Expert , Dec 09, 2017 Dec 09, 2017
Hi Totoremix,
I hope I understood you right:
Try the following way(s) to export.
At first save your file.
  • activate the top level
  • press [Shift]+[Strg]+[Alt]+ at once
  • leftclick while holding [Alt]-key on the eye of this new created Layer (in layers palette)
This new layer will be visible, all other layers are invisible now.
Try the export again.
If the Export fails:
  • select the new created layer (selection --> select all)
  • copy
  • menu --> file --> new (from pasteboard)
  • paste
Have fun
Adobe
Adobe Employee ,
Hi totoremix,
Do you have you have something outside of your canvas, because I think the export panel is trying to pick something that is outside of the canvas.
Please try using the "Crop Tool" and check Delete Cropped Pixels on top, then crop the image a little bit and then try exporting & let us know if it helps.
Sahil
Thanks a lot for your answer, i tried what you suggested but it didn't work, the image is still offbeat..
By the way, the shift is different this time, it's very strange... And sorry for the duplicate post, it's the first time I use this forum. Again thanks a lot, and if you have another idea...
Adobe Employee ,
Did you crop the image?
Dec 05, 2017 Dec 05, 2017
Yes, but it didn't change anything, so I canceled the trimming...
Adobe Employee ,
try cropping the Image then hit enter and then try to export the cropped image.
That's what I did but the result is even more strange :
Moreover, you can see that the character's feet (which I cut in theory) go beyond the blue background which is him well trimmed... I don't get it
Does anyone have another solution ?
Hi Totoremix,
  • copy
  • paste
Have fun
Dec 10, 2017 Dec 10, 2017
Thanks a lot, I just tried the first solution and it worked like a charm !! Again, a big thank you !
Jan 12, 2024 Jan 12, 2024
Bonjour, je ne comprends par la première étape "activate the top level" pouvez-vous joindre une image svp
