Windows 10 Update - Lr & Ps Issues
Engaged ,
Dec 03, 2017 Dec 03, 2017
I seem to be having an issue with Lr & Ps since the latest Windows 10 update that was done on 11/30/17. Everything seems to be lagging when making adjustments. I built a photo editing pc 10 months ago & Lr & Ps worked great. I was breezing through editing like nothing. Anyone have the latest on what's being done? Anything I can do? I hate it when Windows hijacks my pc like this. Has anyone tried deleting any bloatware to see if this corrects the problem and if so which programs? I would hate to delete something that is tied to some operating function of my pc. Any help would be appreciated....Thanks Jerry
1.0K
Community Expert , Dec 09, 2017 Dec 09, 2017
I do not install Lightroom at all. I'm sorry to say I can not add any more info on you problem. Have you tried resetting your Photoshop Settings and tools to see it that helps. Currently I have the latest Windows 10 and all updates install.
I have onle three version of Photoshop Creative cloud installed.  CS6,  CC 2014 which is my preferred version and CC 2018.  All perform w little different from each other.  Some operation behave some what differently and for and operation like transform rotati
Adobe
Hi Jerry
Small consolation I know , but I have LR Classic And Photoshop working fine here with the latest Windows update . So it will work if we can get to the bottom of the problem.
Can you post your system info from Photoshop >Help >System info.
Also if you run the resource monitor from Windows Task Manager - does that show any app or process that is hogging your CPU?
Dave
Engaged ,
Thanks for your help Dave, see screen shots below. I don't see any problem with cpu usage. Below are copies of my Photoshop System Info & my pc build specs. Glad to hear yours is working ok. I have not downloaded any new programs at all that might interfere with running programs. Last email we discussed JPEGmini for reducing file sizes, you mentioned doing it in Lr & it worked great. I uninstalled JPEGmini before the update & all was working fine, then after the update is when it took a dump. So JPEG mini can be ruled out at this point. Maybe I should check and see whats running under programs.
Jerry
Photoshop>Help>System Info:
Adobe Photoshop Version: 19.0 20171103.r.190 2017/11/03: 1143799  x64
Number of Launches: 1801
Operating System: Windows 10 64-bit
Version: 10 or greater 10.0.16299.15
System architecture: Intel CPU Family:6, Model:14, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 4008 MHz
Built-in memory: 32717 MB
Free memory: 16867 MB
Memory available to Photoshop: 29392 MB
Memory used by Photoshop: 60 %
Surface Dial: Enabled.
Alias Layers: Disabled.
Modifier Palette: Enabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=6144
glgpu[0].GLName="NVIDIA GeForce GTX 1060 6GB"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="23.21.13.8813"
glgpu[0].GLRectTextureSize=32768
glgpu[0].GLRenderer="GeForce GTX 1060 6GB/PCIe/SSE2"
glgpu[0].GLRendererID=7171
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nv_ref_pubwu.inf_amd64_2e7fa54192fe16d0\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_ref_pubwu.inf_amd64_2e7fa54192fe16d0\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_ref_pubwu.inf_amd64_2e7fa54192fe16d0\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_ref_pubwu.inf_amd64_2e7fa54192fe16d0\nvldumdx.dll"
glgpu[0].GLDriverDate="20171027000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.60 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2"
clgpu[0].CLDeviceVersion="1.2 CUDA"
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=6144
clgpu[0].CLName="GeForce GTX 1060 6GB"
clgpu[0].CLVendor="NVIDIA Corporation"
clgpu[0].CLVendorID=4318
clgpu[0].CLDriverVersion="388.13"
clgpu[0].CLBandwidth=1.41884e+11
clgpu[0].CLCompute=1685.91
License Type: Subscription
Serial number: 96040479277360417920
GUIDBucket:
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
Temporary file path: C:\Users\JERRYP~1\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
  Startup, 476.4G, 183.6G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
Installed components:
   A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
   ACE.dll   ACE 2017/09/19-18:51:44   79.586793   79.586793
   AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
   AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
   AdobeOwl.dll   Adobe Owl   5.2.11
   AdobePDFL.dll   PDFL 2017/09/01-01:08:01   79.239219   79.239219
   AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
   AdobeSVGAGM.dll   AdobeSVGAGM   79.586793   79.586793
   AdobeXMP.dll   Adobe XMP Core 2017/07/13-01:06:39   79.160924   79.160924
   AdobeXMPFiles.dll   Adobe XMP Files 2017/07/13-01:06:39   79.160924   79.160924
   AdobeXMPScript.dll   Adobe XMP Script 2017/07/13-01:06:39   79.160924   79.160924
   adobe_caps.dll   Adobe CAPS   10,0,0,6
   AGM.dll   AGM 2017/09/19-18:51:44   79.586793   79.586793
   ahclient.dll    AdobeHelp Dynamic Link Library   3.0.0.6
   AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
   amtlib.dll   AMTLib (64 Bit)   10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8)   1.000000
   ARE.dll   ARE 2017/09/19-18:51:44   79.586793   79.586793
   AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
   AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
   Bib.dll   BIB 2017/09/19-18:51:44   79.586793   79.586793
   BIBUtils.dll   BIBUtils 2017/09/19-18:51:44   79.586793   79.586793
   boost_date_time.dll   photoshopdva   11.1.0
   boost_filesystem.dll   photoshopdva   11.1.0
   boost_signals.dll   photoshopdva   11.1.0
   boost_system.dll   photoshopdva   11.1.0
   boost_threads.dll   photoshopdva   11.1.0
   cg.dll   NVIDIA Cg Runtime   3.0.00007
   cgGL.dll   NVIDIA Cg Runtime   3.0.00007
   CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
   CoolType.dll   CoolType 2017/09/19-18:51:44   79.586793   79.586793
   CRClient.dll   Adobe Crash Reporter Client DLL   1.6.1.0
   dnssd.dll   Bonjour   3,0,0,2
   dvaaudiodevice.dll   photoshopdva   11.1.0
   dvacore.dll   photoshopdva   11.1.0
   dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
   dvamarshal.dll   photoshopdva   11.1.0
   dvamediatypes.dll   photoshopdva   11.1.0
   dvametadata.dll   photoshopdva   11.1.0
   dvametadataapi.dll   photoshopdva   11.1.0
   dvametadataui.dll   photoshopdva   11.1.0
   dvaplayer.dll   photoshopdva   11.1.0
   dvatransport.dll   photoshopdva   11.1.0
   dvaui.dll   photoshopdva   11.1.0
   dvaunittesting.dll   photoshopdva   11.1.0
   dynamiclink.dll   photoshopdva   11.1.0
   ExtendScript.dll   ExtendScript 2017/08/31-12:13:14   81.1133690   81.1133690
   icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   igestep30.dll   IGES Reader   9.3.0.113
   imslib.dll   IMSLib DLL   10.0.0.22
   JP2KLib.dll   JP2KLib 2017/08/23-01:11:25   79.267771   79.267771
   libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
   libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
   libmmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
   LogSession.dll   LogSession   7.4.1.60.45263
   mediacoreif.dll   photoshopdva   11.1.0
   MPS.dll   MPS 2017/09/01-01:08:01   79.586120   79.586120
   pdfsettings.dll   Adobe PDFSettings   1.04
   Photoshop.dll   Adobe Photoshop CC 2018   19.0
   Plugin.dll   Adobe Photoshop CC 2018   19.0
   PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   8.0.0
   PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   8.0.0.55
   PSArt.dll   Adobe Photoshop CC 2018   19.0
   PSCloud.dll                                                   1.0.0.1
   PSViews.dll   Adobe Photoshop CC 2018   19.0
   SCCore.dll   ScCore 2017/08/31-12:13:14   81.1133690   81.1133690
   SVGRE.dll   SVGRE   79.586793   79.586793
   svml_dispmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
   tbb.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
   tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
   TfFontMgr.dll   FontMgr   9.3.0.113
   TfKernel.dll   Kernel   9.3.0.113
   TFKGEOM.dll   Kernel Geom   9.3.0.113
   TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
   updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
   VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
   VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
   WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
   wu3d.dll   U3D Writer   9.3.0.113
Required plug-ins:
   3D Studio 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Accented Edges 19.0 - from the file “Filter Gallery.8bf”
   Adaptive Wide Angle 19.0 - from the file “Adaptive Wide Angle.8bf”
   Angled Strokes 19.0 - from the file “Filter Gallery.8bf”
   Average 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Average.8bf”
   Bas Relief 19.0 - from the file “Filter Gallery.8bf”
   BMP 19.0 - from the file “Standard MultiPlugin.8bf”
   Camera Raw 10.0 - from the file “Camera Raw.8bi”
   Camera Raw Filter 10.0 - from the file “Camera Raw.8bi”
   Chalk && Charcoal 19.0 - from the file “Filter Gallery.8bf”
   Chrome 19.0 - from the file “Filter Gallery.8bf”
   Cineon 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Cineon.8bi”
   Clouds 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Clouds.8bf”
   Collada 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Color Halftone 19.0 - from the file “Standard MultiPlugin.8bf”
   Colored Pencil 19.0 - from the file “Filter Gallery.8bf”
   CompuServe GIF 19.0 - from the file “Standard MultiPlugin.8bf”
   Conté Crayon 19.0 - from the file “Filter Gallery.8bf”
   Craquelure 19.0 - from the file “Filter Gallery.8bf”
   Crop and Straighten Photos 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “CropPhotosAuto.8li”
   Crop and Straighten Photos Filter 19.0 - from the file “Standard MultiPlugin.8bf”
   Crosshatch 19.0 - from the file “Filter Gallery.8bf”
   Crystallize 19.0 - from the file “Standard MultiPlugin.8bf”
   Cutout 19.0 - from the file “Filter Gallery.8bf”
   Dark Strokes 19.0 - from the file “Filter Gallery.8bf”
   De-Interlace 19.0 - from the file “Standard MultiPlugin.8bf”
   Dicom 19.0 - from the file “Dicom.8bi”
   Difference Clouds 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Clouds.8bf”
   Diffuse Glow 19.0 - from the file “Filter Gallery.8bf”
   Displace 19.0 - from the file “Standard MultiPlugin.8bf”
   Dry Brush 19.0 - from the file “Filter Gallery.8bf”
   Eazel Acquire 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “EazelAcquire.8ba”
   Entropy 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   Export Color Lookup Tables 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Export3DLUT.8be”
   Extrude 19.0 - from the file “Standard MultiPlugin.8bf”
   FastCore Routines 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “FastCore.8bx”
   Fibers 19.0 - from the file “Standard MultiPlugin.8bf”
   Film Grain 19.0 - from the file “Filter Gallery.8bf”
   Filter Gallery 19.0 - from the file “Filter Gallery.8bf”
   Flash 3D 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Fresco 19.0 - from the file “Filter Gallery.8bf”
   Glass 19.0 - from the file “Filter Gallery.8bf”
   Glowing Edges 19.0 - from the file “Filter Gallery.8bf”
   Google Earth 4 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Graphic Pen 19.0 - from the file “Filter Gallery.8bf”
   Halftone Pattern 19.0 - from the file “Filter Gallery.8bf”
   Halide Bottlenecks 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “HalideBottlenecks.8bx”
   HDRMergeUI 19.0 - from the file “HDRMergeUI.8bf”
   HSB/HSL 19.0 - from the file “Standard MultiPlugin.8bf”
   IFF Format 19.0 - from the file “Standard MultiPlugin.8bf”
   IGES 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Ink Outlines 19.0 - from the file “Filter Gallery.8bf”
   JPEG 2000 19.0 - from the file “JPEG2000.8bi”
   Kurtosis 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   Lens Blur 19.0 - from the file “Lens Blur.8bf”
   Lens Correction 19.0 - from the file “Lens Correction.8bf”
   Lens Flare 19.0 - from the file “Standard MultiPlugin.8bf”
   Liquify 19.0 - from the file “Liquify.8bf”
   Matlab Operation 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “ChannelPort.8bf”
   Maximum 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   Mean 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   Measurement Core 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “MeasurementCore.8me”
   Median 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   Mezzotint 19.0 - from the file “Standard MultiPlugin.8bf”
   Minimum 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   MMXCore Routines 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “MMXCore.8bx”
   Mosaic Tiles 19.0 - from the file “Filter Gallery.8bf”
   Multiprocessor Support 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “MultiProcessor Support.8bx”
   Neon Glow 19.0 - from the file “Filter Gallery.8bf”
   Note Paper 19.0 - from the file “Filter Gallery.8bf”
   NTSC Colors 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “NTSC Colors.8bf”
   Ocean Ripple 19.0 - from the file “Filter Gallery.8bf”
   OpenEXR 19.0 - from the file “Standard MultiPlugin.8bf”
   Paint Daubs 19.0 - from the file “Filter Gallery.8bf”
   Palette Knife 19.0 - from the file “Filter Gallery.8bf”
   Patchwork 19.0 - from the file “Filter Gallery.8bf”
   Paths to Illustrator 19.0 - from the file “Standard MultiPlugin.8bf”
   PCX 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “PCX.8bi”
   Photocopy 19.0 - from the file “Filter Gallery.8bf”
   Photoshop 3D Engine 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Photoshop3DEngine.8bi”
   Photoshop Touch 19.0 - from the file “PSDX.8bi”
   Picture Package Filter 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “ChannelPort.8bf”
   Pinch 19.0 - from the file “Standard MultiPlugin.8bf”
   Pixar 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Pixar.8bi”
   Plaster 19.0 - from the file “Filter Gallery.8bf”
   Plastic Wrap 19.0 - from the file “Filter Gallery.8bf”
   PLY 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Pointillize 19.0 - from the file “Standard MultiPlugin.8bf”
   Polar Coordinates 19.0 - from the file “Standard MultiPlugin.8bf”
   Portable Bit Map 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “PBM.8bi”
   Poster Edges 19.0 - from the file “Filter Gallery.8bf”
   PRC 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Radial Blur 19.0 - from the file “Standard MultiPlugin.8bf”
   Radiance 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Radiance.8bi”
   Range 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   Render Color Lookup Grid 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Export3DLUT.8be”
   Reticulation 19.0 - from the file “Filter Gallery.8bf”
   Ripple 19.0 - from the file “Standard MultiPlugin.8bf”
   Rough Pastels 19.0 - from the file “Filter Gallery.8bf”
   Save for Web 19.0 - from the file “Save for Web.8be”
   ScriptingSupport 19.0 - from the file “ScriptingSupport.8li”
   Shake Reduction 19.0 - from the file “Shake Reduction.8bf”
   Shear 19.0 - from the file “Standard MultiPlugin.8bf”
   Skewness 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   Smart Blur 19.0 - from the file “Standard MultiPlugin.8bf”
   Smudge Stick 19.0 - from the file “Filter Gallery.8bf”
   Solarize 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Solarize.8bf”
   Spaces 19.0 - from the file “Spaces.8li”
   Spatter 19.0 - from the file “Filter Gallery.8bf”
   Spherize 19.0 - from the file “Standard MultiPlugin.8bf”
   Sponge 19.0 - from the file “Filter Gallery.8bf”
   Sprayed Strokes 19.0 - from the file “Filter Gallery.8bf”
   Stained Glass 19.0 - from the file “Filter Gallery.8bf”
   Stamp 19.0 - from the file “Filter Gallery.8bf”
   Standard Deviation 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   STL 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Sumi-e 19.0 - from the file “Filter Gallery.8bf”
   Summation 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   Targa 19.0 - from the file “Standard MultiPlugin.8bf”
   Texturizer 19.0 - from the file “Filter Gallery.8bf”
   Tiles 19.0 - from the file “Standard MultiPlugin.8bf”
   Torn Edges 19.0 - from the file “Filter Gallery.8bf”
   Twirl 19.0 - from the file “Standard MultiPlugin.8bf”
   U3D 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Underpainting 19.0 - from the file “Filter Gallery.8bf”
   Vanishing Point 19.0 - from the file “VanishingPoint.8bf”
   Variance 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
   Virtual Reality Modeling Language | VRML 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   Water Paper 19.0 - from the file “Filter Gallery.8bf”
   Watercolor 19.0 - from the file “Filter Gallery.8bf”
   Wave 19.0 - from the file “Standard MultiPlugin.8bf”
   Wavefront|OBJ 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
   WIA Support 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “WIASupport.8li”
   Wind 19.0 - from the file “Standard MultiPlugin.8bf”
   Wireless Bitmap 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “WBMP.8bi”
   ZigZag 19.0 - from the file “Standard MultiPlugin.8bf”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
   com.adobe.inapp.purchase  2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
   com.adobe.Butler.backend  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
   New Document  2.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.ccx.fnft\fnft.html”
   Libraries  2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
   Start  2.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.ccx.start\index.html”
   Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
   Export As  3.0.13 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
Installed TWAIN devices: NONE
My PC Specs:
Case: Phantek Enthoo Evolv ATX Glass
Power Supply: EVGA Supernova 750 G2, 750 watts
Motherboard: Gigabyte Z170X-UD5 (rev. 1.0) LGA 1151 Intel Z170 HDMI, SATA 6Gb’s USB 3.1
   USB 3.0 ATX Intel
CPU: Intel i7-6700K Unlocked
Cooler: Corsair H100i v2
Case Fans: 3 - 140's (Phantek) comes with the case
GPU: MSI GeForce GTX 1060
RAM: Corsair Vengeance LPX DDR4, 32GB’s 2666Mhz, 2x16GB
SSD: Samsung V-NAND SSD 950 PRO M.2 NVM Express, 512GB
After I process real estate images they are moved to external hard drives. I keep my pc as empty as possible.
Hi
Task manager shows that something is using 15% of your CPU but it isn't the three apps that are shown.
Are you able to scroll down and find out what is using your CPU time?
Dave
Engaged ,
Here are 2 more screen shots, I scrolled down the whole column, I didn't think that percentage 15% was that much (Learning as I go) to make a difference, most are 0% or .1% to .5%, not much running really, except for the Graphics Card at 4%, which is understandable, I am using the pc & its running. Service Host: Windows Management Instrumentation seems to be the hog here at 10%.
Jerry
Hi
I just checked on mine:
The first, MSI_ActiveX process is not loaded
The second Windows Management Instrumentation service is loaded but taking no CPU time.
I am no expert when it comes to Windows processes/services so will include  JJMack   to see if he can advise.
Dave
Engaged ,
Alright. My MSI wanted to do a new update the other day & when I clicked install it acted a little funny but I didn't think it updated, did not act like it usually does when I installed updates.
I hope JJMack can help out & not go to technical on me, at times people who are knowledgeable don't break it down when asking you to perform tasks or looking for things on your pc, keep it simple please. I am available most of the day but have to get ready to leave around 4 pm. Heading out for the office Xmas party, rather stay home its raining here & turning cold tonight but have to make an appearance.
I guess he's going to contact me at some point instead of you. Thanks for all your help, I'll be in touch.
Engaged ,
Dave, I checked my task mgr and forgot to open the drop down menu, here is another screen shot showing what is not running under the tab. Please pass it along if you feel its necessary.
Jerry
I have onle three version of Photoshop Creative cloud installed.  CS6,  CC 2014 which is my preferred version and CC 2018.  All perform w little different from each other.  Some operation behave some what differently and for and operation like transform rotating a layer with a linked layer mask I see CC 2014 performing much poorer then CS6 and CC 2018.  It would be better if you can identify where you see the annoying lag  stating "Everything seems to be lagging when making adjustments." There are so many adjustment the you can make.  Lightroom Develop module ACR in Photoshop and Photoshop adjustment filters and plug-ins. All lag the same or different.  Some adjustments can be compute intensive. The Task manager captures you post indicated your machine is not  being overtaxed.  If there is a large lagging performance problem there may be some contention for something that is being interlocked.
JJMack
Engaged ,
Dec 10, 2017 Dec 10, 2017
Most of the problem seems to be in Lr, sliders did have a delay but it seems to have stopped, interesting, over the last couple days the delay was present, however when you move ANY of the sliders in the develop module the image has a jerky movement to it as the color, temp, whites, blacks, shadows, etc....is being applied. It use to be fluid, no jerky movement, nice and smooth transition as the slider moves + or - . This does not occur in Ps, it have the same problem but not as severe. Now it seems to be ok, very strange. I am perplexed as to why my Service Host: Windows Management Instrumentation is running at 9% to 12% all the time. Dave's said his is taking no CPU time, but mine is, any thoughts as to why?
A few months ago my Corsair radiator stop working & my core package temp was running at around 35-40C, I realize that's not terrible but still should be lower, like around what it was prior, 25-29C. This is looking at my Corsair Link that monitors everything. After I changed out the radiator is went back down to 25-29C. Now its back up to 38-40C running at 13-15% load, which makes sense because the Service Host: Windows Management Instrumentation is running at 9-10% & my MSI_ActiveX_Service (32 bit) is running at 3.8-4.8%. Adds up to 15% CPU load.
I am not as computer savvy as you are & as for Ps I'm still in the learning stages but getting by being self taught. I don't know how to reset my Ps settings & tools, besides now my problems seems to be in Lr only for the moment.
Also you sent me what appears to be a Windows 10 Pro link that I can click on, is this a link to Windows 10 Pro for me to upgrade or information about for me to read? Please advise. I have Windows 10 Home, if it is a link not sure how to do this, I would need to get with a computer guy to help me. Right now I am slammed with work & need my pc so I can't be screwing around with it to much right now. I have 4 properties to shoot this week & cannot be down due to something I did or inadvertently did. I am just going to have to work around my issue right now. Granted it's not terrible but I built this pc to avoid situations like this & its been working flawlessly up until the upgrade.
Please let me know your thoughts, see screen shots- Jerry
Engaged ,
Dec 16, 2017 Dec 16, 2017
After dealing with this issue for a number of days Windows 10 (Home) did a 2 minute update & it corrected my problem. Hope this helps anyone on the forum with a similar issue, read quite a few. Core Package running around 24C & CPU load is 1-2%. Back in business.
