hey guys,
I was a huge fan of the refine edge tool in photoshop and to my dismay after an auto update it was gone.
I have tried the whole holding shift, option command to get refine edge back in CC 2017 but it doesnt give the same results
so then I heard you can install older versions of photoshop, I went back to 2014 and thought brilliant, but I am still getting the same results as select and mask, is there a fix or do i have a setting wrong?
here is a screen shot, just a rough image of trying to get all the hair and what it is doing ignore the shoddy selection of the person and focus more on the head
as you can see the background is coming through and not actually selecting anything properly, should I try an older version, could 2017 version be interfering or something else
cheers
Hair can be very tricky.
I would say first of all the tighter your original selection the better the Select and Mask/Refine Edges will perform.
Every image is different so its all about tweaking the settings until you get the best result.
Also you could use the Select and Mask/Refine Edges to mask the hair a best you can, then Output the mask onto a new layer and then use a brush to improve the mask further.
Here is a good tutorial and examples: How to Cut Out Hair with the Brush Tool in Photoshop - YouTube
...Copy link to clipboard
Hi
The old refine edge has not changed. Select and mask has moved on between versions.
Why not post a full resolution unmasked image of the head so we can better advise on masking it.
Dave
This email address is no longer in use.
We are not responding by email, we are responding on the Photoshop forum. You need to go to the Photoshop forum and change the email details in your profile
Dave
yeh i have, that was an auto response, Im guessing it comes up when adobe tries sending me a response notification.
cheers for the help guys. it was more a general request not just for that one file, I am trying to do some composites for sport and a lot of hair is involved and using not so great resolution.
I am assuming the brush takes its settings from your actual brush settings, I have since changed to a harder brush and am getting better results already.
cheers for the help
Hope this helps.
Hi
The image is not very resolution. Make sure you have permission to use it and get a higher res version to mask.
For demo onlyI used CC2018 select and mask.
1. A quick selection (top brush)
2. Selected all hair and a bit of background with the brush (3rd tool)
3. Set the refine edge brush to 6 pixels, 100% hardness 1% spacing, radius 0 and smart radius off and brushed between the white hair and the background, then separately between the black hair at the back of the head and the background
Dave
