Hye guys,
I currently want to learn how to make tooltip via as3.
Hoping you guys can help me to explain what the code function in the code;
import fl.transitions.easing.*;
import fl.transitions.*;
mc.addEventListener("mouseOver", mouseRollOver);
mc.addEventListener("mouseOut", mouseRollOut);
mc.addEventListener("mouseMove", mouseMove1);
var tooltip:Tooltip = new Tooltip();
tooltip.txt.text = "This is a tooltip";
tooltip.x = stage.mouseX;
tooltip.y = stage.mouseY - mc.height;
function mouseRollOver(e:MouseEvent):void {
addChild(tooltip);
var myTween:Tween = new Tween(tooltip, "alpha", Regular.easeIn, 0, 1, 0.5, true);
function mouseRollOut(e:MouseEvent):void {
removeChild(tooltip);
function mouseMove1(e:MouseEvent):void {
Thank you
cc: RandomlyFish​, just.emma​,
do you have a Tooltip class? (just movieclip with a textfield (named txt) is sufficient.)
is that your code?
Yes I have create a Movie Clip with instance & class named "Tooltip" with empty Dynamic Text in it.
This is not my own code, i just copied & pasted from a tutorial (i forgot where).
But I have no idea the function of the code & need someone to help me to explain it so later I can made my own.
and I want make a multi tooltip.
Thanks.
mc.addEventListener("mouseOver", mouseRollOver); // adding mouseevent listeners
mc.addEventListener("mouseOut", mouseRollOut); // "" ""
mc.addEventListener("mouseMove", mouseMove1); // "" ""
var tooltip:Tooltip = new Tooltip(); // create a new Tooltip instance
tooltip.txt.text = "This is a tooltip"; // assign the help text
tooltip.x = stage.mouseX; // assign position
tooltip.y = stage.mouseY - mc.height; // "" ""
addChild(tooltip); // add to the display when mc is rolledover
var myTween:Tween = new Tween(tooltip, "alpha", Regular.easeIn, 0, 1, 0.5, true); // tween its alpha so it fades in
removeChild(tooltip); // remove the tooltip on mouse out
tooltip.x = stage.mouseX; // move the tooltip when the mouse moves
Thanks for the reply @kglad
So if I put it to more changeable view:
<movieClip>.addEventListener("mouseOver", <mouseOver function>); // adding mouseevent listeners
<movieClip>.addEventListener("mouseOut", <mouseOut function>); // "" ""
<movieClip>.addEventListener("mouseMove", <mouseMove function>); // "" ""
var <instance>:<class>= new <class>(); // create a new instance
<instance>.<dynamicText instance>.text = "This is a tooltip"; // assign the help text
<instance>.x = stage.mouseX; // assign position
<instance>.y = stage.mouseY - <movieClip>.height; // "" ""
function <mouseOver function>(e:MouseEvent):void {
addChild(<instance>); // add to the display when mc is rolledover
var myTween:Tween = new Tween(<instance>, "alpha", Regular.easeIn, 0, 1, 0.5, true); // tween its alpha so it fades in
function <mouseOut function>)(e:MouseEvent):void {
removeChild(<instance>); // remove the tooltip on mouse out
function <mouseMove function>(e:MouseEvent):void {
<instance>.x = stage.mouseX; // move the tooltip when the mouse moves
is this correct?
that's not valid actionscript. if it's meant to something else, i don't understand it.
So sorry,
forget my previous post.
What i need to change if i want to make another tooltip in the same stage.
var tooltip:Tooltip;
var ttObj:Object={};
//call toolTipF and pass whatever displayobject and tooltip string you want
function toolTipF(dobj:DisplayObject,s:String):void{
tooltip = new Tooltip(); // create a new Tooltip instance
tooltip.txt.text = s; // assign the help text
ttObj.dobj=tooltip;
obj.addEventListener(MouseEvent.MOUSE_OVER,mouseRollOver);
obj.addEventListener(MouseEvent.MOUSE_OUT,mouseRollOut);
tooltip=ttObj.e.currentTarget
removeChild(ttObj.e.currentTarget); // remove the tooltip on mouse out
