PDFs opening in Internet Explorer even with Adobe Plugin DISABLED
Nov 28, 2017 Nov 28, 2017
Hi Adobe,
I have Adobe Acrobat Reader DC version 18.009.20044.55097, and I am using IE 11 version 11.674.15063.0.  I have properly disabled the Adobe PDF Reader plugin within Internet Explorer, and PDFs are STILL opening inside of the browser.
This happens on Windows 7 AND Windows 10.
Any tips?
General troubleshooting
10.6K
Adobe Employee ,
Dec 01, 2017 Dec 01, 2017
Hello ThoR294
Sorry for the delay in response to your query and apologize for the inconvenience caused. As per the description above the PDF file is still opening in IE after disabling the plug-in/extension, Is that correct?
Please refer and try the steps from the following KB doc Cannot stop PDF's opening in Internet Explorer (IE)
Hope this helps, and let us know how it goes.
Anand Sri.
Hi Anand,
We have already completed those steps, as you can see in the 2nd photo where the addin is disabled, and the option to enable/disable it is grayed out.  This is on a computer that is on a domain, where we have a GPO set to disable the addin.]
The only way we have been able to get it to work, is to delete the folder on the PC that contains the adobe PDF plugin for IE.
also, forgot to answer, yes that is correct.
Dec 12, 2017 Dec 12, 2017
Bump.
Adobe Employee ,
Jan 02, 2018 Jan 02, 2018
Hello Brandon,
Sorry for the delay in response to your query and apologize for the inconvenience caused. I am following up to check if the issue is resolved or not. If you still facing the issue after trying the above suggestions, will request you to contact the support team so that they can remote in if required and resolve the issue for you, contact support through Contact us | Adobe
Anand Sri.
Hi Anand,
No problem.  The issue is not resolved.  We are currently doing a workaround by renaming the activeX folder in C:\Program Files (x86)\Common Files\Adobe\Acrobat ... This disables the plugin temporarily till adobe is updated, then we have to do it again.
I tried calling adobe support but they will not support adobe reader itself, they said to post here.
Nov 26, 2019 Nov 26, 2019
HI ,
is it fixed now ?  we are using Adobe Acrobat Reader 18.9 and we disabled the Adobe plugin in IE 11 , still PDF files are opening in IE.
any permanent issue ?
Nov 27, 2019 Nov 27, 2019
Rename the plugin file, effectivly breaking the intagration when IE cant find the plugin.
Disableing via GPO or manualy in the IE plugin interface dosnt work dispite what support here will say.
It's funny, that's exactly what I did. I renamed the file to Activex.old
and now it can't use the plug in so it works. Would be great to not have
to figure out some kind of workaround...
Adobe Employee ,
Brandon,
I have sent you a private message, please check your email inbox . Meanwhile, please refer to the following KB doc Troubleshoot viewing PDF files on the web and check the PDF display preferences in Preferences>internet and deselect Display PDF in Web Browser.
Anand Sri.
Oct 22, 2019 Oct 22, 2019
What would be really great is if instead of sending him a private message, you could post the solution publicly so that not every single person who has this issue has to go through this rigamarole.  This is beyond frustrating for me and my users.  I know this is way late, which actually makes me wonder why this issue hasn't been fixed ages ago.  I don't want to have to create another thread to get my own answer but if I have to that's what I'll do.
Adobe only knows canned responses, everything else is kept in the shadows.
