Hi
I had the same issue as the one below.
I followed the steps provided:
1. Go to File-> click Print Presets
2. click Define -> click Edit
3. Change Printer: If it was Postscript files or PDF change to -> Default Printer(or actual printer that you have).
4. Click OK button Click OK button again.
5. go to Print Booklet and Click Print Settings
6. Change Printer: Adobe PDF and print...
Presets Edit is already set to default printer. There is no other option. And I still got the error.
However, when I just go to print the document (ctl + p) and change the preset there to default from custom, my default printer pops up, which I change to pdf but then I have to readjust the page size.
This adjustment does not stay when I close it and reopen it and try it again.
What can I do?
Hi armands appealtech,
As per your query when you try to print with default printer it gives you error "Printing error: Problem with initializing".
In that case please try updating or installing printer drivers once again and check how it works.
Regards
Srishti
