Hello - I'm new to After Effects, but have been using it without problems for the past few weeks. Yesterday I went into Preferences and Emptied the Disk Cache and Cleaned the Database and Cache in order to improve performance. After doing that, playback of video or comp became veiled in black, with no audio. If I scrubbed with the playhead, I could see the video but that was the only way I could see anything. - I uninstalled and reinstalled AE 2017 but that didn't fix the problem. I uninstalled AE 2017 again and installed 2015. So far, 2015 is working normally. - Prior to installing 2015, I also upgraded to OSX Sierra so I could update my graphics card driver. That didn't fix the problem with AE 2017, but everything is up-to-date.
I'm using both .mp4 files and .mov files. The same files that were working and visible before adjusting the Preferences settings would only playback under a black screen after adjusting the settings.
I would like to be able to use the most current version of AE. Any suggestions as to how I can fix the playback issue with 2017? - I've looked on these forums and elsewhere and found a few other people describing a similar problem with a 'black screen.' The suggested solution often seems to be to empty the cache and clean the database. So, in my case, it seems the solution to some people's problems has been the cause of my problem. ???
If it helps, here is my system info:
Model Name: iMac
Model Identifier: iMac14,2
Processor Name: Intel Core i5
Processor Speed: 3.2 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 6 MB
Memory: 16 GB
NVIDIA GeForce GT 755M:
Chipset Model: NVIDIA GeForce GT 755M
Type: GPU
Bus: PCIe
PCIe Lane Width: x16
VRAM (Total): 1024 MB
Vendor: NVIDIA (0x10de)
Device ID: 0x0fea
Revision ID: 0x00a2
ROM Revision: 3782
Metal: Supported
Displays:
iMac:
Display Type: LCD
Resolution: 2560 x 1440
Pixel Depth: 32-Bit Color (ARGB8888)
Main Display: Yes
Mirror: Off
Online: Yes
Automatically Adjust Brightness: Yes
Built-In: Yes
If you think it was related to your preference, try launching AE and trashing the prefs. You hold cmd+opt+shift while it's starting and it should give you an option to delete your preferences file. Uninstalling usually keeps your prefs around, so this will ensure they get trashed.
Try installing CC 2017 alongside your current install of CC 2015.3 (or whatever version you have that's working). Try turning off (or on, if it's already off), the hardware accelerate panels option.
don't work!
Hi JessicaC,
Are you still getting a black screen when playing back? That sounds pretty awful. Have you tried an installation of the new software as Szalam suggested? Please let us know what happens when you try his suggestions.
Kevin
Sorry for not replying earlier. No, installing 2017 alongside 2015 didn't fix the issue. I also toggled hardware acceleration on and off. I'm still getting a black screen on preview.
No problem, Jessica. That is an annoying issue. How large is the frame size of your footage? Is it 4K? Which camera did it come from?
Kevin
I've tried with footage from various sources. I've used video taken with my cellphone (a Moto G4), video created from an Animate CC file converted to MP4 with Media Encoder, and other video I've downloaded. None of it is 4k and all of it worked prior to me mucking about with the Preference settings. - This first started with some files I was using as part of an After Effects class available through Bring Your Own Laptop. I was looking for help with cameras but got derailed by a section on speeding up a slow computer. I didn't see anyone else in the BYOL forums reporting any issues with black screens so I'm assuming the issue was something unique to me or my machine.
Success!! That worked! Thank you!
Hooray!
Please come back to this thread on the forum real quick and hit the "Correct Answer" button on the right post (and feel free to mark any others as "Helpful" that were) to close out this thread and to help others with the same problem in the future to find the correct answer more quickly.
i installed ae off my school website and they only have cc 2015
I HAVE THE ANSWER JESS!
When I had the same problem, All i did was got to my comp settings, change it from HD 1080p to 720p. That fixed it. Its got to do with your memory and resolution. If your file is too big to pre-render/preview in Full HD 1080p, then it will show black all the time. But lower the resolution settings, it will fix it.
It works. Hope this helps.
Same issue and seemingly no solutions anywhere online
eye symbol button must be turned on (play video in preview) ! boom
Omg thank you so much! I've been looking all morning for a solution and this simple one actually worked!
This literally saved my day. You are a wizard.
I simply had disabled 'play video in preview', click on the eye in the preview panel
This totally was my problem. After freaking out with the black screen. I saw the eye was not selected in the preview tab. Problem solved! Thank you dearly.
I found this black playback happens when you're on a "Custom Camera". I selected it by accident by pressing escape and I didnt realize I did it. As I tinkered around I noticed the setting and reverted it to Active Camera and it all played back normally as it should. The resetting of settings didnt help or clearing the cache because it wasnt the issue for me in the first place. It was the camera issue causing it to go black.
How do you go about this? Where do I find the camera settings and switch it back to active camera?
