I have been having issues finding already imported images and folder problems so decided to remove them and start again. I am trying to import images to be hit with this message for every image type and every folder destination. What does this mean how do I fix this?
[Moved from the Lounge (which is where you can "connect with your peers" from across all of Adobe's products for conversations that don't directly relate to help and support) to a product-specific support forum by a moderator.]
You need to use your operating system features to check the properties of the destination folder to ensure that the folder has both read and write permissions.
Hi. Do you know the steps to access operating system features and check folder has permission to read and write or how to change its features.? I am having the same problem and don't know how to get into these steps in order to make changes.
In Windows, you use the Windows File Explorer, "properties" on the selected file/folder.
Similarly with a Mac using Finder.
