2
Photoshop CC 2017 - Problem with Generator
Participant ,
Sep 22, 2017 Sep 22, 2017
For the last couple of days, I've been receiving this error:
I can still use Photoshop, but attempting to export images (for example, exporting PNGs for the web), results in another error message.
I have uninstalled and reinstalled Photoshop. I launched Photoshop after disabling all third-party plug-ins. I continue to receive these messages.
OS: WIndows 7 Professional
5.6K
New Here , May 29, 2018 May 29, 2018
Hi Everyone,
I just experienced this issue and was able to fix it. I've tried the two solutions but it did not work for me. I was able to find a fix that worked for me. Hopefully this helps someone else out.
Ensuring you have administrative privileges on  the device:
  • Hit the Windows key and type in Regedit.
  • Navigate to the following folder: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  • There you will see a variety of entries. On the right hand side in the
Adobe
Sep 28, 2017 Sep 28, 2017
Hi todd_rohrer,
We've documented 2 solutions that might be helpful in fixing this issue. Take a look at this article Error: "There is a problem with Generator" occurs when launching Photoshop and let us know the outcome.
Akash
Participant ,
The Photoshop CC 2017 folder and Generator subfolder already exist.
Neither this folder nor previous Photoshop version folders have plug-ins.
Oct 02, 2017 Oct 02, 2017
This solutions are not working, Akash Error: "There is a problem with Generator" occurs when launching Photoshop
Same problem here. Windows 10, i7, DELL. Full updated.
Why Adobe didn´t solve this issue?
Oct 12, 2017 Oct 12, 2017
Hi flaviop55563966
Which version of Photoshop are you using?
Akash
Participant ,
Oct 13, 2017 Oct 13, 2017
I'm using CC 2017.1.1
Jan 03, 2018 Jan 03, 2018
Anyone find a solution to this? I've had this issue for a long time and photoshop has been unusable to create content because i can only save my work, not export it.
I've tried reinstalling photoshop, The solutions listed above, manually adding the generator folder, renaming the photoshop folder from profile, renaming the adobe folder from the profile, looking at the shell entries in the registry.
Windows 10 64 1709 with the latest photoshop 2018.
Is there anyway to FORCE the generator option off and stay off?
Participant ,
Oct 20, 2017 Oct 20, 2017
I upgraded to CC 2018, and I'm still having this problem.
Participant ,
Oct 26, 2017 Oct 26, 2017
This is also preventing me from creating animated gifs. Is there ​any solution?!
Nov 11, 2017 Nov 11, 2017
I've been having the same problem for the last few months.
The suggested 'fix' doesn't work and it has occurred in the last version of PS CC 2017 and now in PS CC 2018.
I'm using an up-to-date Win 7 Home Premium OS w/ a deliberately very generic 16GB  i5 computer.
This is difficult to diagnose definitively because the Adobe 'error' message is essentially useless.  I suspect it's a write privilege issue even though I am the administrator.  I've considered kludging gpedit into Win 7 HP but am likely to mess everything up.
We need help from Adobe.
Bruce
Dec 07, 2017 Dec 07, 2017
hej Guys
I experience same problems as you with photoshop.
Did anybody found a solution on this one?
Emanuel
Dec 12, 2017 Dec 12, 2017
A solution for me which is similar but not identical to Adobe's solution …
In Win10: View/ Options: ‘change folder and search options’ to View tab> ‘Show hidden files folders, drives’
Hopefully you can walk through the path:
C:\Users\Bruce\AppData\Roaming\Adobe\Adobe Photoshop CC 2018\
In this case ‘Bruce’ is me, the User.  There should exist in that last folder of ‘Adobe Photoshop CC 2018’ , a nested folder called ‘Generator’ and it likely will not exist for us.  Create that folder.  Additionally in that ‘Generator’ folder that should be a nested folder called Logs.  Also, Create that folder.
The proper path should now look like:
C:\Users\Bruce\AppData\Roaming\Adobe\Adobe Photoshop CC 2018\Generator\Logs\
When Photoshop is run, it should automatically create a file called  ‘generator_latest.txt’.  Us PS users don’t need to worry about that as Photoshop will do this but it's good to know.
I have no idea why some of our machines don’t have these folders.  I suppose it's irrelevant.  Hope this works for some or all of you having this problem.
Bruce
Participant ,
Dec 13, 2017 Dec 13, 2017
That did not work for me.
I originally tried both ‘Solution 1’ and ‘Solution 2’ from earlier in this thread and they didn’t work.
I erroneously thought that there must be only TWO specific paths where these Generator folders must exist.  In a brainstorm I realized I also have a small Win 10 Microsoft Surface computer that I travel with and PS CC 2018 is also installed on that a per our Adobe Cloud contract.   I did a search on the MS Surface for ‘generator’ and it showed additional folders in a different path than existed on my main graphics Win 7 desktop computer.  Having nothing to lose, I created the rest of that path on my main computer by creating an additional ‘Generator’ and nested ‘Logs’ folder.   It worked for me.  That makes me think that some of us have different folder structures.  It's possible it is perhaps because of old installs. I still have my original vintage  32 bit PS CC and a 64 bit install of PS CC5.  (I should get rid of the PS CC5 but I still use PS CC because it had some 32 bit only filters I occasionally need and I can use the TWAIN Epson Scan only out of a 32 bit PS also.)
My point here is that not only might the plug-in path where one generator folder exists be different but the ‘Generator\Logs\’ folder that I just added might also be a different for some.  Presumably only Adobe knows how these paths are created.
Bruce
<SIGH>
Right after I wrote the above a few hours ago, I fired up PS to do some editing...and guess what?  Yup... the Generator error.
I can't even believe it myself and after a couple of days of error free use.  Makes even less sense than it going bad in the first place.  Why again, especially after a supposed fix that actually worked for a while?
I've been working on this for hours and I'm getting nowhere.  This is Sooooooo bizarre.
Bruce
Dec 14, 2017 Dec 14, 2017
OK…...a non-solution solution...
So Adobe is no help, I’ve worked on this issue for many hours to no avail and the ‘Generator’ error message is a constant irritant.  Apparently the generator is a Java script launcher and Java script capability might be the underlying culprit.  Whatever,  I will have to live without the functionality of those scripts until someone really solves this problem.
However it appears that I/we don’t have to live with a constant in-the-face reminder that this feature isn’t working when PS is launched.  For me, that’s multiple times a day.
(on a PC) go to:
Edit > Preferences > Plug-Ins > and uncheck ‘Enable Generator’
…a simple, if ostrich head in the sand, solution since it fixes nothing.  It does insulate us from that first file launch error message.
There will be glitches… like trying to use ‘Export’.  That apparently uses Generator and in another Adobe indignity, just attempting to ‘Export’ will get the ‘Generator’ error message again AND, to add injury to insult, will automatically recheck that ‘Enable Generator’ box in Preferences.  I suspect something behind the scenes like this happened to me for that day and a half when everything was working…then I unknowingly flipped a bit somewhere.
Bruce
Guest
i think i have the same problem. I mostly use photoshop to make pictures for my website solution media.
Hi Everyone,
  • There you will see a variety of entries. On the right hand side in the Data Column you should see entries that resemble %USERPROFILE%\Downloads %USERPROFILE%\Documents ...etc
  • If there are any items that are mapped to another drive and not the current user profile as above, you could be experiencing this error.
  • My issue was both the Personal and another entry that mapped my documents to an external drive. I edited it to reflect. %USERPROFILE%\Documents
  • Exit the registry editor
  • Restart Photoshop and you should no longer see the issue.
I hope this helps most who have not found a solution. All the best
Participant ,
May 31, 2018 May 31, 2018
I still get an error about "Generator" when I open photoshop, but I can finally use Save For Web again!
Participant ,
Jun 01, 2018 Jun 01, 2018
That may have just been a holdover. I am no longer getting the error!
Jan 23, 2020 Jan 23, 2020
I've been chasing this all morning. Finally found the solution (for me anyway) - it was being caused by MalwareBytes, who are aware of it. THis link for more info and the work-around: https://forums.malwarebytes.com/topic/254622-latest-update-breaks-photoshop/?tab=comments#comment-13...
Jan 27, 2020 Jan 27, 2020
Thank you so much @colins26751223 - second try at trying to find a solution for this and I think MB was the culprit; makles sense as the error only started happening around the time I reinstalled that.
