My apologies, I should have taken more time to read through
the thread. The joys of trying to solve a problem for someone while
you are solving your own.
OK, help me a bit more. In your latest post you say you
started with your IT Merge as one project but split out into a
merge and the process worked and continues to work. Now you are
looking at the next phase of work for User Project. The plan here
is to have the new topics in Project C and that will be merged with
User Project.
In the post before you said the following except that I have
renamed the projects
"So, the problem as it now stands: I've created a new version
of Project C, merged it into IT Merge to test the topics, see if
they will open; they did. Then merged Project C into User Project
(the original goal), but still the topics in Project C do not
open."
What I would like you to do, assuming I have got it right
now, is create a copy of User Project and then trash most of the
content to reduce its size. Then create a folder called Lonno and
copy this reduced User Project to a folder under Lonno. Then copy
Project C to Lonno. Finally zip up Lonno and send it to me via
http://www.transferbigfiles.com.
(I assume both projects are currently directly off your C drive)
Email me via my site with a link to this thread and use that
email address for the file transfer.
