dreamweaver cc 2018 crashes when opening on windows 10
Dec 12, 2017 Dec 12, 2017
this is the screen I get when launching dreamweaver. how do I fix it?
I have uninstalled all of CC apps and adobe cloud and reinstalled. didn't fix it.
also installed program an a different windows 10 machine and same exact issue. other apps install and run perfectly. just an issue with dreamweaver.
8.9K
Community Beginner , Apr 20, 2018 Apr 20, 2018
Since I opened the ticket, having had several weeks of regular hassle, it has not gone wrong so I have no crash therefore no logs to send.
A good thing yes, but I am still wondering what might have been wrong. I am not aware of anything I did to resolve the issue.
I was going to keep going till the start of next week then close the ticket if no more hassle.
I guess the ticket can be closed – and if it happens again I can reopen it and send a log
David
Are you able to install one of the older versions of DW by chance?
From the CC Desktop App...
1. Click the Apps tab
2. Click the small triangle next to DW's Install Icon
3. Choose Other Versions
4. Pick CC 2015
See if that one will run for you. If it does, at least you'll be able to get your work done while troubleshooting continues. CC 2015, 2017 and 2018 can all be installed on the same machines at the same time under a single subscription, so you can continue troubleshooting with Adobe on the latest, while using an older version.
yes, I tried installing the other versions and same issue.
One note on installing multiple versions, well, two notes...
1. Only 1 version can run at a time. If you do get the latest up and running, you'll need to close the older version to work in the newer version and vise versa.
2. If you install a newer version than what you have currently installed, make sure to click the Advanced Options link in the installer dialogue window. That will allow you to turn off the "Remove Older Versions" checkbox so you can keep your older versions while learning if the newer version is worth your trouble (some have found it isn't).
Weird.
When you uninstalled, did you use the Adobe Cleaner Tool?
Use the Creative Cloud Cleaner Tool to solve installation problems
Sometimes corrupt files are left behind in your user account and will affect new installations. You should be able to use it for DW alone, without having to uninstall the other programs in CC.
yes i used that.
What does the Event Viewer report?
Wappler, the only real Dreamweaver alternative.
Dec 13, 2017 Dec 13, 2017
Application Error
Faulting application name: Dreamweaver.exe, version: 18.0.0.10136, time stamp: 0x59cb9662
Faulting module name: Dreamweaver.exe, version: 18.0.0.10136, time stamp: 0x59cb9662
Exception code: 0xc0000005
Fault offset: 0x0000000000f8c177
Faulting process id: 0x24a8
Faulting application start time: 0x01d3742594391f05
Faulting application path: C:\Program Files\Adobe\Adobe Dreamweaver CC 2018\Dreamweaver.exe
Faulting module path: C:\Program Files\Adobe\Adobe Dreamweaver CC 2018\Dreamweaver.exe
Report Id: c3198cda-227f-4864-ae9c-69dddca2f6cb
Faulting package full name:
Faulting package-relative application ID:
Windows Error Reporting
Fault bucket 120864140759, type 4
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: Dreamweaver.exe
P2: 18.0.0.10136
P3: 59cb9662
P4: Dreamweaver.exe
P5: 18.0.0.10136
P6: 59cb9662
P7: c0000005
P8: 0000000000f8c177
P9:
P10:
Well, this is definately a problem with Dreamweaver. I have a feeling that Lalita (lnayal) will be here soon to help you
Adobe Employee ,
Thank you Ben for adding me to the thread.
Dec 14, 2017 Dec 14, 2017
Same exact issue. Tried reinstalling and cleaning. Keeps crashing. I finally got it to load but it refuses to recognize any external drives. It will only see the C drive and can't get it recognize a mapped network drive to the server location.
Do you have all the latest Windows 10 updates?
Did you install DW on your primary hard drive -- same as Windows?
Did you try right-click, run as Admin?
Nancy O'Shea— Product User, Community Expert & Moderator
Alt-Web Design & Publishing ~ Web : Print : Graphics : Media
yes, latest windows updates
on primary hd and have tried run as admin.
Open Windows Event Viewer and look for the faulting module that causes DW to crash.
6 Ways to Open Event Viewer in Windows 10
Sorry, I realize now that Ben already asked you about the Event Viewer.  My bad.
Did you try Restoring Preferences?
Unusual behavior in Dreamweaver? Try restoring preferences.
Nancy
Adobe Employee ,
Hello Jane,
We regret the inconvenience caused due to this crash on launch.
We would need crash dump to dig into the issue. To get a crash dump, below are the steps to follow
  1. Press Win+R and enter regedit and press Enter key to open Registry editor
  2. Go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Windows Error Reporting\
  3. Create a new key LocalDumps
  4. Inside LocalDumps create a new Expandable String value and name it DumpFolder and provide path of the folder on your desktop where you want the dump to created.
  5. Create a DWORD 32Bit value and name it DumpType and provide 1 as the value.
  6. Close Registry Editor
You can refer to the following MS article for more info on the same: https://msdn.microsoft.com/en-us/library/windows/desktop/bb787181(v=vs.85).aspx
Next time Dreamweaver crashes, it will create a crash dump in the path provided in the registry.
Once you have shared the crash dump, you can delete the DumpFolder key if required from HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Windows Error Reporting\ in registry.
You can share the dmp file with me at lnayalatadobedotcom
We will try our best to resolve this issue.
~Lalita
Jan 04, 2018 Jan 04, 2018
Lalita,
did you ever get the dmp file that was sent?
Adobe Employee ,
Feb 22, 2018 Feb 22, 2018
For all those of you still facing issues after restoring preferences, or doing a clean install, send me your Adobe ID, location, and phone number over a private message along with the URL of this post. To send a private message, click my picture and use the Message button.
Preran
Mar 26, 2018 Mar 26, 2018
Edit to below.
This fix has NOT worked - came in next morning opened Dreamweaver and windows crashed
Edit 2
Worked for a few days OK providing I opened Dreamweaver BEFORE all other Apps/Programs - but todya - that did not work.
reverting to text editor to work again - nightmare ++
Have had a similar problem - Windows 10 crashing on opening Dreamweaver
(all apps up to date and current)
Only way out was a reset/reboot PC...
For information I have resolved it
  • Removed Dreamweaver using Creative Cloud  (kept preferences etc)
  • Restarted PC
  • Re-Installed Dreamweaver
  • Re-Started PC again (just to be sure)
  • Opened Dreamweaver successfully
I hope that is it sorted now.
If you have a similar problem good luck in getting it sorted - this cost me a lot of time trying to diagnose and resolve until I did what I guess I should have done at the start...
Regards
David
Adobe Employee ,
Apr 19, 2018 Apr 19, 2018
As requested above could you please share the crash logs with us to look into the issue.
David
Jun 12, 2018 Jun 12, 2018
good luck to you David.
I'd like to delete dreamweaver and reinstall, but when I try it tells me to close dreamweaver.
this when I can't even open the program.
a nightmare
Ralph
Restart your computer.  Right-click and run DW as administrator.
Contributor ,
Aug 08, 2018 Aug 08, 2018
I am beyond frustrated. Experiencing the same problem and it doesn't matter what I do to try and rectify the situation:
Windows 7 Home (legit, all up to date)
Tried Dreamweaver 2018, 2017, 2016, 2015 etc...
Tried uninstalling, restarting computer, using the clean up tool, etc. NOTHING WORKS. Fresh installs still launch, then crash. Tried running as administrator, and all it did was take longer to launch and crash.
I need this app to work! I am paying for it!
Without much to go on, I'm guessing it's caused by a missing or corrupted DLL file.  Please open your Windows Event Viewer to see which faulting module is causing DW to crash.
Lavasoft & Bins utility are 2 known culprits effecting Photoshop, Dreamweaver, After Effects and other Adobe software.  See link below for details on how to fix it.
Photoshop crashes with Lavasoft Chrome extension or Bins utility installed
If neither Lavasoft or Bins are present on your system, please post back with more details from your crash logs.
Contributor ,
I don't know what Lavasoft or Bins are, so presumably I don't have either. (I'm the only user of this system, use Photoshop every day without issue).
Event viewer log for Dreamweaver:
Faulting application name: Dreamweaver.exe, version: 18.2.0.10165, time stamp: 0x5afef9a8
Faulting module name: imshelper.dll, version: 1.0.0.12, time stamp: 0x5b10054d
Fault offset: 0x000000000000b32f
Faulting process id: 0x38b8
Faulting application start time: 0x01d42f49edeaba74
Faulting module path: C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\LCC\x64\imshelper.dll
Report Id: 58c47a24-9b3d-11e8-a739-9e56eaae419c
So, looks like imshelper.dll is the culprit?
