.hhk upload problem
Dec 17, 2008 Dec 17, 2008
When I generate htmlhelp from dita, I open the .hhp in RoboHelp to generate WebHelp. Doing so changes the .hhk file so that any indexterm that references more than one topic is only referenceing the first topic listed under the object.
I need to be able to have the same index term reference various topics. Is there anyway this is possible, other than doing a find and replace in the .hhk to format it like the whidata0.xml and then saving it as whidata0.xml?
914
Community Beginner , Dec 22, 2008 Dec 22, 2008
So the code generated by the toolkit in the .hhk file looked like this:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML//EN">
<html>
<head>
<meta name="GENERATOR" content="Microsoft&reg; HTML Help Workshop 4.1">
<!-- Sitemap 1.0 -->
</head>
<body>
<ul>
<li> <object type="text/sitemap">
<param name="Name" value="Animals">
<param name="Name" value="Cats">
<param name="Local" value="Cats.html#Cats">
<param name="Name" value="Dogs">
<param name="Local" value="Dogs.html#Dogs">
</object>
</li>
</ul>
</body>...
Dec 18, 2008 Dec 18, 2008
Welcome to the forum.
Not sure we allow blue poetry!
I'm not sure why the index is working that way but my first curiosity is why you are opening the project from the HHP file rather than the XPJ.
What you want is the normal way an index works. Was it created in RH?
My files are in dita. So I use ant to process these files through the dita open toolkit. It produces html for every file and also produces the .hhp, .hhk, and .hhc. I open the .hhp in RoboHelp to generate WebHelp.
There is no xpj until after I open the hhp with RoboHelp
Now I see the DITA relevance.
Are you saying that if the keyword is Animals, that only Cat appears in the WebHelp or the Cat and Dog appear but when you click Dog, it goes to the Cat topic?
If you look at the index in the RH editor, what does that show under Animals?
the hhk would originally say this:
<ul>
</object>
When the hhp is opened in RoboHelp the hhk is changed to say:
<ul>
</object>
When WebHelp is generated the whidata0.xml looks like this:
<indexdata>
<key name="Animals" >
<topic name="Animals" url="Cats.html#Cats" />
For it to work how I want it to the whidata0.xml should look like this:
<indexdata>
<topic name="Cats" url="Cats.html#Cats" />
<topic name="Dogs" url="Dogs.html#Dogs" />
I hope this clears everything up. How it works now...only one topic can be linked to each index term.
Sarah
Create a new project in RH with a topic titled Animals and create an index in RH with both index words.
How does that compare with the index your tools are creating.
Your project is not on a network is it? If it is, move it locally as RH will not work properly across a network.
Dec 19, 2008 Dec 19, 2008
In the new project I created in RoboHelp, the index has a keyword called Animals. When I click Animals, it displays a drop-down that says:
Cats
Dogs
Both will take you to the correct topics they are related to.
In the project I generate with DITA, if you click on Animals in the index, it takes you to the Cats topic. Dogs is not an option.
OK so you have established an index generated in RH works as desired. It should now be a case of examing that HHK file in a text editor and the one you are getting from your process. There has to be a difference.
<html>
<head>
</head>
<body>
<ul>
</object>
</li>
</ul>
</body>
</html>
The code in the .hhk file created by the new RoboHelp project, that works, looks like this:
<html>
<object type="text/site properties">
<param name="SiteType" value="index">
</object>
<ul>
<li><object type="text/sitemap">
<param name="Local" value="Cats.htm">
<param name="Local" value="Dogs.htm">
</object>
</ul>
</html>
How to fix the problem:
Copy and paste the following code into the .hhk generated by the toolkit, before you open the ,hhp in RoboHelp:
</object>
That .hhk now looks like this:
<html>
<head>
</head>
<body>
</object>
<ul>
</object>
</li>
</ul>
</body>
</html>
Now the index works just fine.
Glad it was that easy in the end.
RoboHelp Documentation
Download Adobe RoboHelp
