While editing a long video I noticed that the audio does not match the video from a certain point of the video all the way to the end. It is the audio from already edited and cut clips at the beginning but put onto the yet unedited long clip. How can I fix that problem? I have tried to import it again (the original video is fine, but once it is imported the audio is messed up anyway). I would usually start again but I have edited so much that I do not want to star all over again, however continuing is impossible as no matter how many times I import the original video, the audio is shifted?
Hi PaulaR,
What kind of camcorder was used to shoot this footage? More info on the format, etc.
Kevin
Exactly what is INSIDE the video you are editing?
Report back with the codec details of your file, use the programs below... A screen shot works well to SHOW people what you are doing - For Windows Internet Explorer press the PRINT SCREEN button on your keyboard, and then do CTRL-V to paste the screen print from the clipboard into a forum message
Free programs to get file information for PC/Mac http://mediaarea.net/en/MediaInfo/Download
- when you analyze your file in MediaInfo and post a screen shot in the forum, do so in TREE view
Does your video use a VARIABLE Frame Rate? See https://forums.adobe.com/thread/1110005
If yes, use https://handbrake.fr/ open source transcoder/converter to convert to Constant Frame Rate
