Have couple thousand jpg files that I need go from 4 digits (ex. IMG_1158.jpg) to 5 digits (IMG_01158.jpg). Basically, I want to keep the current name and add a zero (a digit) at the beginning. Also, there are gaps in the numbering, they are not continuous: Sequence Number will not work Current Filename or Preserved Filename keep the existing name but don't offer the option of inserting anything into the file name.
Are you talking about Bridge or a Photoshop Script?
I’m thinking you can probably work something out in Command Prompt (if you run Windows). cmd - Batch renaming files using Windows 7 REN (adding prefix)? - Stack Overflow
You may have to remove the original prefix then add it back on.
there are plenty of file re-namers that are freeware.
such as "Renamer" which i use all of the time.
Sorry, I am using CS5 Bridge's Batch Rename feature with a macbook pro 10.12.2
