hello
I'working on a website and I encounter an issue with the accordion menu. When the menu is too long, it goes past the browser's window which is "normal" given the list length, but since the browser does not detect the menu as going past its window and does not provide a scrolling method. I tested on all 3 browsers and I do have the issue.
incomplete menu
entire menu
strangely, it works on mobile phone.
Do you have any idea of what I could do/parameter to get the accordion widget to allow for scrolling?
Thank-You for your time,
On my computers/devices (iMac, iPad) the menu is scrolling without any problem.
Nevertheless: It is not a really good practice, to make a menu so longer, that it exceeds the screen height. This is not a good user experience at all.
I’d suggest to use two text columns (if you definitely want simple text links and no buttons.
(I think, you are aware of the fact, that the text is bleeding outside the grey rectangle. But this is a different issue.
Dear Günter,
thank you for your reply. Sadly, I'm at fault here. I accidentally left the old site online (based on spip). I did put the new site online so if you check again, you should be able to see the issue. Thank-you for your help.
Kind regards,
ps: I know for the bleeding, easy fix but I'd rather correct the scrolling 1st.
No, I can‘t see the issue. All works, as I expect it to work.
