Lightroom cc wont Start . event log references ucrtbase.dll
Oct 27, 2017 Oct 27, 2017
lightroom CC wont start . it crashses and windows looks for a solution.
windows 10 latest update
multiple installs/reinstalls of lightroom cc
lightroom cc classic does work .
import and catalog templates are upgraded.
tries turning off vpn and vpn back on neither works .
event viewer log references
Faulting application name: lightroomcc.exe, version: 1.0.0.10, time stamp: 0x59c19f6d
Faulting module name: ucrtbase.dll, version: 10.0.16299.15, time stamp: 0x70f70cc4
Exception code: 0xc0000409
Fault offset: 0x000000000006b70e
Faulting process id: 0x2c94
Faulting application start time: 0x01d34faa8789bc25
Faulting application path: C:\Program Files\Adobe\Adobe Lightroom CC\lightroomcc.exe
Faulting module path: C:\WINDOWS\System32\ucrtbase.dll
924
Adobe Employee ,
Nov 23, 2017 Nov 23, 2017
Hi latenightbj,
Please update Lightroom CC to 1.0.1 update and check if that helps.
Keep your Lightroom version up to date
Mohit
Nov 24, 2017 Nov 24, 2017
Hi Mohit,
I was really interested in testing Lightroom CC (for many reasons, but particularily for the cloud features, allowing me to work from everywhere). But unfortunately I was not able to get it running on my windows PC at home, so now the test period is over and I will probably have to look for other solutions.
What I did:
  • Install from adobe website
  • Reinstall from installer file
  • Reinstall from Adobe CC GUI
  • clearing Preferences, restarting/reinstalling
  • spending hours searching through communities
You tell us to keep the version up to date - is there another way to do so other than reinstalling (rembember it won't even start).
This is my last try - maybee you can give me/us another good hint. Otherwise I fear you have lost a customer - presumably more since others seem to have similiar problems.
Axel
Nov 25, 2017 Nov 25, 2017
Hi!
Mine doesn't start, instruction is "upgrade", than program says: "program is not reacting".
Can't use the program, never could start once...
Jos ten Brink
Hi there!
Problem is: Initialising, then trying to upgrade, next: program closes. I did re-install.
Thanks for your reaction anyway.
Jos ten Brink
Muiderberg, Netherlands.
Dutch version Photoshop Lightroom 6.
Sorry Mohit,
Lightroom 6.0 (did buy a few days ago) says: Upgrade for making new logfile.
When I do, program closes after a few seconds, so I can't update either..).
Thanks anyway.
Jos ten Brink
Dec 18, 2017 Dec 18, 2017
I've got the same problem. Can you try turning off GPU acceleration in the preferences and see if that helps you?
Advocate ,
Since we all use (basically) the same software and it works just fine for most, when there are problems, such as yours, the cause is with Microsoft Windows and/or a specific PC system. Since the software runs just fine on most Windows systems we are left at looking at an individual system as the cause.
i.e. - If it works on my system but not on yours the cause is your system and not that of the software.
