The mini bridge in photo shop seems to have disappeared and I really, really miss it! I have Photoshop CS6.
Is there any way I can get this back?
Start double click Adobe Bridge CS6...
Hi
Have you tried Window --> Extensions --> Mini Bridge
Das hier war der richtige Tip - nach langem Suchen läuft meine Minibridge unter CS6 und Win 10 Pro wieder!
Danke, Super Merlin und Igment Blog!!
It should be there. If it is but the mini panel is empty make sure the CS6 Bridge is running in the background not bridge cc 2018 and your registry has the string key found in the link SuperMerlin posted. If no Bridge is running in the background CS6 mini bridge should display a button launch Bridge cs6 if you have the string key in your registry. If the wrong bridge is running in the background cs6 mini bridge panel should show that.
That happen to me when a preview Windows 10 broke windows on my machine. I had to install Windows fron scratch and installed all ma applications. My registry was missing that key and my Mini Bridge panel was empty.
not sure I know how to make sure the CS6 bridge is running in the background.
and then what?
