Please provide any quick tips for buttons which can toggle
on/off for narration in presentation. I can default with audio off
and begin narration with a Success Click. Any ideas on how best to
handle.
The quickest tip for turning narration off or on in a
presentation would be to use a skin that has a Flash based playback
control. On these, you may supply a "Mute" button. The user would
click the mute button to turn the sound off and on.
Wow, what a great group. Thanks for the quick response. I'm
actually trying to build (through Edit Function) a simple learning
module...not much beyond PPT (though I prefer Keynote!). Photos,
copy points, narration. Wanted to export as a SWF file for web use
(which I would be handled by some folks who actually know what
they're doing!). Is there a place you can point me which would walk
me through assigning functions to the Flash skins?
I'm thinking you may have interpreted what I said as meaning
you need to resort to Flash to accomplish this. You don't. All you
have to do is to click Project > Skin... and make sure there is
a check mark in the "Mute" check box.
Unless I'm misunderstanding, which is always a possibility!
May I add a note on the playback controls thought: If you
choose the bmp playback controls, they will be placed overtop the
video playback area (video viewing area). If you choose the flash
playback controls, they will be outside the playback area. This may
be useful information is you have playback area size
limitations.
I think you may be a bit misinformed. It's not the fact the
control type is bitmap that makes the control overlap the play
area. It's the fact
Borders are enabled or disabled that governs this.
The bottom line is that even if you use Bitmap controls, as
long as you are using the Borders feature they will still be
outside the main part of the movie.
