Hi all,
Our company has recently upgraded to windows 10, and we are seeing a large amount of crashes with Acrobat Reader DC.
The crashes are repeatable on the Continuous Release - version 2018.009.20044
The crashes are not tied to particular documents but occur at random, typically while users are opening and closing multiple documents.
The fault module is consistently StackHash_####
Searching the forums there are some old threads about StackHash, but I haven't been able to locate a fix.
The install has been repaired, crashes persist.
Version=1
EventType=APPCRASH
EventTime=131570775179703652
ReportType=2
Consent=1
UploadTime=131570775183350183
ReportIdentifier=82b5efd1-dadf-11e7-8bb9-f8633f4ef19b
IntegratorReportIdentifier=3690d8fa-1ecc-43f1-8b10-ade633dc5a9d
WOW64=1
NsAppName=AcroRd32.exe
AppSessionGuid=000032c0-0001-002f-53f0-649aeb6ed301
TargetAppId=W:00069122786c41ef650bd4c12d9a1c6c8fb300000904!0000897f79d95a8c3d9e3a78830615f1cee079bfafd2!AcroRd32.exe
TargetAppVer=2017//11//04:20:06:42!22a6b5!AcroRd32.exe
BootId=4294967295
Response.BucketId=3eb474f9302376531fd4fb696037766b
Response.BucketTable=1
Response.LegacyBucketId=2293734540242810475
Response.type=4
Sig[0].Name=Application Name
Sig[0].Value=AcroRd32.exe
Sig[1].Name=Application Version
Sig[1].Value=18.9.20044.55097
Sig[2].Name=Application Timestamp
Sig[2].Value=59fe1dd2
Sig[3].Name=Fault Module Name
Sig[3].Value=StackHash_0533
Sig[4].Name=Fault Module Version
Sig[4].Value=10.0.14393.1715
Sig[5].Name=Fault Module Timestamp
Sig[5].Value=59b0d8f3
Sig[6].Name=Exception Code
Sig[6].Value=c0000374
Sig[7].Name=Exception Offset
Sig[7].Value=PCH_38_FROM_ntdll+0x0006EB2C
Any help would be greatly appreciated.
James
Hi James,
Could you try installing the latest patch (18.009.20050) for Reader and check if that resolves the issue? To download the patch, click check for updates under help menu. You may also download the update manually using this link: 18.009.20050 Optional update, November 29, 2017 — Acrobat and Adobe Reader Release Notes
Reboot the machine once and try again.
Let us know if that helps.
Shivam
Hi Shivam,
I updated to 18.009.20050 and opened a bunch of pdf documents, I received a message that I had opened the maximum number of concurrent documents, closed a few, opened few more and browsed around. This seemed to be better performance.
I exited Adobe Reader, and selected close all documents. Adobe began closing each tab, however before finishing I got the "(not responding)" message in the title bar for a few moments then Adobe crashed.
Looking at Windows Error Reporting logs shows the stackhash error once again.
Version=1
EventType=APPCRASH
EventTime=131574291061801912
ReportType=2
Consent=1
UploadTime=131574291065434242
ReportIdentifier=1d98d5fa-de12-11e7-8bb9-f8633f4ef19b
IntegratorReportIdentifier=fb341e58-c636-47f0-a83a-766f9c9cf783
WOW64=1
AppSessionGuid=000001c0-0001-002f-29cb-f3e51d72d301
TargetAppId=W:00066861560bb7e3985e0bd61e0e9257c86200000904!000014c10eb00e59cb9407b94a4a119636cead1cb4dc!AcroRd32.exe
TargetAppVer=2017//11//27:20:21:25!2281e6!AcroRd32.exe
BootId=4294967295
Sig[1].Value=18.9.20050.57426
Sig[2].Value=5a1c73c5
Sig[3].Value=StackHash_560e
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=10.0.14393.2.0.0.256.125
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=3081
DynamicSig[22].Name=Additional Information 1
DynamicSig[22].Value=560e
DynamicSig[23].Name=Additional Information 2
DynamicSig[23].Value=560e23789839283ed968ed4d135072a3
DynamicSig[24].Name=Additional Information 3
DynamicSig[24].Value=64f4
DynamicSig[25].Name=Additional Information 4
DynamicSig[25].Value=64f45f43c5431d710138e329c5125774
UI[2]=C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AcroRd32.exe
Kind regards,
James
Thanks for the information, James.
Please try following troubleshooting steps:
1- Uninstall Reader using cleaner tool which you can download from here: Download Adobe Reader and Acrobat Cleaner Tool - Adobe Labs
2- Reboot the machine,
3- Download Reader DC from here: Adobe - Adobe Acrobat Reader DC Distribution
4- Reboot the machine and try again.
Keep us posted with the results.
Shivam
Hi Shivam,
I've run the cleaner and reinstalled.
I put adobe reader dc through it's paces and didn't notice a crash, however looking at my event logs I can see the cleaner application reported a crash which isn't too encouraging. I will deploy this to one of our impacted users to see if they see any improvement.
Version=1
EventType=APPCRASH
EventTime=131582043762128206
ReportType=2
Consent=1
UploadTime=131582043765309466
ReportIdentifier=2edd3567-e51f-11e7-8bbf-f8633f4ef19b
IntegratorReportIdentifier=902e622f-ffbe-4eae-bddf-cdc6e06cdf61
WOW64=1
NsAppName=AdobeAcroCleaner_DC2015.exe
AppSessionGuid=00002374-0001-0035-25fd-93c52b79d301
TargetAppId=W:000698c5a26fe66a4427e9e996335239b99a00000904!000095e1746b53edb3fca3db0f1de01f6a215730304b!AdobeAcroCleaner_DC2015.exe
TargetAppVer=2015//07//03:02:47:00!22bd16!AdobeAcroCleaner_DC2015.exe
BootId=4294967295
Response.BucketId=c5e964f48ea65d5969c85585b93adfc0
Response.LegacyBucketId=109136295072
Response.type=4
Sig[0].Value=AdobeAcroCleaner_DC2015.exe
Sig[1].Value=4.0.0.15957
Sig[2].Value=5595f7a4
Sig[3].Value=StackHash_eace
Sig[7].Value=PCH_24_FROM_ntdll+0x0006EB2C
