Hello experts - I'm trying to create a blue & white image from a colour photo I took (of Manhattan skyline at night). What I'd like to do is turn it black and white, invert it (so that the lights of the buildings and windows become black dots) and then replace the black in the photo with a mid-blue.
I've tried 'replace colour', but when I change the black to blue it doesn't seem to work - the black just goes grey.
What am I doing wrong? Your help and expertise hugely appreciated on this...
As an alternative to Derek's approach you could use a gradient map adjustment layer.
Dave
Please post the name of the program you use so a Moderator may move this message
-A program would be Photoshop or Dreamweaver or Muse or Premiere Pro or ???
Hi John - thanks for the heads-up! I'm using Photoshop.
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
[Moved from generic Cloud/Setup forum to the specific Program forum... Mod]
Convert your image to grayscale mode then convert it to duotone then and select the second color.
Dave
1. Open the image. Choose your Foreground Color of Blue
2. Image > Adjustments > Invert
3. Edit > Fill > Foreground Color... with Blending Mode Set to: Color
Norman, you didn't use LAB mode!!!
Trevor, you are not going to believe this, but I did!
Made the dupe layer, switched to LAB and transposed the Lightness curve.
Then came back to RGB for the Fill with the same blue and compared them.
Very minor difference. Since the one I posted took fewer steps, I used that one.
But rest assured, Lab Man is back!
(It bugged me not to be able to use it last night with that Polar Coordinate post.)
JM88​ - I love norman.sanders answer, but when I read your original question, it appears to me that you went to black and white using the Image>Mode>Grayscale menu option. That will result in you ONLY being able to get variations of gray, no matter what color you pick.
Derek Cross and davescm have some excellent options, using your start from RGB, but one other option might be to invert your original layer, and use a Black and White adjustment layer, with TINT turned on, then adjust your color to taste. I don't currently have the perfect image for this, but perhaps you can infer what I mean by this screenshot:
Many, many thanks all. For my particular image, davescm's gradient map technique worked particularly well.
Hugely appreciated - may you all find fifties on the pavement tomorrow.
Haha - you're welcome
Dave
