Hello.
For several weeks I ran my Lightroom Slideshow on an old iPad. This worked great as a digital photo frame until... the Slideshow suddenly stopped repeating.
I believe what is happening is the slideshow is running through the photos once, then exiting. What I want is for the slideshow to repeat indefinitely. This used to be normal, not I can't seem to get it to work this way. Is there a way to run a Lightroom Mobile Slideshow 'forever'?
Steve
Is this what you are looking for?
The setting you point to is in Lightroom CC. I'm trying to play the slideshow from a mobile device (iPad) using Present, then Play. I don't see this same setting on the iPad version. Is it there and I just can't find it?
Steve
That screen capture is from Lightroom CC CLASSIC - Not Lightroom CC
Thanks for the clarification. I think Adobe made a mistake with their names creating confusion. But, if I understand, you are suggesting that if i make this change on the web, the slideshow on the iPad should repeat, correct? I will try that. Thanks.
Steve
