Templates
Dec 17, 2008 Dec 17, 2008
I am trying to apply a template in the topic view. I select any number of files from 5 to 100 files. After I apply the template it does not stick. Selecting a smaller number of files seems to work better. Selecting one file at a time never is a problem.
The project does have 2000 files in one directory.
Thoughts?
Using RH7, XPSP2
J
684
I don't know for sure but it looks like you have answered your own question.
Guest
Dec 23, 2008 Dec 23, 2008
If the topics have a template applied already why not alter that and/or the stylesheet?
They don't.
I might test the number of files in the directory to see if that makes a difference.
The number of files shouldn't be an issue, although I guess it may depend on exactly how many. Maybe you'd want to try adding the tag below to the meta data in the truecode for each topic. Just use a good find and replace tool. FAR and Bk ReplaceEm are just two. Don't forget to take a backup before doing anything and change templatefilename.htt to the file name of your template.
<meta name="template" content="templatefilename.htt">
I like the idea. Why not use the find/replace that is in RH?
Have you ever used it? It has rather limited functionality One of the advantages of the tools I mention is that they work across multiple lines of HTML code and provide a lot more flexibility (e.g. text starting with, ending with, containing). Bk ReplaceEm is even freeware!
Thanks to Peter for making me realise that 2000 files in one folder is not good practice. I skipped reading that line 😉 So maybe that is an issue after all.
There actually is 3,300 files. It is bad practice because?
RH keeps track of all files and folders, partly in the CPD file and partly in the FPJ. There is a possibility, no more, that this unusally high number in one folder could corrupt one or the other.
There is no limit in theory to the number of files in a project but when I was splitting up a monster (10,000 files) I found that above 4,000 was not unusable but there was a performance difference. Of course, the machine used will impact on that.
Could you import say twenty topics into a new project and then see if that number will stick there when it would not in this project?
Maybe I should have said it is not what I would have done rather than it is bad practice - sorry it is late in the day here! Perhaps I could ask how long the project takes to open with that many topics. I used to maintain a project with 1200+ topics and it took upwards of 10 minutes. It also makes for difficulties with navigation and linking as some RH dialogs are so darn small that you only see a few topics at a time.
With that many files, I consider using merged help and/or using a folder structure inside the project that mirrors the TOC books.
RoboHelp Documentation
Download Adobe RoboHelp
