Because of the memo field you note in your summary, is it
safe to assume this is an Access DB? If this is an Access DB, is
there a particular benefit to running this sort of filter at the DB
level?
In my previous experience, MS Access was not only a slower
database (than SQL Server or MySQL, for example). but it isn't a
true database server and easily locks up when experiencing higher
loads.
It might be easier, and without any significant a
performance, to manipulate the article body content/string in CF.
<cfquery name="rs" datasource="#dsn#>
select article_id, article_body
from articles
where article_id = #id#
</cfquery>
Once you get the record you want, you can use a variety of
ColdFusion's string functions (see live docs for more options) to
pull the section you want from the article_body.
<cfscript>
// quick and dirty -- certainly more effective ways
readMorePos =
ReFindNoCase("id=systemreadmore",rs.article_body);
readMoreBody = RemoveChars(rs.article_body,1,readMorePos-1);
</cfscript>
<cfoutput>
#readMoreBody#
</cfoutput>
