Locked
1
testing apps in iPhone X simulator
Participant ,
Oct 19, 2017 Oct 19, 2017
We can't test our apps in iPhone X simulator from Animate CC 2017 and AIR 27 BETA, someone told me that AIR doens't makes something 64-bit or something (sorry for my poor explanation..), thing is, how could we test this?
As I've only worked with Animate and AIR, I don't know other ways to put .app on simulator than straight from Animate option "test in iOS simulator"
thanks!
Air beta
5.1K
Engaged ,
Adobe need to update simulator builds from 32bit to 64bit as XCode Simulator now only supports 64bit
In the meantime you could try a remote device testing lab such as offered by browserstack.
Android and iOS Mobile App Testing on Remote Device Lab
Adobe Employee ,
Oct 23, 2017 Oct 23, 2017
This issue is known to us and we are working on it. We will keep you posted.
Ankit | Adobe AIR Engineering
Participant ,
nice thanks, I'll try!
Contributor ,
Do they have iPhone X devices available?
Participant ,
Dec 03, 2017 Dec 03, 2017
So SDK 28 fix this, but in XCode 9, when I send the app to test it in the iOS simulator, it opens with iPhone  and when I choose another device from menu, it opnes a new one, but the iPhone 6 is the only one with the app in it!
How can I change the device? I'm only using Animate 2018 an dSDK 28
thanks
Adobe Employee ,
You can use command line to install and launch your app on iPhone X simulator. Please refer this page for the steps to be followed: Adobe AIR * Device simulation using the iOS Simulator .
Use the command:
export AIR_IOS_SIMULATOR_DEVICE = 'iPhone X' for using iPhone X simulator.
Pravishti | Adobe AIR Engineering
Dec 21, 2017 Dec 21, 2017
I'm on macOS 10.13.1 and when I run:
I get:
-bash: export: `=': not a valid identifier
-bash: export: `iPhone X': not a valid identifier
Where does that command need to go, or how do I use it?  Seems to have no effect.
I've also tried:
which seems to set the environment variable, but it has no effect as when I build and install, it still launches on default iPhone 6 device...
Help?
Replying as I found the fix.  The spaces were causing an issue.  Use the command without any spaces and double quotation marks like so:
export AIR_IOS_SIMULATOR_DEVICE="iPhone X"
and it's working for me with AIR 28
Contributor ,
Jan 15, 2018 Jan 15, 2018
To get a list of possible simulator devices from Xcode that can be used with AIR_IOS_SIMULATOR_DEVICE, use this command in the MacOS terminal:
xcrun simctl list devices
Participant ,
Jun 29, 2018 Jun 29, 2018
I have tried this in various iterations of spaces and quote marks but not working for me with Air 30.0 sadly
