Hey all - Any advice on the following?
Every time I try and create a photomerge panorama (file>automate>photomerge), I get a file called "tmp00001" after selecting the images I want to merge together. (See attached)
The images I'm trying to combine are JPGs.
Would love some help fixing the issue.
You show Photomerg's Dialog you need to select several image files(more than one) using the options in the dialog like browse. After thet you check the options you want to use and then click OK to run the script.
Have you tried opening the files and then choosing Add Open Files?
It is possible that one of your files is corrupted.
Are they single-layer files?
