I have a font I’d like to use on a website (Latina). I bought both the desktop and web version, I have already installed the desktop font.
This is a file of one of the font styles for the web font:
When I draw all of my files in the self host area, this window shows up:
(it says: "66 web fonts were found!")
So long evverything is fine. Now this shows up:
So the first problem is, that Muse doesn't take the regular italic. All the other ones have the green check.
The second and way bigger problem is this one:
So of the 22 different font styles I dragged in, only 5 show up. I actually don't need all of them, but Muse doesn't take the italic and the non-italic style at one time. To be precise: I need at least the bold, thin and regular and the italic one as well, but Muse only takes one of them, even if I do the same hosting thing with only one font style after another. And as you can also see on the last screen shot: the name says f. e. "Bold" but the bold italic ist shown on the right.
So what am I doing wrong? I hosted another font some months ago and there weren't any problems at all.
Thanks.
maybe if you install a demo version first then the actual files but I don't see why this would only bugger up Mac users and work in Windows?
at this stage I think Adobe and Frontspring have to do more testing before we will get a solid answer one way or the other
I would assume its not a full set i.e, some of the symbols are missing?
You mean that the number of characters is different from style to style?
I almost have the same problem. I try to host a purchased webfont in adobe muse, but it doesn't work. I get a maximum of 2 fonts displayed although I install 12. The 2 fonts are displayed incorrectly. Adobe can you please fix the bug!?
for better understanding I made a short video:
[video removed by ussnorway because it is locked]
Adobe has nothing to do with the hosting of 3rd party fonts... that is the job of your host server
Hey, I'll try to explain it better:
I followed exactly the guidelines of this tutorial from Adobe:
https://helpx.adobe.com/muse/how-to/add-self-hosted-web-fonts.html
It worked so far.
Everything was detected and installed (woff, eos, svg, otf).
But here's my real problem:
The system font is completely displayed and works.
If I now want to use this font as a webfont it only shows me 2 font styles in the Textmenu of Muse.
I think it's a flaw in adobe and not a third one.
Here again a short video showing the bug (I hope you can see it this time):
Adobe Muse — self hosted webfonts bug - YouTube
Greetings, Paul.
You are saying: „I have already installed the desktop font“.
Did you install exactly the Latina TTF, which came with your web font package, of means „already“, that you have installed the desktop font before?
If so, did you have a look into your font collection and deinstall all former versions of Latina in whatever font format (Type 1, otf, …)?
I bought a complete font family from Fontspring. All fonts and additional file formats are installed in Muse. It's all right up to here.
I've tried OTF and after a new installation I tried it again with TTF.
both unsuccessfully.
Nor do I get an error message in Muse. On the contrary, I even get the green hook. But as soon as I want to select my installed fonts in the text window under Web fonts, it always shows with only 2 fonts.
When I go back to adding/removing web fonts now to manage my font, it will only show me 2 fonts.
This doesn‘t answer my question completely: Is there installed the same font in different formats — not in Muse (that isn‘t possible), but in your system?
Unfortunately I can‘t check this in detail, because I don‘t own this specific font.
I have completely uninstalled all fonts again. (also in the system).
Then I did it again as they described it.
Once with the OTF format and after uninstalling again, I tried again with the TTF format.
Both attempts were unsuccessful.
I happen to have a licence for "molde reverse" if you want to test that?
p.s, I see he only has basic language support... is German covered by that?
I have now tried again with other settings when downloading the font from Fontspring.com.
Here the settings in Fontspringeditor:
Muse shows me the fonts in the textmenu but now the wrong font styles are shown. I inserted them all manually and made sure to choose the right ones:
when I go back to the menu "add/remove web fonts" it shows me only 2 fonts again:
I will test other fonts now to find out if it's the typeface "molde" or if it's a bug of adobe muse.
first but thank you very much for your support! i will be in touch again. merry christmas.
No file, no help – unfortunately. The screenshots don’t help at all.
Ussnorway: Would be nice, it you send me your „Molde Reverse“ for testing reasons. You find my email address in a private message!
done
+ my self hosted on Adobe bc test = text
I am facing some issues with the font "Molde Regular" to UssNorway:
The font file „molderegularreverse.otf“ works fine in all applications, but the system font doesn’t show up in Muse’s font menu.
Therefore I can install the .woff and .eot fonts, but Muse alerts the missing system font.
Here the Muse font menu along with the Mac’s system font menu:
have you tried a system restart i.e, shut the Mac down and boot back up?
Yes, but this isn’t necessary on a Mac. Fonts – web fonts too – are definitely and always installed and activated „on the fly“.
yes Muse should see any system font "on the fly"
Coming from high quality print design, I am very acquainted to font handling. Believe me, I tried to restart the computer, circumvent font managing software, clear font caches and all other sort of tricks, but "Molde Regularreverse" doesn’t appear in Muse’s font menu. It show up instantly in all other font menus (InDesign, Illustrator, Pages,… whatever you want), but not in Muse. Perhaps a Mac only issue?
I think, this is a question for the Muse team, what do you think Preran or ankushr40215001?
I beleave Ankush is in charge right now
I download the font demos on fontspring, 162 in total and the metadata is all messed up.
After fixing the metadata
Which „metadata“?
How „fixing the metadata“?
I'm using Transtype to edit the font metadata and I'm talking about the font weight. All the Molde expanded font fontweight is set to Extrabold. You can also edit the font width and the styling group so they can be listed under the same family name.
Fixed Molde Expanded
the demos are all set the same because they are just demos... when you pay | download the actual fonts they are set correct
Ussnorway: If the font metadata are mixed up (in demo-version), this may help to explain the misbehaviour, which the original poster is encountering.
