I am facing issue with video component. i am using video component is mask layer, . below code contain xfl format of masked video component.
<DOMSymbolItem xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://ns.adobe.com/xfl/2008/" name="Condition Zoom" itemID="516d7885-0000361a" symbolType="graphic" lastModified="1514264849" lastUniqueIdentifier="1">
<persistentData>
<PD n="CreateJSToolkit_timelinedata" v="version
0.1
loop
true"/>
</persistentData>
<timeline>
<DOMTimeline name="Condition Zoom" currentFrame="72" guides='<guidelines><guideline direction="h">-124</guideline><guideline direction="h">-139</guideline></guidelines>'>
<layers>
<DOMLayer name="Animation Blank" color="#4FFF4F" locked="true" outline="true" useOutlineView="true" autoNamed="false" layerType="mask">
<frames>
<DOMFrame index="0" duration="193" keyMode="9728">
<elements>
<DOMShape>
<fills>
<FillStyle index="1">
<SolidColor color="#99CC66"/>
</FillStyle>
</fills>
<edges>
<Edge fillStyle1="1" edges="!6200 -5033|6200 -1945!6200 -1945[6200 -1856 6134 -1787!6134 -1787[6066 -1716 5973 -1718!5973 -1718|2638 -1718!2638 -1718[2552 -1718 2483 -1784!2483 -1784[2411 -1853 2411 -1945!2411 -1945|2411 -5033!2411 -5033[2411 -5123 2480 -5192!2480
-5192[2549 -5261 2638 -5260!2638 -5260|5973 -5260!5973 -5260[6057 -5261 6131 -5182!6131 -5182[6200 -5109 6200 -5033"/>
</edges>
</DOMShape>
</elements>
</DOMFrame>
</frames>
</DOMLayer>
<DOMLayer name="Animation Blank" color="#9933CC" parentLayerIndex="0" locked="true" current="true" isSelected="true" autoNamed="false">
<frames>
<elements>
<DOMComponentInstance libraryItemName="Video" selected="true" uniqueID="1">
<matrix>
<Matrix a="0.75" tx="58" ty="-319.95"/>
</matrix>
<transformationPoint>
<Point x="200" y="150"/>
</transformationPoint>
<parametersAsXML><![CDATA[ <property id="src">
<Inspectable name="source" variable="src" category="" verbose="0" defaultValue="C:\Users\selvamt\Downloads\untitled.mp4" type="Video Content Path"/>
</property>
<property id="autoplay">
<Inspectable name="autoplay" variable="autoplay" category="" verbose="0" defaultValue="true" type="Boolean"/>
</property>
<property id="controls">
<Inspectable name="controls" variable="controls" category="" verbose="0" defaultValue="true" type="Boolean"/>
</property>
<property id="muted">
<Inspectable name="muted" variable="muted" category="" verbose="0" defaultValue="false" type="Boolean"/>
</property>
<property id="loop">
<Inspectable name="loop" variable="loop" category="" verbose="0" defaultValue="true" type="Boolean"/>
</property>
<property id="poster">
<Inspectable name="poster image" variable="poster" category="" verbose="0" defaultValue="" type="Image Path"/>
</property>
<property id="preload">
<Inspectable name="preload" variable="preload" category="" verbose="0" defaultValue="true" type="Boolean"/>
</property>
<property id="class">
<Inspectable name="class" variable="class" category="" verbose="0" defaultValue="video" type="String"/>
</property>
<property id="__ComponentType__">
<Inspectable name="__ComponentType__" variable="__ComponentType__" category="" verbose="0" defaultValue="1" type="Number"/>
</property>
]]></parametersAsXML>
</DOMComponentInstance>
</elements>
</DOMFrame>
</frames>
</DOMLayer>
<DOMLayer name="Layer 2" color="#9933CC" locked="true">
<frames>
<elements>
<DOMGroup>
<members>
<DOMShape>
<fills>
<SolidColor color="#FFFFFF"/>
</FillStyle>
</fills>
<edges>
!6184 -5234[6255 -5158 6255 -5081!6255 -5081|6255 -1897!6255 -1897[6255 -1805 6187 -1734!6187 -1734[6117 -1661 6021 -1663!6021 -1663|2583 -1663!2583 -1663[2494 -1663 2423 -1731!2423 -1731[2349 -1803 2349 -1897!2349 -1897|2349 -5081!2349
-5081[2349 -5174 2420 -5245!2420 -5245[2491 -5315 2583 -5315!2583 -5315|6021 -5315!6021 -5315[6108 -5315 6184 -5234"/>
</edges>
</DOMShape>
</members>
</DOMGroup>
</elements>
</DOMFrame>
</frames>
</DOMLayer>
<DOMLayer name="Layer 3" color="#FFFF4F" autoNamed="false">
<frames>
<elements>
<DOMShape>
<fills>
<LinearGradient>
<matrix>
<Matrix a="0.0246124267578125" b="-0.0918121337890625" c="0.0215301513671875" d="0.020294189453125" tx="66.5" ty="-45.4"/>
</matrix>
<GradientEntry color="#FFFFFF" alpha="0" ratio="0"/>
<GradientEntry color="#FFFFFF" ratio="1"/>
</LinearGradient>
</FillStyle>
</fills>
<edges>
<Edge fillStyle0="1" edges="
!1101 -601/3636 -1663!3636 -1663/2745 -1678!2745 -1678/1101 -601"/>
<Edge cubics="!2745 -1678(;2745,-1678 1144,-256 1144,-256q2745 -1678 1144 -256);"/>
<Edge cubics="!1144 -256(;1144,-256 3636,-1663 3636,-1663q1144 -256 3636 -1663);"/>
<Edge cubics="!3636 -1663(;3636,-1663 2745,-1678 2745,-1678q3636 -1663 2745 -1678);"/>
</edges>
</DOMShape>
</elements>
</DOMFrame>
</frames>
</DOMLayer>
</layers>
</DOMTimeline>
</timeline>
</DOMSymbolItem>
below line is in DOMDOCUMENT.xml
<DOMBitmapItem name="____componentassets____/Video" itemID="5a41d570-0000052c" sourceLastImported="1498768008" externalFileSize="583" allowSmoothing="true" useImportedJPEGData="false" compressionType="lossless" originalCompressionType="lossless" quality="50" href="____componentassets____/Video.png" bitmapDataHRef="M 2 1514263909.dat" frameLeft="6980" frameTop="5720" frameRight="7620" frameBottom="6360"/>
I can see video.js in the path "components\video\src"
After converting to HTML5 canvas,video component is not masked, i want center of the video should be shown and other portions should be masked . Below script code shows the masked layer and video component.
(lib.ConditionZoom = function(mode,startPosition,loop) {
this.initialize(mode,startPosition,loop,{});
// Animation Blank (mask)
var mask = new cjs.Shape();
mask._off = true;
mask.graphics.p("ANCN1I6DAAQgrAAgighQgkgiAAguIAA4HQAAgtAigjQAjgiAsAAIaDAAQAqAAAlAnQAiAlAAAmIAAYHQAAAsghAjQghAjgtAAIgCgBg");
mask.setTransform(215.3,-174.4);
// Animation Blank
this.instance = new lib.an_Video({'id': '', 'src':'videos/untitled.mp4', 'autoplay':true, 'controls':true, 'muted':false, 'loop':true, 'poster':'images/', 'preload':true, 'class':'video'});
this.instance.setTransform(208,-169.9,0.75,1,0,0,0,200,150);
var maskedShapeInstanceList = [this.instance];
for(var shapedInstanceItr = 0; shapedInstanceItr < maskedShapeInstanceList.length; shapedInstanceItr++) {
maskedShapeInstanceList[shapedInstanceItr].mask = mask;
this.timeline.addTween(cjs.Tween.get(this.instance).wait(193));
// Layer 2
this.shape = new cjs.Shape();
this.shape.graphics.f("#FFFFFF").s().p("ANbORI62AAQgsAAgkgiQglgkAAgvIAA43QABgvAjgjQAkgjAtAAIa2AAQAsAAAmAoQAjAmABAnIAAY3QAAAugjAjQgiAkguAAIgDAAg");
this.shape.setTransform(215.1,-174.4);
this.timeline.addTween(cjs.Tween.get(this.shape).wait(193));
// Layer 3
this.shape_1 = new cjs.Shape();
this.shape_1.graphics.lf(["rgba(255,255,255,0)","#FFFFFF"],[0,1],-72,86.8,-31.7,-63.6).s().p("AC8kMIG+AHIzzISg");
this.shape_1.setTransform(118.4,-57);
this.timeline.addTween(cjs.Tween.get(this.shape_1).wait(193));
}).prototype = p = new cjs.MovieClip();
p.nominalBounds = new cjs.Rectangle(55.1,-265.7,257.7,235.7);
Posting generated and built-in code is not helpful.
You can't mask components in Canvas mode.
But there are some workarounds available:
i think you misunderstand the issue, i want to hide half of the video, i.e., i want to show only the heart portion, other portion should not be visible. it is not masking the video , what is the workaround for this?
where i have to add the line "dom_overlay_container.style.zIndex = -1;"
