Hi Flex Community,
I have a web service with a SOAP response (XML Document) and
store the result in a XMLList. Here the SOAP response:
<method:ReportListResponse xmlns:xsd="
http://www.w3.org/2001/XMLSchema"
xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance"
xmlns:SOAP-ENV="
http://schemas.xmlsoap.org/soap/envelope/"
xmlns:sql="
http://schemas.microsoft.com/sqlserver/2004/SOAP"
... xmlns:method="
http://<servername>/Server
Objects/Endpoints/SOAP">
<method:ReportListResult>
<sqlresultstream:SqlRowSet
xsi:type="sqlsoaptypes:SqlRowSet"
msdata:UseDataSetSchemaOnly="true"
msdata:UDTColumnValueWrapped="true">
<xsd:schema targetNamespace="
http://schemas.microsoft.com/sqlserver/2004/sqltypes">
<xsd:simpleType name="varchar">
<xsd:restriction base="xsd:string"/>
</xsd:simpleType>
</xsd:schema>
<xsd:schema
targetNamespace="urn:schemas-microsoft-com:sql:SqlRowSet1"
elementFormDefault="qualified">
<xsd:import namespace="
http://schemas.microsoft.com/sqlserver/2004/sqltypes"/>
<xsd:element name="SqlRowSet1" msdata:IsDataSet="true"
msdata:DataSetNamespace="urn:schemas-microsoft-com:sql:SqlDataSet"
msdata:DataSetName="SqlDataSet">
<xsd:complexType>
<xsd:sequence>
<xsd:element name="row" minOccurs="0"
maxOccurs="unbounded">
<xsd:complexType>
<xsd:sequence>
<xsd:element name="NAME" minOccurs="0">
<xsd:simpleType>
<xsd:restriction base="sqltypes:varchar"
sqltypes:localeId="1033" sqltypes:sqlCompareOptions="IgnoreCase
IgnoreKanaType IgnoreWidth" sqltypes:sqlSortId="52">
<xsd:maxLength value="255"/>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:schema>
<diffgr:diffgram
xmlns:diffgr="urn:schemas-microsoft-com:xml-diffgram-v1">
<SqlRowSet1
xmlns="urn:schemas-microsoft-com:sql:SqlRowSet1">
<row>
<NAME>OTTO</NAME>
</row>
<row>
<NAME>ANNA</NAME>
</row>
</SqlRowSet1>
</diffgr:diffgram>
</sqlresultstream:SqlRowSet>
<sqlresultstream:SqlRowCount
xsi:type="sqlrowcount:SqlRowCount">
<sqlrowcount:Count>
31
</sqlrowcount:Count>
</sqlresultstream:SqlRowCount>
<sqlresultstream:SqlResultCode
xsi:type="sqlsoaptypes:SqlResultCode">
</sqlresultstream:SqlResultCode>
</method:ReportListResult>
</method:ReportListResponse>I want to select the needed rows and output the results in a
datagrid:
private function webServiceResult(event:ResultEvent):void
trace("Ergebnis erhalten");
// create a XML object for result
var ResultXML:XML = (XML)(event.result);
//var th:Namespace = ResultXML.namespace();
//ResultXML.setNamespace(th);
// search the xml structure an d find the SqlRowSet1 tag
var sqlSet:XMLList = ResultXML.descendants("row");
trace("test=" + ResultXML.toString());
var ResultRows:XMLList = ResultXML.elements("NAME");
// output the identified rows
trace("#rows=" + ResultRows.length());
dataGridItems.removeAll();
// put all identified items ...
for each(var item:XML in ResultRows)
// ... in datagrid rows
dataGridItems.addItem(
COMPOUND_NAME: item.COMPOUND_NAME
<mx:DataGrid id="listRowsOutput"
dataProvider="{dataGridItems}" x="353" y="108" width="134">
<mx:columns>
<mx:DataGridColumn headerText="COMPOUND_NAME"
dataField="COMPOUND_NAME"/>
</mx:columns>
</mx:DataGrid>
The FlexBuilder has the xml structure but stores nothing in
the XMLList (Trace: rows = 0). Could anybody help me and describe
how I get the required tags?
Thx
