flash builder 4.7 crashes on mac os high sierra 10.13beta
and I cannot use simulator iphone X
and all function of it cannot work
I have problems with Flash Builder in High Sierra (release), too. It has crash when I click "Export Release Build" button.(((
do you have any solution
No, i have no any solution( so i am return Mac OS to Sierra (10.12).
How to return ?
You can make boot flash drive with Mac Os to install it, or you can push Command + R at mac startup and install it via internet.
I have this problem too;
I also get crash when i click on "Export Release build". Can someone maybe found solution for this ?
At this moment you can only
1) downgrade Mac OS to Sierra
or
2) migrate to another IDE
Maybe solution will be found in future...
Which another IDE i can use instead of FB?
I am migrate to IntelliJ Idea, it can import FB projects.
you can use FDT,I Have got a 7 day version of FDT,it really a good replacer of FB.
hi! IntelliJ Idea can Compile and debug on iOS device?
you can use IDEA too,but it compile slower than FDT.and FDT is Eclipse based similar with FB
I have the same compile time in FB and in Idea. You are using FDT with High Sierra? There is no any problems?
And about price:
IntelliJ Idea: 14.90 $ per month
FDT: 49 $ per month
P.S. I am check... Yes, Idea compile slower than FB (so, maybe than FDT, too).
yes, price is problem , so I am planing to buy a "FDT 4 Ever" License.
I also tangled this thing, Adobe is no longer support FB, the reality is the MacOS upgrade, Java is also upgrading, Eclipse is also upgrading, all kinds of things are upgrading, FB can not hold long, sooner or later.I also on IDEA, FDT, FlashDevelop were compared, feeling FDT more in line with our habits, the project changes are relatively small. Personally feel FDT is more professional,just personal opinion.
Thanks for the support but It seems that I can't run Flex Project in FDT ? It's desktop application and when I import in FDT i can't run it. can someone help me with setup ?
I am not develop Flex project,so I do not know how Flex project is in FDT , sorry .
Same issue here!
This is precisely what I was afraid of! No Solution from Adobe?! We need a workaround.
I have this problem too; No Solution from Adobe?
Adobe should fix this issue, since everything else compiles normally. I'm not sure if this is an issue from Adobe Flash Builder or somewhere else, however Exporting a Release is crashing. It is reproduceable on every MacOS High Sierra computer.
Hi @keigot I think that bug may be different, the issue in that eclipse bug is that the buttons are not enabled. In Adobe Flash Builder they are enabled, however only the Export Release crashes Flash builder instantly.
I have the same issue. MacOS High Sierra (10.13.1)
Flash Builder 4.7 Premium
Adobe Air 27, Flex SDK 4.6 (Air 27 overlay)
as soon as I choose Export Release Build the software crashes, However, making a debug build works fine.
anyone found a solution?
