Bonjour,
j'ai toujours la même erreur quand je publie, et la publication est très lente : "error animate CC publish :a script in file /Applications/Adobe Animate CC 2018/Adobe Animate CC 2018.app/Contents/Common/Configuration/Publish/Canvas/jsfl/LayerObj.jsfl"
Je suis sous mac OS High Sierra, avec la dernière version de Animate CC
Quelqu'un connaît ce type d'erreur ?
merci !
upload your problematic fla to a file server and post the link here.
are you seeing an out of memory error?
are you importing assets from illustrator or elsewhere?
non I don't have any memory error
And i have not imported assets from Illustrator, I have juste done a very simple animation - one line with a shape interpolation - ... nothing else.
there's something wrong with the blanche tween. delete the middle layer (calque_1) in that movieclip and recreate your tween.
thank you, i will be more careful - it's less obvious to work with canvas, thank you for taking the time to help me !
you're welcome.
p.s. if i were you i would just copy and past parts of that layer into another copy with that layer deleted until i pinpointed the problem and then just re-create that part.
