I need to call cmd command to get HDD serial. I will do it often so I need fast and invisible (without popup console window) solution.
This is perfect fast and invisible solution on MacOS. But user see popup console window on Windows
I will glad to know how to disable with popups windows. Do anybody know how?
var command="ping google.com";
var vbsFile = File(Folder.temp + '/aps_call.vbs');
vbsFile.open('w');
//vbsFile.write("chcp 1251\r\n");
vbsFile.write("Dim objShell\r\n");
vbsFile.write('Set objShell = WScript.CreateObject( "WScript.Shell" )\r\n');
vbsFile.write('objShell.Run "' + command + ' > ""' + decodeURI(tempFile.fsName) + '""", 0, True\r\n');
vbsFile.write('Set objShell = Nothing\r\n');
vbsFile.close();
vbsFile.execute();
$.sleep (200);
This is invisible but very slow solution. I don't know why execute method takes 2-3 seconds on my pc. May be somebody knows how do it faster.. )
Thanks for your attention and answers!
The modified code....
...#include "BasicExternalObject.h"
#include "SoSharedLibDefs.h"
#include <string>
#include <windows.h>
#include <stdio.h>
#include <iostream>
#if defined (_WINDOWS)
#pragma warning(disable : 4996) // Turn off warning about deprecated strcpy on Win
#endif
* \brief To allow string manipulation
using namespace std;
* \brief Utility function to handle strings and memory clean up
* \param s - The referenced string
static char* getNewBuffer(string& s)
// Dynamically allocate m
Windows 64bit only!
You could use Pauls modified External Lib example.
Files are here..
wikisend.com/download/806904
Place both files in the preset/ scripts folder.
The jsx gives a few basix examples, the system command will return data without opening a dos window.
Where can I find documentation for this? Is this library free?
Yes its free, the modified code can be found here.. Get Photoshop foreground color as RGB value
The original code (SDK) can be downloaded from Adobe... Bridge Developer Center
Thank you! But what about Winx86? I need support it too
Just recompile it then
Just compiled a 32bit version for you...
OK. I will try to use it. Thank you again
Sorry but .systemCmd shows cmd window. And I didn't find 'systemCmd' in documentation. May be it has more parameters..
Also I tries to use x86 version on x64 Windows and I got error of 'input-output'. Is it mean that I have to check WIndows type and have 2 libraries?
The documentation is the code itself, you might be able to amend it to suit your needs, maybe you could use CreateProcess instead of popen?
Yes it will be nice to use CreateProcess but sorry I'm still don't see modified code of this library. For example code of systemCmd. Can you send me project that you complied or link of it?
#include <string>
#include <stdio.h>
#include <iostream>
#endif
// Dynamically allocate memory buffer to hold the string
// to pass back to JavaScript
char* buff = new char[1+s.length()];
memset(buff, 0, s.length()+1);
strcpy(buff, s.c_str());
return buff;
extern "C" BASICEXTERNALOBJECT_API long systemCmd(TaggedData* argv, long argc, TaggedData* retval)
// The returned value type
retval->type = kTypeString;
// Accept 1 and only 1 argument
if(argc != 1)
return kESErrBadArgumentList;
// The argument must be a string
if(argv[0].type != kTypeString)
char* cmd = (argv[0].data.string);
FILE* pipe = _popen(cmd, "r");
if (!pipe) retval->data.string = "";
char buffer[128];
std::string result = "";
while(!feof(pipe)) {
if(fgets(buffer, 128, pipe) != NULL)
result += buffer;
_pclose(pipe);
retval->data.string = getNewBuffer(result);
return kESErrOK;
extern "C" BASICEXTERNALOBJECT_API long getClipboard(TaggedData* argv, long argc, TaggedData* retval)
HANDLE h;
if (!OpenClipboard(NULL)) return kESErrBadArgumentList;
h = GetClipboardData(CF_TEXT);
CloseClipboard();
if(h){
string text;
text = (char*)h;
if(text.length() < 1) return kESErrBadArgumentList;
retval->data.string = getNewBuffer(text);
}else{
return kESErrOK;
extern "C" BASICEXTERNALOBJECT_API long clearClipboard(TaggedData* argv, long argc, TaggedData* retval)
if (OpenClipboard(NULL)){
EmptyClipboard();
CloseClipboard();
return kESErrOK;
extern "C" BASICEXTERNALOBJECT_API long setClipboard(TaggedData* argv, long argc, TaggedData * retval)
if(argc != 1)
string source = (argv[0].data.string);
int len = source.length() +1;
source = source.c_str();
if(OpenClipboard(NULL))
HGLOBAL clipbuffer;
char * buffer;
EmptyClipboard();
clipbuffer = GlobalAlloc(GMEM_DDESHARE, len);
buffer = (char*)GlobalLock(clipbuffer);
strcpy(buffer, LPCSTR(source.c_str()));
GlobalUnlock(clipbuffer);
SetClipboardData(CF_TEXT,clipbuffer);
CloseClipboard();
return kESErrOK;
* \brief Free any string memory which has been returned as function result.
* \param *p Pointer to the string
BASICEXTERNALOBJECT_API void ESFreeMem (void* p)
delete(char*)(p);
* \brief Returns the version number of the library
* ExtendScript publishes this number as the version property of the object
* created by new ExternalObject.
BASICEXTERNALOBJECT_API long ESGetVersion()
return 0x1;
* \brief Initialize the library and return function signatures.
* These signatures have no effect on the arguments that can be passed to the functions.
* They are used by JavaScript to cast the arguments, and to populate the
* reflection interface.
BASICEXTERNALOBJECT_API char* ESInitialize (const TaggedData ** argv, long argc)
return "makeArray,getAverage,appendString_s,myScript_a,acceptBoolean_b";
* \brief Terminate the library.
* Does any necessary clean up that is needed.
BASICEXTERNALOBJECT_API void ESTerminate()
Receive an image file name and return coordinate values of non-black and white colors
How to modify :
#include <iostream>
#include <fstream>
#include <gdiplus.h>
#include <vector>
#pragma comment(lib, "gdiplus.lib")
using namespace Gdiplus;
extern "C" BASICEXTERNALOBJECT_API long my_getXY(TaggedData* argv, long argc, TaggedData * retval) {
Gdiplus::GdiplusStartupInput gdiplusstartupinput;
ULONG_PTR gdiplustoken;
Gdiplus::GdiplusStartup(&gdiplustoken, &gdiplusstartupinput, NULL);
wstring infilename(L"1.png"); //
Bitmap* bmp = new Bitmap(infilename.c_str());
UINT height = bmp->GetHeight();
UINT width = bmp->GetWidth();
Color color;
vector<int> arr_xy(0);
for (UINT y = 0; y < height; y++) {
for (UINT x = 0; x < width; x++)
bmp->GetPixel(x, y, &color);
if (((int)color.GetRed() != 255 && (int)color.GetGreen() != 255 && (int)color.GetBlue() != 255) && ((int)color.GetRed() != 0 && (int)color.GetGreen() != 0 && (int)color.GetBlue() != 0)) {
arr_xy.push_back(x); arr_xy.push_back(y);
long* array = new long[arr_xy.size()];
for (int i = 0; i < arr_xy.size(); i++)
array = arr_xy.at(i);
delete bmp;
Gdiplus::GdiplusShutdown(gdiplustoken);
return array; //
I used vbs and that didn't make 2 - 3 seconds delay: Re: UI: Remember last path entered
