Hello,
I am not sure how to correctly use Adobe Stock images ... For example here are three scenarios:
1) Modified image (Standard license) to use on Facebook, Social Media Channels
As far as I understand I can use this images without attribution, right?
2) Un-Modified image (Standard license) to use on a website
With or without attribution?
Enough to name the author on a separate credit page?
Or is it a must to overlay the image with attribution?
3) Modified image (Standard license) to use on a website
Quote from the Adobe Stock license terms page (License information and Terms of use | Adobe Stock 😞
Post the asset to a website with no limitation on viewers. If the asset is posted unmodified to a social media site, attribution is required (© Author Name - stock.adobe.com).
Thanks for helping,
A.
Hi Alexander,
As per the licensing terms, if the image is modified then the attribution is not necessary however, you can still give the author credits on a separate credit page which is an optional choice.
But if the image is unmodified, then the attribution is required over the image itself where it can be read in the provided format.
I apologize for the confusion caused here.
Sheena
Hi Alexander,
For more information, you may refer to Common Questions, Adobe Stock
Hope this information helps!
Feel free to update this thread in case of any additional questions.
Regards
Twarita
Hello twaritar3263062 🙂
thank you for answering, so you say the following (please correct if I miss-understand) ...
For website:
Un-Modified image (Standard license) to use on a website requires an attribution
Give the credit to the photographer on a separate credit page is allowed instead of an overlay credit text
Do I get this now right?
Now for Social Media , Facebook , etc. ... How to handle it here?
You wrote this:
twaritar3263062 wrote
- Under no condition can you use the assets without attribution be it modified or unmodified as it will then remove the rights from the Adobe Stock and thus a violation to the terms.
But why the terms page describe this in another way? Quote from the Adobe Stock license terms page: "... If the asset is posted unmodified to a social media site, attribution is required (© Author Name - stock.adobe.com) ..."
See Screenshot here: https://d.pr/i/TdOaGV+
So this means to me that I do not have to attribute the image if I modify it, right? FYI: This was also a feedback that I get from a support chat from Adobe staff. So what is right here? This is very confusing.
Best, A.
Hi Alexander,
Sheena
Hello Sheena Kaul,
okay so this is much clearer now - and you're totally right ... to credit authors on a separate credit page is: FAIR USE 🙂 no problem ... thanks for helping ...
Best, A.
You are welcome!
Hello,
I have also a question to this topic.
What does it mean to modifies an image (Standard license)? Is an image modified, when I put text, shapes, forms or somethings like that over the image? Does that mean modified?
I hope you can answer this question, because I find it very unclear what means modified and unmodified.
Christoph
Hi there,
The modification of the image means to edit the image in any form.
Any change made to the original file is considered a modification.
Sheena
Is resizing or cropping the image considered a modification?
You need to attribute, as long as your modification does not result in a new work that is interpreted as a different artwork.
So these are not image modifications that allow you omitting credits:
I've seen examples where I would say that attribution is not necessary. Those examples are highly edited pictures that are probably combined from multiple assets where none of the assets was recognizable without intimate knowledge of the editing that took place.
If in doubt, credit. For sure it does not harm to credit, but it may be a violation of the terms if you don't.
I look it in this way: if the assets would be mine, would I still ask for crediting or would the image be that different now that I would barely recognize my own work?
So you should give credit to the photographer for a modified image on a seperate page and not on the modified image?
Do you also need to indicate that you modified the image? or is okay to not state that?
