Slider control for shape layer fill colour
Dec 28, 2017 Dec 28, 2017
Hello, I'm trying to make a motion graphics template with colour as one of the options. Instead of the colour picker, I'd like to make it so it's on a slider and each number value is associated with a different colour. As of right now, I have a shape layer that is "parented" to a null object with the slider control effect on it.
Right now my expression code is:
slider = thisComp.layer("CONTROLS").effect("Slider Control")("Slider").value;
if (slider == 0)
  [48,26,23,0]
else if (slider == 1)
  [30,157,139,1]
else if (slider == 2)
  [0,122,135,1]
else if (slider == 3)
  [149,82,20,1]
But when I change the slider to each of the values (0-3). the shape layer isn't changing to the colour I want. It's changing between white and a bright blue and yellow, which aren't the values I've put in. I am using RGBA values.
Not sure what I'm doing wrong, can anybody help?
Expressions
3.6K
Community Expert , Dec 28, 2017 Dec 28, 2017
The color channel numbers need to be normalized (between 0 and 1), like this:
[149,82,20,255]/255
Dan
[149,82,20,255]/255
Dan
So you're saying it should be like this:
if (slider == 0)
  [75,69,44,1]/255
  [30,157,139,1]/255
  [0,122,135,1]/255
  [149,82,20,1]/255
else if (slider == 4)
  [234,171,0,0]/255
The last number of each set of four would be 255 (so that you end up with 1.0 for the alpha value):
[75,69,44,255]/255
although it probably works no matter what you have for the alpha value.
Jul 17, 2018 Jul 17, 2018
Hello,
I tried the same as rachgouveia, but I only need three colors (red, black en white).
I tried to use this expression code:
if (slider == 0)
  [0,0,0,255]/255
  [ 238,0,0,255]/255
  [255,255,255,255]/255
But I get this error:
Error at line 0 in property 'Color" of layer 1 ('COLOR CONTROL') in comp....
expression result must be of dimension 4, not 1.
What am I doing wrong?
Thanks in advance
In the meantime I could find a way.
I still don't know, where I went wrong with the first code, but now I've used this expression code and it works:
s = thisComp.layer("CONTROLS").effect("Slider Control")("Slider");
c1 = 0xFF2434; // red
c2 = 0xffffff; // white
c3 = 0x000000; // black
function hexToFloat(c){
  r = ((c & 0xff0000) >> 16)/255;
  g = ((c & 0xff00) >> 8)/255;
  b = (c & 0xff)/255;
  return [r,g,b,1];
if (s < 1)
  hexToFloat(c1)
else if (s < 2)
  hexToFloat(c2)
else
  hexToFloat(c3)
