After updating to version Photoshop 19.0 I keep getting "File can't open due to program error"I uninstalled and reinstalled 19.0, same thing happened. So I uninstalled again and installed Photoshop version 17.0.2. Same thing continues to happen.
If you have insight regarding my issue, please please help me!
Best
What file can not be open? An Image file, any image file? Post your Photoshop menu Help>system Info. Is it the same erre ib CC 2017 and cc 2018? What OS are you using.
Supply pertinent information for quicker answers
I can open image files (JPEG & PNG), but I cannot open a Photoshop PDF. It's happening for both 2017 and 2018, I'm running on Mac OS 10.13.2 (High Sierra). Thoughts?
System Info:
Adobe Photoshop Version: 2017.1.2 20171103.r.18 2017/11/03: 1143982 x64
Number of Launches: 0
Operating System: Mac OS 10.13.2
System architecture: Intel CPU Family:6, Model:61, Stepping:4 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 2
Logical processor count: 4
Processor speed: 1200 MHz
Built-in memory: 8192 MB
Free memory: 3847 MB
Memory available to Photoshop: 6297 MB
Memory used by Photoshop: 70 %
History Thumbnails: Enabled.
Touch Bar: Enabled.
Alias Layers: Disabled.
Modifier Palette: Disabled.
Highbeam: Enabled.
Image tile size: 128K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Main Display
High DPI Monitor
Display Bounds: top=0, left=0, bottom=800, right=1280
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=1
glgpu[0].GLVersion="2.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=1536
glgpu[0].GLName="Intel(R) HD Graphics 5300"
glgpu[0].GLVendor="Intel Inc."
glgpu[0].GLVendorID=32902
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="Intel(R) HD Graphics 5300"
glgpu[0].GLRendererID=16925953
glgpu[0].HasGLNPOTSupport=1
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[60]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2 (Oct 31 2017 18:19:43)"
clgpu[0].CLDeviceVersion="1.2 "
clgpu[0].IsIntegratedCLGPU=1
clgpu[0].CLMemoryMB=1536
clgpu[0].CLName="Intel(R) HD Graphics 5300"
clgpu[0].CLVendor="Intel Inc."
clgpu[0].CLVendorID=16925952
clgpu[0].CLDriverVersion="1.2(Nov 9 2017 18:56:42)"
clgpu[0].CLBandwidth=1.32179e+10
clgpu[0].CLCompute=157.656
nativegpu[0].NativeName="Intel(R) HD Graphics 5300"
License Type: Subscription
Serial number: 90970007335335776582
GUIDBucket:
bucket: 247
test: DocumentPanel
Application folder: /Applications/Adobe Photoshop CC 2017/
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 465.6G, 190.7G free
Required Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/
Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Plug-Ins/
Installed components:
dvametadata.framework dvametadata 10.0.0.0
AdobeXMPScript.framework AdobeXMPScript 79.159824 79.159824
ICUUnicode.framework ICUUnicode 3.61 "gtlib_6.0" "." "21287"
ICUConverter.framework ICUConverter 3.61 "gtlib_6.0" "." "21287"
AdobeCrashReporter.framework AdobeCrashReporter 7.3.2
boost_system.framework boost_system 10.0.0.0
AdobeUpdater.framework AdobeUpdater 6.0.0.1452 "52.338651"
AdobeACE.framework AdobeACE 2.20.02.37848 79.579975
AdobeOwl.framework AdobeOwl 5.2.11
mediacoreif.framework mediacoreif 10.0.0.0
manta.framework manta 2.0.00.1 1.
dvaunittesting.framework dvaunittesting 10.0.0.0
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.8.0.34320 79.562390
AIDE.framework AIDE 1.5.0.36540 79.574279
dynamiclink.framework dynamiclink 10.0.0.0
dvametadataUI.framework dvametadataUI 10.0.0.0
UpdaterNotifications.framework UpdaterNotifications 10.0.0.1 "10.0.0.1"
AdobeExtendScript.framework AdobeExtendScript 4.5.6.5 80.1089815
boost_filesystem.framework boost_filesystem 10.0.0.0
AdobeBIB.framework AdobeBIB 1.2.03.37848 79.579975
AdobeXMPFiles.framework AdobeXMPFiles 79.159824 79.159824
AdobeLinguistic.framework 22175
dvaplayer.framework dvaplayer 10.0.0.0
PlugPlugOwl.framework PlugPlugOwl 7.0.0.67
AdobeAGM.framework AdobeAGM 4.30.87.37848 79.579975
adobe_caps.framework adobe_caps 10.0.0.6 1.584361
AdobeSVGRE.framework AdobeSVGRE 6.0 88.588432
AdobePDFL.framework AdobePDFL 15.0.0.36975 79.195992
dvacore.framework dvacore 10.0.0.0
AdobePIP.framework AdobePIP 7.4.1.60.45263
AdobePDFSettings.framework AdobePDFSettings 1.4
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.8.0.34320 79.562390
dvatransport.framework dvatransport 10.0.0.0
Cg.framework NVIDIA Cg
boost_signals.framework boost_signals 10.0.0.0
AdobeXMP.framework AdobeXMPCore 79.159824 79.159824
AdobeJP2K.framework AdobeJP2K 1.2.2.38234 79.266006
dvaaudiodevice.framework dvaaudiodevice 10.0.0.0
LogSession.framework LogSession 7.4.1.60.45263
PlugPlugExternalObject.framework 7.0.0.67
AdobeScCore.framework AdobeScCore 4.5.6.5 80.1089815
AdobeSVGAGM.framework AdobeSVGAGM 1.0.0.39544 88.588432
dvametadataapi.framework dvametadataapi 10.0.0.0
CITThreading.framework
WRServices.framework
amtlib.framework amtlib 10.0.0.119
AdobeBIBUtils.framework AdobeBIBUtils 1.1.01 79.579975
boost_threads.framework boost_threads 10.0.0.0
aif.framework aif 6.0.00.1 1.
AdobeCoolType.framework AdobeCoolType 5.15.00.37848 79.579975
dvamediatypes.framework dvamediatypes 10.0.0.0
AdbePM.framework AdbePM 2.5.00.377243 1.578146
boost_date_time.framework boost_date_time 10.0.0.0
AdobeMPS.framework AdobeMPS 5.8.1.37174 79.577269
dvaui.framework dvaui 10.0.0.0
ahclient.framework ahclient 2.2.0.1
ICUData.framework ICUData 3.61 "gtlib_6.0" "." "21287"
dvamarshal.framework dvamarshal 10.0.0.0
Required plug-ins:
3D Studio 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Accented Edges 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Adaptive Wide Angle 18.1.2, Copyright © 2014-2017 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
Angled Strokes 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Average 18.1.2 ©1993-2017 Adobe Systems Incorporated - from the file “Average.plugin”
Bas Relief 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
BMP 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Camera Raw 10.1 (864), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Camera Raw Filter 10.1 (864), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Chalk & Charcoal 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Chrome 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Cineon 18.1.2 ©2002-2017 Adobe Systems Incorporated - from the file “Cineon.plugin”
Clouds 18.1.2 ©1993-2017 Adobe Systems Incorporated - from the file “Clouds.plugin”
Collada DAE 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Color Halftone 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Colored Pencil 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
CompuServe GIF 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Conté Crayon 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Craquelure 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crop and Straighten Photos 18.1.2 Copyright © 2003-2017 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
Crop and Straighten Photos Filter 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Crosshatch 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crystallize 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Cutout 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Dark Strokes 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
De-Interlace 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dicom 18.1.2, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “dicom.plugin”
Difference Clouds 18.1.2 ©1993-2017 Adobe Systems Incorporated - from the file “Clouds.plugin”
Diffuse Glow 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Displace 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dry Brush 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Eazel Acquire 18.1.2 Copyright © 2007-2017 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
Entropy 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
Export Color Lookup Tables 18.1.2 Copyright ©2012-2017 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
Extrude 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
FastCore Routines 18.1.2 ©1990-2017 Adobe Systems Incorporated - from the file “FastCore.plugin”
Fibers 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Film Grain 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Filter Gallery 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Flash 3D 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Fresco 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glass 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glowing Edges 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Google Earth 4 KMZ 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Graphic Pen 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Halftone Pattern 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
HDRMergeUI 18.1.2, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
HSB/HSL 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
IFF Format 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
IGES 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Ink Outlines 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
JPEG 2000 18.1.2 Copyright © 2001-2017 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
Kurtosis 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
Lens Blur 18.1.2, Copyright © 2002-2017 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
Lens Correction 18.1.2, Copyright © 2002-2017 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
Lens Flare 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Liquify 18.1.2, Copyright © 2001-2017 Adobe Systems Incorporated - from the file “Liquify.plugin”
Matlab Operation 18.1.2 ©1993-2017 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Maximum 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
Mean 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
Measurement Core 18.1.2 Copyright © 1993-2017 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
Median 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
Mezzotint 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Minimum 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
MMXCore Routines 18.1.2 ©1990-2017 Adobe Systems Incorporated - from the file “MMXCore.plugin”
Mosaic Tiles 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Multiprocessor Support 18.1.2 Copyright © 1990-2017 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
Neon Glow 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Note Paper 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
NTSC Colors 18.1.2 ©1993-2017 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
Ocean Ripple 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
OpenEXR 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Paint Daubs 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Palette Knife 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Patchwork 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Paths to Illustrator 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
PCX 18.1.2 ©1989-2017 Adobe Systems Incorporated - from the file “PCX.plugin”
Photocopy 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Photoshop 3D Engine 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
Photoshop Touch Copyright ©2013-2017 Adobe Systems Incorporated - from the file “PSDX.plugin”
Picture Package Filter 18.1.2 ©1993-2017 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Pinch 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pixar 18.1.2 ©1989-2017 Adobe Systems Incorporated - from the file “Pixar.plugin”
Plaster 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Plastic Wrap 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PLY 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
PNG 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pointillize 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Polar Coordinates 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Portable Bit Map 18.1.2 ©1989-2017 Adobe Systems Incorporated - from the file “PBM.plugin”
Poster Edges 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PRC 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Radial Blur 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Radiance 18.1.2 ©2003-2017 Adobe Systems Incorporated - from the file “Radiance.plugin”
Range 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
Render Color Lookup Grid 18.1.2 Copyright ©2012-2017 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
Reticulation 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Ripple 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Rough Pastels 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Save for Web 18.1.2, Copyright © 1999-2017 Adobe Systems Incorporated - from the file “Save for Web.plugin”
ScriptingSupport 18.1.2, Copyright © 2017 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
Shake Reduction 18.1.2, Copyright © 2014-2017 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
Shear 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Skewness 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
Smart Blur 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Smudge Stick 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Solarize 18.1.2 Copyright © 1993-2017 Adobe Systems Incorporated - from the file “Solarize.plugin”
Spaces 18.1.2, Copyright © 2015 Adobe Systems Incorporated - from the file “Spaces.plugin”
Spatter 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Spherize 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Sponge 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sprayed Strokes 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stained Glass 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stamp 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Standard Deviation 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
STL 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Sumi-e 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Summation 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
Targa 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Texturizer 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Tiles 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Torn Edges 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Twirl 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
U3D 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Underpainting 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Vanishing Point 18.1.2, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
Variance 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
Virtual Reality Modeling Language | VRML 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Water Paper 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Watercolor 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Wave 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wavefront|OBJ 18.1.2 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Wind 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wireless Bitmap 18.1.2 ©1989-2017 Adobe Systems Incorporated - from the file “WBMP.plugin”
ZigZag 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
com.adobe.inapp.purchase 2.10.56 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_2_10_56/purchase.html”
Libraries 2.10.56 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_2_10_56/index.html”
New Document 2.0.1 - from the file “/Users/kalepaulsen/Library/Application Support/Adobe/CEP/extensions/CCX_CMDN_EXTENSION_2_0_1_001/fnft.html”
Start 2.0.1 - from the file “/Users/kalepaulsen/Library/Application Support/Adobe/CEP/extensions/CCX_START_EXTENSION_2_0_1_044/index.html”
com.adobe.experimentation.extension 2.0.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.experimentation.extension/index.html”
Adobe Color Themes 6.1.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html”
Export As 3.0.8 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/PSPanel/dialog.html”
Device Preview 1.3.2 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.previewHD/PSPanel/panel.html”
com.adobe.preview.loader 1.3.2 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.previewHD/PSLoader/loader.html”
Installed TWAIN devices: NONE
Can acrobat open the PDF? If it can upload the pdf and post a link to it I'll see if I can open it win Windows Photoshop.
Does Photoshop Import PDF dialog open?
I can try. 9/10 times acrobat will crash on me (and of course, it's the newest version as well)... How/where exactly would I upload?
Yes, it will give me that dialog box when opening... I switched to a PDF from a long time ago and it opened fine... but still won't open my files that I was working on last week... if that helps at all
Some file sharing site like dropbox.
I could not open your PDF files in Photshop CS6, CC 2-14 oor CC 2018 I did not get the Import PDF dialog just got an program error.. Acrobat Reader was able to open them and save them. Evem the PDF save by acrobat could not be open in Photoshop.
dang... Any advice where I should go from here?
If all you use was Adobe's software report it as a bug.
Adobe has recently upgraded my Adobe Cloud version of Photoshop CC to the 2018 version. I also now get the error intermittent error 'could not complete your request because of program error' , This never happened with the previous version. I run Windows 7 and have made no changes to the operating system. My old version of Photoshop has no problems and works satisfactorily so the problem must be associated with this latest download.
Can anybody help?
When do you get that error? Are you always doing the same operation?
I get the 'could not complete your request because of program error' message when I try to open any image (.jpeg, .RAF or any RAW) .I am using Windows 7 and Photoshop CC 2018 via Adobe Creative Cloud. The program appears to work once after initial startup of my PC and then I get the error message on each subsequent attempt to open a new image, This never occurred with the previous version of Photoshop CC 2017.
See my recent reply in the forum.
There appears to be a program error in the latest version of Photoshop CC 2018 for use with Windows 7
