Hey guys! Long time Photoshop user, first time poster. I am self-taught, but relatively adept at Photoshop for the pretty basic stuff.
I have about 30 night pictures in which there is a lit location in the background, but the foreground shot is completely dark. I have tried every possible workaround to try to brighten the picture. But, it ends up looking washed out and noisy/pixelated.
I've played around with the levels. I have followed the official tutorials, the unofficial tutorials, searched for solutions, none of which work, etc etc.
Are there just some pictures that are beyond saving? Should I post an example of the picture?
Yes, you should. That said - what's not there is not there. Even a Raw image only has so much dynamic range. There are no magic invisible pixels that can be recovered if the image was shot with too low exposure and this may be a hopelss cause, after all.
Mylenium
Absolutely. But you can make a start by using the Camera RAW filter, providing you are using CC. Work on a copy of the layer. Move the Shadow slider all the way to the right, and edge the Black slider to the left to win back the contrast, and block out the worst of the noise.
I will just provide one...some are worse than others. I have gotten some of them into acceptable range; if I could get them better, that would be great. But, there are some that have been tough.
Restoring the full image just in one swoop might not be possible, but if you can boost the foreground as illustrated, it would not be to difficult to fix something up using a few duplicated layers with different settings and a bit of basic masking.
Mylenium
Wow, you were not kidding when you said it was dark. There is so little to work with, you are never going to get a really good result. If the original is a RAW file, then you could get a much better result in ACR. Is that the case? I have a feeling from the resolution, that it was taken with a phone.
Actually no. Just a regular point and shoot digital camera. I mean, it's a nice one, and it typically does pretty good with pictures.
The problem was that with the flash on, the foreground was perfectly bright, but the background was not even visible. My thought was that I would just go flash-less with the pictures and edit them after the fact. I've done it before with pretty decent results. I had no idea how difficult it could be.
Thanks so much!
Does your camera not give you independent control of ambient and flash exposure? You say it is a 'nice' point & shoot, so it likely does. You'd need to take it off the Green full auto setting, but even the Program setting should give you more control. What is the make and model of your camera?
I never work without a decent flash on both cameras. The EXIF for this shot says it was taken with 180mm, so I would have been a good five metres away, but even in very bright sunlight the flash has prevented the hard shadows on the runners face that would have been there without the flash. There is every chance that your P&S can adjust the degree of flash independently from the ambient light exposure, to give exactly the balance you want. Another reason to take it off full auto (I am sorry, I know that's an assumption) is that if your camera is capable of shooting RAW, it is unlikely to have that option with it on Auto mode.
Hi
I agree with Trevor. A couple of passes with the camera Raw filter got this, but doing it on a Raw file rather than an 8 bit png would be better. Better still balancing flash from the camera would produce a much better result. If you have trouble balancing flash and background with the controls on your camera then take the picture twice one of the person and one of the background then use Photoshop to composite them.
Dave
I've run the CSI Enhance plug-in on it, and got a surprising amount of additional detail.
Ah the CSI filter....
Dave
What tools did you use to bring up detail? You didn't mention taking it into Camera Raw--did you?
Here is what I played with in Camera Raw--I think I pushed it a little too far, but I wanted to show you how far you can take it. I would suggest duplicating the layer, running camera raw and then masking out the background so you have the original background part of the image. Below the image are the settings I used in CR--I focused on the Basic and the Detail tabs. Like I said before, I took the photo a little further than I probably would normally--but at least it gives you an idea of what you can do in ACR.
I hope this gives you something to work with! Let me know if this helps.
Michelle
Thanks so much. This is actually pretty similar to the results I have been getting through all of the other methods I have tried. There is something about it that feels blurry and noisy and unnatural.
I may give the multiple layers thing a try (I have tried it in 2 layers but not beyond that), just to see where it gets me. But, again, thank you so much...it looks like maybe there is not much chance of salvaging it. But, at least I know.
