I have a master file (Mac OSX) that I am working on and I replaced few REGULAR layers with LINKED smart object layers in order to reduce the file size.
The problem is that the file size does not change. When I look at the actual file in the finder before I made the change it is 481 megs but when I look at the same file after I replace the regular (non-linked) layer with Linked smart objects layers, the file size remains the same at 481 megs. On the doc. file size view on the bottom left hand side of my document it says 231/738; even after I make the change.
Can any one explain?
Additionally, will Photoshop's functions speed up if I am working on a master file with LINED OBJECTS instead of regular layers?
If not, then what is the efficiency benefit of working with linked smart objects given that I typically don't work with a team and just want to work faster?
Thanks for your time and action.
Before
After
Hi
If you use a linked smart object, the document still contains a layer the size of the rasterised image from the smart object. So in your case you will see no difference between the smart object and using a rasterised layer
The advantages of a linked smart object are :
1. The layer in your file will only be the size of a single rasterised layer - even if the file it links to contains several layers
2. When you update and save the source file, the linked smart object is updated.
3. If you duplicate the linked smart object in your document , there is no further increase in file size
Dave
Thank you @davescm. That is helpful in understanding linked smart object layers. Much obliged.
Hi @davescm, any thought on this question:
When I apply a paint filter to a linked smart object layer it takes several minutes to process, but if the layer is just a normal layer the filter process is much faster. Since I work with large photo files this process makes using fillers useless to me.
Am I doing something wrong?
I have an iMac 27 inch machine with 32 megs of RAM and only have Photoshop open. Files are operating at 100 % efficiency.
I'd not noticed any difference so I just tried applying the oil paint filter to several single layer photos and then did the same with those photos as linked smart objects in a new document (applying the oil paint filter to the linked smart objects). I used the timer in the info panel to compare and both came out the same ( 0.4-0.5 seconds.)
What size documents are you using?
Dave
Hi @davescm,
My document size is 30 X 30 @ 300 dpi.
Hi, sorry to dig up an old thread, but regarding 3rd thesis, it does increase size twice if you duplicate a linked layer. Do I do something the wrong way?
Every time you add a layer you increase the file size. If you have one layer and duplicate the layer, I believe you double the size of your file. If you have 50 layers and add a layer with a lot of paint you also increase the file size but only proportionately. That is my understanding.
Hi
My explanation was poor
If you duplicate a smart object - then it increases the file size in memory only by the size of a single raster layer, regardless of content.
Dave
