2
Photoshop bounces back and forth between saturated and muted colors
Jan 02, 2018 Jan 02, 2018
In the middle of working on both CMYK or RGB images, the photoshop interface will suddenly display a muted/unsaturated version of my document.
It only happens while I'm actually working on the document. If I save out the graphic (even while it's displayed as the muted version) the saved file will look fine. Sometimes I'll just keep working on the document and photoshop will unexpectedly revert back to the fully saturated version - but not always. When it doesn't revert back, simply closing out the document and reopening it magically fixes the problem every time.
This only happens within photoshop. I haven't had any other color issues like this in any other program.
Any thoughts?
9.5K
Community Expert , Jan 16, 2018 Jan 16, 2018
Adobe
Any chance you have been switching "Proof Colours" on/off  by accident (Ctrl+Y on Windows)
Dave
As clumsy as I am, I won't rule that out. However, I feel I haven't noticed any pattern for when the color shifts happen.
I'll keep any eye out for the possibility that maybe I've been mistakenly hitting "command+Y" when I attempt to transform an object with "command+T".
If it happens again it is easily checked by hitting Ctrl+Y and see if it switches back.
Let us know either way
Dave
Yes, that's pretty much the only possible explanation.
Mine is doing the same thing.  I just started my creative cloud subscription and noticed it right away when looking at a portrait.  Although for me it doesn't shift to desaturate or mute... it shifts to suddenly oversaturate.  Which of course is frustrating because it causes your eyes to sort of bug out.  Definitely need consistent color when working on fine detail color balancing.
It seems to do this when I am shifting viewing modes.  Not touching any other keys.. not changing any profiles.  But simply hitting the F button on a mac to toggle between full screen mode and the work screen.
The only thing I can think of is that this is because it is cloud based software and is depending on internet?  Maybe a lull in processing power?  I have no idea.  It's odd that only one other person is experiencing this here.
Jan 07, 2021 Jan 07, 2021
I am having the same issue.
Its when I toggle on the F Key the saturation and contrast changes.
I tried looking at all shortcuts and in window settings but cant figure out.
It drives me nuts as I am a digital painter and color is most important.
Any way to fix?
Feb 20, 2021 Feb 20, 2021
Does anyone have a solution for this problem, it appears to be a recurring issue.
The below images were processed in PS CC release 22.2 on a MacBook pro running Big Sur 11.1
Dual Monitor secondary monitor  Dell P2715Q, both monitors were just calibrated i1Studio 15.1
Open GL turned off
These are screenshot images that were cropped in PS so the profile associated is the monitor colorspace not corrected back.
The original image was been moved to the second monitor with no changes to the original AdobeRGB profile.
The second image is a screenshot captured after the second monitor was changed to Full Screen using the "F" key. No other actions taken.
The presentation of the color in the image on the secondary monitor does not change back even when switching back out of Fullscreen mode though closing it and reopenning indicates no actual change occured within the file, just how its presented on the monitor.
I like to keep my fullscreen mode with a white background for evaluating the dynamic range of my B&W images before printing and decluttered while I'm doing touch up work. What appears to be happening is PS (MAC not sure who) is switching the profile it isusing for displaying on the secondary monitor when it switches to Fullscreen.
The problem is that Photoshop uses the wrong monitor profile. We've had quite a few threads on the "wrong monitor profile" syndrome lately. Windows laptops may be affected too, but it is always laptop/iMac + external display, in other words, a computer with an integrated display. To my knowledge it never happens with desktop systems (and I've noticed this coming up from time to time over many many years).
This fact suggests that if there is a bug here, it may not be Adobe, and it may not even be the operating system. It may be connected to manufacturer's modifications to the operating system or GPU drivers to accommodate the integrated display. That's the only common factor.
It's a frustrating issue because it's so elusive. Being a Windows desktop user I've never seen it myself, but nevertheless it would be nice to have something to tell people.
There are workarounds, like setting up the same monitor profile for both displays. At least one of them will be right.
I'd try a broader search, in your case Apple forums, for Windows users I'd try laptop manufacturer's support forums.
Feb 28, 2021 Feb 28, 2021
I am having the exact same problem and it's annoying as hell! I had this issue couple of years ago but it was resolved. now it's recurring again stronger than ever. adobe is the worst and they couldn't care less just because they have a monopoly!!
May 04, 2021 May 04, 2021
You got the last sentence more than correct. They couldn't care less about the quality of their products or customer service. It's why I'm leaving Adobe for alternatives like Affinity Photo (I already use Capture One Pro since I shoot on a Phase One camera, but would probably still choose C1 over LR).
Any ways, I have this same problem with every monitor I plugin into my M1 Macbook. If PS is open on the secondary monitor (whether it's my Wacom Cintiq or my Asus ProArt display), and I minimize the PS window or the computer goes to sleep, when the window is reopened, it displays a heavily saturated and contrasty image until I minimize and reopen again, or drag the window between screens. The color spaces are all set correctly. It's so annoying and makes Photoshop next to unusable or unreliable for photo editing. I've noticed that I don't have this issue with Affinity Photo.
Mar 08, 2021 Mar 08, 2021
i am having the exact same issue,  and for me it is not the F key , it happens randomly when i am brushing, cloning,  sometimes zooming,   it is extremely frustrating.  I am a photo retoucher for hi end beauty cosmetics and skin color is extremely important.  seems like i am getting kicked out of my monitor calibaration,  i use a Ben q SW270 C on a mac pro.  when it kicks me out,    my screen gets saturated and red.    like a flash,   i have to launch the photoshop color settings dialog box, and just launching the window and not doing anything else,   it resets my monitor profile.    I have been working on this system for a very long time,     .    This started ,   id say,  last week?    SUPER annoying,  Needs to be addressed,  nothing changed for me,   same graphic card,  same hardware, same OS  catalina .   i just recently updated photoshop to the latest and greatest,  i was one upgrade behind,  with hopes that it would go away,  but no.   problem still there..
Apr 10, 2021 Apr 10, 2021
I recently upgraded my old mid-2010 Mac Pro 5.1 to Mojave. This is when I first started seeing this problem. It was very frustrating until I found this thread. I must have spent over 4 hours trying to figure out what the problem was. Currently, I am using photoshop 22.3. I would hit the F key to view in full-screen mode, and the color would have an obvious shift to over-saturation. I am using 2 monitors to work with. One is an old Apple 23" Cinema Display and the other is an NEC PA271Q. I really love the NEC monitor and I can rely on it for accuracy for printing on an Epson P9000 printer.
I found that I was actually using my old Cinema display for the main monitor. I used system preferences > monitor to change the arrangement to have the NEC become the main monitor. I simply dragged the menu bar indicator from the Cinema to the NEC in the Arrangement tab and tested the change. Magically my problem was solved. Thanks so much for your input in this thread.
"I smell victory"!!!!
Jun 11, 2021 Jun 11, 2021
I have the exact problem. CreativeCloud Adobe Photoshop 22.1.1 on a MacBook Pro, 15-inch, 2018 with a external DELL screen. The color changing is absolutely horrible and it's affecting my work!
..oh and why does is say SOLVED? it ain't solved at all.
GET YA SHHH TOGETHER ADOBE!
The problem is that the wrong monitor profile is loaded, and it is most likely an Apple bug. It has been reported quite a few times recently, always MacBook Pro/iMac plus an external connected display. In other words, an integrated display plus an external display. That's the common factor.
Some years ago there were a few cases with Windows laptops, also with an external display connected. But never desktop systems with multiple displays connected. Recently it has only been Macs.
All of which strongly suggests a problem with how displays are assigned in the video card/operating system.
Photoshop has no influence over which monitor profile is used. It just loads whatever it gets from the operating system.
A workaround is to switch primary/secondary display assignment in the OS. That seems to get around it for most people.
Which makes me wonder why Affinity Photo doesn't have this issue. I've made the decision to switch over to Affinity from Photoshop since it's been more stable and reliable. Adobe doesn't really seem to care about the quality or custom service of their products, and the [removed] call center people get REALLY defensive if you say something is a Photoshop issue.
I will back the claim that switching the external monitor to be the primary monitor will solve this as a work around.
Oct 11, 2022 Oct 11, 2022
I know this is an old thread but I recently switched to a desktop PC from an Imac and I have this issue big time. I have a Windows 11 PC connected to single profiled Benq SW321C monitor and I'm running Photoshop version 23.5.1. I get the colour shift only when I go into full screen no menus mode, mostly to muted colours but sometimes it displays correctly and sometimes it displays over saturated colours. No issues in using the Lights out feature in Lightroom which always displays correctly. Turning off the GPU option in preferences removes the issue but of course disables some PS features. I'm at my wits end with this issue and any help or pointers would be most appreciated.
If disbling GPU corrects it, then it's most likely a buggy GPU driver.
It should also be said that the BenQ software doesn't have a good track record. It has been known do do things like this, where the monitor profile isn't correctly loaded. Since display color management is actually performed in the GPU, these two may be connected. One may trigger problems in the other.
Do you have any other calibration software you can try? Or maybe test with Adobe RGB (assuming it's a wide gamut model).
